October 14, 2026, 02:40:53 am
| |-+  For sale!
| | |-+  1641 motor, built G/box. narrowed beam. 48 DRLA's
Author Topic: 1641 motor, built G/box. narrowed beam. 48 DRLA's  (Read 3545 times)
59.143
« on: February 23, 2008, 18:05:51 pm »
For sale- complete turnkey high spec 1641 motor,  probably a bit small for you guys!
Spec- mahle 87mm B+P.German69mm crank balanced with 12v 200mm flywheel.
Engle V26 cam.Manton steel pushrods.Magnumstraight cut gears.Scat1.4.1. rockers.
T.3 F.I. 040 heads,heavily ported with matched manifolds.Berg H.D. valve springs.
Bugpak hardened collets+steel caps.Weber 36IDF carbs,32mm venturis.Berg linkage.
Bosch 050 distributor.Bosch coil. Full dress tinwear(not to everyones taste!)
0 miles,cam run in.  Bolt in and go.  £1650.
Also-  Cogbox built 1500 gearbox,complete drum to drum.
4.12 R+P,H.D. diff+side plate,swayaway race axles.
Ran a (novice)15.8 up at the pod in a heavyweight ghia.
£750.
Also- Lowered/narrowed K+L beam complete with CSP discs,koni shocks,rebuilt K+L's,
steering box,tie rods.  £750
Also - Dellorto 48 DRLA carbs,complete with filters,manifolds and hex linkage.  £600.
All parts in Harpenden,Herts, UK.  Call 01525 860472,07769 680547.  Cheers.
