September 24, 2026, 03:03:06 am
Carbs, carbs and MORE carbs....
Topic: Carbs, carbs and MORE carbs.... (Read 26194 times)
Re: Carbs, carbs and MORE carbs....
Reply #30 on:
April 29, 2009, 00:13:00 am »
Yep! They ARE a pain for most people. Hence why I'll hopefully end up with a set for my 1915cc. Because I'm used to doing things the difficult way. It is how I rotate.
Hotrodvw
Reply #31 on:
April 29, 2009, 05:11:00 am »
That's why 'Weber Windows' came in to play. I run 40mm Dells.........I dig 'em. IDA's are the shiz are far as looks
and
performance go though.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Reply #32 on:
May 20, 2009, 23:02:36 pm »
Quote from: vwcab on April 28, 2009, 22:16:08 pm
Now that weare talking about carbs...............when building an engine for our cars,the most (?) use
the weber 48 ida carbs(and in callook land these are "THE" must have carbs).
But there are also weber "idf" carburettors.
Now my question (is this a stupid question?
):what is the difference between these?
Can/will somebody help me out?
Thx,Peter
Nobody can help me out?
..............or explain?
Reply #33 on:
May 20, 2009, 23:49:53 pm »
Everything! IDA's were made to be a race carb, IDF's were more geared towards street use. As far as I know, pretty much the only thing that is interchangeable are the jets.
marc1951
Reply #34 on:
May 21, 2009, 02:56:55 am »
IDFs have better progression circuits which makes them smoother when driving in traffic. The IDAs were made for wide open throttle, balls out racing so the part throttle smoothness is not so much a concern.
Personally I prefer the IDA, but then I always have my foot into it.
Anybody running a Holley Bug Spray has experianced the lack of progression circuits. You can get them to run well but it takes patience getting the right gap between the main jet mixture and the idle mixture.
Marc Buehler
DRA
The legendary DRA car club
(Der Rennmeister Association)
Reply #35 on:
May 21, 2009, 19:35:30 pm »
Thx for the info Zach & Marc.
Reply #36 on:
May 21, 2009, 20:07:22 pm »
I've used nothing but DCNFs on my dual carb motors, but what do I know. At least they are old school. That seems to be important here. LOL!
Reply #37 on:
May 21, 2009, 20:47:32 pm »
Quote from: vwcab on May 20, 2009, 23:02:36 pm
Thx,Peter
having run both for years.....
The IDA's: on the surface, it's hard to come up with logical reasons to run these on a street car. Not that they run poorly (even in 2 prog hole setup), because if they're tuned to what your motor wants they are fully driveable. But it's the non logic that makes the 48's such a must have. If you have IDF's and you go for a ride in a hot car with IDAs, after that ride you'll want a set. They sound incredible, they pull harder all the way up, the engine seems to have an edge it never had with IDFs. It's a whole different game with IDAs.
The IDFs are good carbs for bus or a car you'd drive everywhere. I'd say start with 44IDFs if you buy them, as the 40 IDFs seem so soft on everything. Nice thing about IDFs is the air bypass circuits you can adjust (given you can even get to the screws to adjust them though). IDF's are a step up from Kadrons, that's the best way I can describe them. They pull nicely at low and mid rpm, good on freeway. Get ready for lots of swearing when you drop a cylinder because of idle jet plugging.
Rasser
Reply #38 on:
May 21, 2009, 21:24:44 pm »
Quote from: Jim Ratto on May 21, 2009, 20:47:32 pm
Now that´s were the Dellorto DRLA comes in. Lovely carb with idle jets on top as the IDA.!
1955 type1
1966 type2 13w deluxe
Reply #39 on:
May 21, 2009, 22:28:03 pm »
thx Jim
jimi323
Reply #40 on:
May 22, 2009, 13:35:40 pm »
i'm so curious about DCNFs cause nobody use it here in Italy...the most use IDF o DRLA..( maybe cause 36 & 40 idf & DRLA were easy to find on ALFAROMEO 33)
can someone talk me about DCNF? i see that are very used in States... are they older than Idf i think..right?
what cars mounted it?
thank u !
jimi323
Reply #41 on:
May 22, 2009, 13:38:33 pm »
Quote from: roland (DAS) on April 28, 2009, 22:39:19 pm
IDF's are a pain in the a** to adjust in a bug. Perfect for a bus though
hi Roland..why u say that?
Reply #42 on:
May 22, 2009, 15:37:53 pm »
I think DCNFs came on Ferarraris of Alfas. I don't know which came first. I have both a set of 44 DCNFs and 42 DCNFs currently, but I am using the 42s because they seem to be more driveable. They don't make as much HP which makes sense as they are smaller. They are very smooth with no flat spots from idle all the way up to over 6000 RPM. Mine are Berg modified with Berg manifolds match ported to Berg heads.
Reply #43 on:
May 22, 2009, 19:59:36 pm »
my experience between 40 dells, IDF's and DCNF's is that i like the DCNF's a bit better.
the IDF's and certainly the 40's are a bit underrated and i have to disagree with Jim. they are a very good carb for engines under 2000cc and will work great on a street/strip engine. sure idles clog up and they need some finetuning, but i think they respond very well and are with a bit off patience quite easy to keep in tune and good working order.
but i have to say i would rather have 40 dells over 40 idf's... they seem to have more power in them and just have that silky smooth transition from idle to mains built into them. the idea that dells are better then webers could be only my personal perception and be completely a thing between the ears.
so then comes the dcnf ( i run 42s) and they are just the ticket for me. they fit nice in a type3, look bulky like a type3 engine and just run great. recently the only thing i have noticed is just a little stumble when hitting the trottle in lower rpms. just a small hesitation when i hit the gas. but that is probally a jetting issue.
Allen Wiess
Reply #44 on:
May 22, 2009, 20:52:04 pm »
Any carburetor is OLD SCHOOL........................
Geers Engineering / LAT Lubricants
Reply #45 on:
May 23, 2009, 02:27:57 am »
Quote from: Allen Wiess on May 22, 2009, 20:52:04 pm
get OUT!!!!
streetvw
Reply #46 on:
May 23, 2009, 15:35:42 pm »
Quote from: Sarge on May 23, 2009, 02:27:57 am
get OUT!!!!
LOL!! but weres the love?
anyways your only telling him to get out cause you know he's right Sarge
rick m
Reply #47 on:
May 23, 2009, 15:48:33 pm »
Allen,
Great post!!! It had me laughing. The only thing about EFI is when you're on a long cruise and something electrical goes. You can cripple a carb motor to the next repair stop. With EFI you are dead in the water if electrical issues arise. Otherwise, EFI is obviously far superior in all other circumstances.
Good to see you post. The 67 looks great since the new paint job and refurbishing!
Rick Mortensen
Rick Mortensen
Driving Hot VWs since 1970
