September 24, 2026, 05:43:03 am
anybody knows more of this car?
Topic: anybody knows more of this car? (Read 10074 times)
bullitt
everything as it was at the good old days.
March 04, 2008, 02:51:44 am »
it was built in 1969 by haven miller company...and maybe it is first example of real finished and "custom"look baja bug.
i know u guys aren't into offroad things...but isn't it tooooo funky?
got more pictures of it or similar?
bullitt
Re: anybody knows more of this car?
March 04, 2008, 03:09:07 am »
they told me now on "thesamba" it is on march 08 hotvws.....hehe not arrived yet in italy....
my questions stay open though...if someone knows more...
bullitt
March 04, 2008, 13:52:19 pm »
found out:
"The Original Baja Bug
Baja bugs, and their copies, are a common sight anywhere off-roaders or desert racers congregate today. But it hasn’t always been that way.
In 1967, Gary Emory wanted to build a Meyers Manx dune buggy, but couldn’t raise the money for the kit. Gary was assistant parts manager at Chick Iverson Volkswagen in Newport Beach, California at the time, so he had access to parts and information to build such a car, but he also had a wife and two young daughters, so the initial cash outlay was out of the question.
To surmount the problem, Emory traded an 80cc Suzuki for a clapped-out 1957 sunroof Beetle and built his own buggy to his own design. He had first class help on his project because his father, Neil was body shop manager and his brother, Don, was in charge of the paint shop-both, also at Iverson’s.
The 57’ Beetle was completely stripped and cleaned down to bare metal. The interior was left gutted, and the windows and raising mechanism were all removed. Ted’s Aircraft Interiors in Santa Ana upholstered the sock seats with black vinyl and built vinyl side curtains that snapped onto the doors to cover the areas left open when the windows were removed. This saved some weight, and allows open-air driving if desired.
Meanwhile, father Neil (old time hot rod and custom car nuts will remember Neil as the co-owner of Valley custom in Burbank, California where some of the best custom cars of all time were built in the 1950s) was working on the fenders, hood and rear lid.
The front was chopped off short, and the fenders trimmed to match. Top speed was not a part of the scheme, and gasoline was 30 cents a gallon, so aerodynamics was not considered in planning the front of the Beetle buggy. What was considered was light weight, minimal overhang, and enough metal left to keep flying dirt off the car itself.
After bobbing the front and rear ends (the running boards were to be left off), two front fenders were reworked to become rear fenders. A right front was used on the left rear, and a left front on the right rear. This gave a wider fender to clear the big tires that Gary wanted to install and also allowed a better styling match between front and rear fenders.
The bead that appears on the outer edges of all four fenders was fabricated by taking two pieces of 5/32-inch wire which were welded to the fender edge and ground to give a finished surface. A slight bit of body lead was used to smooth everything out. Aside from the aesthetic value, the wire added both strength and stiffness to the fenders.
Because the car was to be used for family outings in the desert, complete reliability was one of the top considerations. The engine was stock but consisted of a 1500 case with 1600 barrels and pistons. A single-port heads. The main alterations to be seen are the headers and upswept exhaust.
Added ground clearance was obtained by cutting the front torsion bar mounts and rotating them so the trailing arms hang down at an angle rather than straight back. At the rear, the simple expediency of installing a 1967 transporter transmission and axle assembly withy its outboard reduction gears did the trick. The Gated XT Commando tires-7.35-15 front, 10-15 rear – are mounted on Ansen Sprint alloy wheels (these are actually the first set of wheels of this series to come from Ansen’s firm).
After Gary and Neil had done their work, brother Don painted it chrome yellow. A tribute to his ability is knowing that the car still carries the original paint on the body and only the four fenders have been repainted.
When the car was finished, it attracted for more attention than any of the Emory’s had expected. Doyle Dane-Bernbach used it in a Volkswagen ad titled: “What have they done to our car”? The ad appeared in Time, Life, and on outdoor billboards.
Since 1967, the car has had two engines, a different front end, and acquired a new exhaust system. It has also acquired a new owner. Not long after the car was finished, Gary’s eight-year-old daughter Shelly told daddy she wanted that car. Gary said okay, when you’re old enough you can have it.
Well…Shelly acquired a husband and a son of her own, and recently reminded dad that he had promised her the car. So said, so done. Rick and Shelly Lugo are the new owners of the original Baja Beetle Bug.
Gary has gone on to operate Porsche Parts Obsolete in Costa Mesa, California, and brother Don and father Neil have a shop in Fallbrook, California called Emory’s which does custom bodywork and painting-specializing in Porsches.
Emory Motorsports "
bullitt
March 04, 2008, 13:55:04 pm »
more
bullitt
March 04, 2008, 13:57:55 pm »
it's the first baja
March 04, 2008, 15:46:28 pm »
I remember when that magazine/issue came out... still have mine. That was an interesting article.
Kobus
See you at the NEXT EUROPEAN BUGIN!!! Summer 2011!
March 04, 2008, 16:00:19 pm »
Garry still has the Baja! it's up in Oregon i think at his Porsche Farm..
Keep the Thru Cal-Look Alive!!!!
bullitt
March 04, 2008, 16:07:53 pm »
i think that is very cool, coolest baja i've ever seen!! idea of button up windows is the top!!!....and then that lines...gates tires..ansen mags...woooo
bullitt
March 04, 2008, 16:09:22 pm »
why i found firt infos saying haven miller company built if it was built by gary emory?
March 04, 2008, 17:50:45 pm »
Quote from: bullitt on March 04, 2008, 16:09:22 pm
If I remember correctly, Miller-Haven was the 1st company to come out with a Baja Bug kit. What we now call a narrow eyes kit.
Rick
Tony M
March 04, 2008, 18:02:56 pm »
I rember that car - must have been early 70's when first seen it. By 74 i had made my first baja - 30 years later made my 2nd baja - very cool car - even by todays standards
bullitt
March 04, 2008, 18:24:47 pm »
hey rick!!! do you remember if first baja kit (narrow eyes) were mounted with six volt bubble headlight or modern flat twelve volt one?
i love narrow eyes baja bug...in my mind, the bugeye is the only baja bug.....it was maybe tamiya sand scorcher tht changed my mind!!!
never had that toy...but i dreamt a lot of it when i was 8-9 or so!!!
i bought it at 25...never used it...but it's there...realized dreams of childhood..just like my split, bus, my dune buggy, my vespa...
sometimes i feel a lucky man..just because at 32 yo i'm doing same games with same toys...only all is bigger!!!!
March 04, 2008, 18:37:50 pm »
Quote from: bullitt on March 04, 2008, 18:24:47 pm
First ones use the flat 67 on up headlights.
bullitt
March 04, 2008, 20:52:26 pm »
...that is most lucky design in my opinion...
ty for infos rick
