July 22, 2026, 22:34:58 pm
Lowering a 412 ?
Topic: Lowering a 412 ? (Read 5914 times)
71CALRIPPER
Lowering a 412 ?
February 27, 2008, 17:08:01 pm »
May be picking one up as my daily driver
any ideas how to bring the front down so its at least level with the back ?
bob
team97
3M TA3
Re: Lowering a 412 ?
February 27, 2008, 17:11:58 pm »
Quote from: 54caldub on February 27, 2008, 17:08:01 pm
bob
Contact Randy at oldbug.com He's got a custom green / woody type4 thingy
Der Kleiner Panzers III
D.K.K.
71CALRIPPER
February 27, 2008, 17:24:43 pm »
cheers dude , i was wondering if a set of lowerd 1303 springs would cut the mastard but it may be a weight factor .
February 27, 2008, 17:42:39 pm »
I'm a So Cal native... land of just about every kind of car. Yet it's been YEARS since I've seen a Type 4 on the road.
71CALRIPPER
February 29, 2008, 13:43:37 pm »
Right looks like BMW E30 Standard springs work and dont need any mods
£24 each which is a good price to boot
IP359
February 29, 2008, 14:05:41 pm »
Quote from: vwfye on February 27, 2008, 17:47:36 pm
this one is mine and sitting even lower now...
A friend of mine looks for one in mini van (break) version...
So if you have that for sale, don't hesitate !
Thanks for him
http://www.flat4sale.fr/detail.php?id=1334
Flat4sale.fr, the VW aircooled classified ads website
Mario/DKT
February 29, 2008, 17:44:48 pm »
i think bmw spring's from the 3-series helps to lowering...
http://www.mariodkt.blogspot.com/
http://www.type3headquarter.de
http://www.derkleinetorpedo.com/
alfie the monster
March 01, 2008, 12:52:01 pm »
This one belongs to club member Neal, I think it may be for sale too
JG54 Grunherz
March 01, 2008, 13:14:49 pm »
Neals is absolutely awesome IMHO
WRT lowering the 412. The cheaper way is to take a set of front springs from a Golf1 gasoline version. (The diesel frt springs are stiffer and dont suit the 412) That will lower it 55-60 mm. That is enough for regular street driving. More and it becomes a problem. The only downside is that it doesnt carry that much in the front luggagge compartement before it stands on the rubber stops.
I used a spring from an older BMW once, but I forgot which model. That spring was 1 mm thicker in the threads, which gave the same stance unloaded as the Golf springs, but carried a load much better.
On the last one I set up, I modified a set of Koni front shocks from a T3 caravelle so they fitted in the rear and used a set of adjustable Spax from a 73 super beetle in the front. I had a new front stabilizer made ehich was 50% stiffer over stock (I forgot how thick, but I think it was about 20 mm.) And modified a 3/4" rear ADDCO stabilizer from a beetle. I think it was originally thought for a swingaxle. To top it off we used a set of BBS 7 X 16 wheels w. 205/55X 16 frt & 215/55 X 16 rear.
Transmission was an early "FA" which is about a 4,125 T1 ratio. Engine was a 2 liter type4 bumped to 121 hp.
That was ran great both around corners and on the freeway. But it disappeared about 4 years ago. I do not know what happened to it.
