September 23, 2026, 01:59:52 am
| | |-+  Cool vid (short but sweet)...
Author Topic: Cool vid (short but sweet)...  (Read 22117 times)
Tim C
« on: October 02, 2006, 10:01:31 am »
A short clip of 3 of our club guys on a drive through a tunnel this weekend... Car 1 is a 2276cc 66, second car is my 2165cc 63 and the last car is a 2276cc 56....
<a href="http://www.youtube.com/v/FIJI_2hnKEw" target="_blank">http://www.youtube.com/v/FIJI_2hnKEw</a>
Not a long clip but the feel of speed is quite cool.
Needs sounds.  Cool
JG54 Greenhearts
« Reply #1 on: October 02, 2006, 10:13:37 am »
Tunnels loves lookers... other motorists may not  Wink
Cool vid!!!
« Reply #2 on: October 02, 2006, 11:34:21 am »
looks cool! but i don't hear much apart from the hiss...
they're bad ass though  Cool
Rasser
« Reply #3 on: October 02, 2006, 15:17:13 pm »
Don´t hear much...   try this clip instead  Grin Grin Grin
Here is a video of me driving my 62 ragtop with my old engine (1914- 147hp). Cruising down the tunnel in 4. gear, then shifting to 3. midway through and racing to the top before shifting to 4. again (gearbox - 4.12RP- std. gears)
I miss my old engine ;-)
<a href="http://video.google.com/googleplayer.swf?docId=-5782694275058868534" target="_blank">http://video.google.com/googleplayer.swf?docId=-5782694275058868534</a>
« Last Edit: October 02, 2006, 15:19:21 pm by Rasser DK » Logged
1955 type1
1966 type2 13w deluxe
Tim C
« Reply #4 on: October 02, 2006, 15:44:10 pm »
Now that is a cool clip...  Cool
JG54 Greenhearts
Olaf A./DFL
« Reply #5 on: October 02, 2006, 16:11:50 pm »
oooh yes -how i love that tunnel sound…
Rasser
« Reply #6 on: October 02, 2006, 17:41:03 pm »
sorry to let u guys down,   but it´s the sound of 40 dellortos and  not 48IDA´s
1955 type1
« Reply #7 on: October 02, 2006, 18:18:01 pm »
sweet!!!
would you mind sharing the specs of your potent 1914? sounds like a champ to me
anyone else that has some vids?  Grin
Rasser
« Reply #8 on: October 02, 2006, 18:37:35 pm »
sweet!!!
unwelded 040 heads   40-37,5mm
w130 cam
1.25:1 rockers
CB ultra leight weight lifters
Manton pushrods
911 style adjusters
JPM valve springs (w130 + 1.25 rockers  require insane pressure if you don´t want to float the valves)
40mm dellorto carbs with 37 vents
69mm DPR crank
stock rods
mahle piston/cylinders
1-5/8" merged header
2½" magnaflow exhaust
C/R  10.85:1
Straight cuts
sump
etc.
etc.
max power at 6750 rpm
« Last Edit: October 02, 2006, 20:18:13 pm by Rasser DK » Logged
1955 type1
« Reply #9 on: October 02, 2006, 20:08:29 pm »
damn, i already thought it would need high revs, 130 cam...
was it driveable in town though?  Wink
maX cal-look
« Reply #10 on: October 02, 2006, 20:09:20 pm »
Too short ...
I speak about video, not anything else !!  Roll Eyes
Rasser
« Reply #11 on: October 02, 2006, 20:16:56 pm »
Perfectly driveable !!!!!  It´s all in the carb tuning/tweaking.
Listen to the video once again, and pay close attention to the idle when waiting for green light, and the sound when driving slowly away.
1955 type1
Heebah
« Reply #12 on: October 05, 2006, 11:21:12 am »
Yeah.
Tunnelsounds are nice. Me like.
<a href="http://video.google.com/googleplayer.swf?docId=-6690553909418429263" target="_blank">http://video.google.com/googleplayer.swf?docId=-6690553909418429263</a>
-Heebah-
« Reply #13 on: October 05, 2006, 16:26:28 pm »
Yeah.
-Heebah-
Is this your's? Nice dash  Smiley if so, do you have any pics?
I think he broke his gearbox in that last sprint though...  Roll Eyes
Frank LUX
Back...Soon...hopefully!!!
« Reply #14 on: October 05, 2006, 21:06:07 pm »
Nice one... Wink Grin Grin
Frank
Heebah
« Reply #15 on: October 06, 2006, 11:16:51 am »
Here´s a shot from my dash.
The lambda-meter is usually out of sight, not like in the picture.
And nope, I didn´t broke my trans in that one, it was before that and later in the summer...3 boxes in one summer.
Now I have Weddle all-the-way and Karpiola axles. Should have listen to late Gene Berg: By the best, cry ones...
-heebah-
« Reply #16 on: October 06, 2006, 15:57:01 pm »
looks pretty bad ass to have a monster tach right in the middle.
what kind of speedometer is it you're using? and the other instrument is a fuel gauge right? but did i notice the indicator reflected in the gauge?
p.s. 3 boxes wow!
Heebah
« Reply #17 on: October 13, 2006, 13:09:54 pm »
Speedo is an old vdo-meter with trip, works fine. (from scaniavabis I think)
On the right is an old Dehne fuel cauge.
I have hidden the indicator-, charging- and highbeamlight behind the speakergrill.
Shiftlight is in ignitionkeys original place, I have a original streeringlock with ignition now.
I had to make some room with machinefile to fit the Monster tach.
-heebah-
p.s. 3 boxes wow!
Tom G.
« Reply #18 on: January 25, 2007, 17:36:47 pm »
Hi,
you have nice concept....i have seen your video...:-))
Your magnaflow make a really nice sound, you can hear it..How is your fuel consuption (l/ 100km) with the 40 DRLA??
I think if you use 45 DRLA it would give  a + in HP and more torque!!!
I have to change in my 1951ccm to bigger valves, damm i want also good HP :-))It´s not enough with 120 HP.... Sad
Bye
Tom
Rasser
« Reply #19 on: January 25, 2007, 20:44:48 pm »
cruising  at 100km/h   =  8-9l/100km
yeah magnaflows rock !!!
1955 type1
Tom G.
« Reply #20 on: January 26, 2007, 23:45:34 pm »
what  Shocked Shocked...what is your jet size of your carbs (idle,main,air,needle valve)??
Bye
Tom
« Reply #21 on: January 27, 2007, 00:52:08 am »
My 2176 superflow IDA engine also gives that liters pr Km ratio...
Tobi/DFL
« Reply #22 on: January 27, 2007, 09:49:02 am »
I can second that. On the way home from the last Hessisch Oldendorf meeting in 2005 my 2176ccm IDA engine needed about 10-11 litres of Shell´s V-power per 100km while cruising the autobahn with about 100-110km/h.
What it needs when you push the throttle is another story... Grin
« Reply #23 on: January 27, 2007, 14:21:41 pm »
Then it needs a bigger tank!!  Grin
« Reply #24 on: January 27, 2007, 15:06:55 pm »
Bye
Tom
I did some research for you  Wink
If you check his last posts you'll see that the first 3 times he gives away his specs he says it had 37mm vents, the last 2 times the vents have shrunk to 36mm  Tongue
Tom G.
« Reply #25 on: January 31, 2007, 00:02:50 am »
Bye
Tom
Yes you are right , but he didn´t tell us or me, what his jet sizes are!!
But thanks for your research Cool
Bye
Tom
Rasser
« Reply #26 on: January 31, 2007, 08:59:02 am »
Bye
Tom
yeah   and both are right  :-)    I first build my 1914 with w120 cam using 34mm vents....  next year w130 using 36....  final 2006 season 37mm vents (custom made by a Gribel MIB).
why i mixed it up - I hope i have cleared it up now.
Jetting was 57/160/160  - 37vents (yeah I know it sounds strange with 160/160 - but it was dynoed by a superprof. carb guy, and ran great)
What do you mean by needle valve ?...are you thinking about the emulsion tube ?
« Last Edit: January 31, 2007, 09:01:31 am by Rasser DK » Logged
1955 type1
richarzzz
« Reply #27 on: January 31, 2007, 13:02:38 pm »
nice vids, so i try to complete this threat with one of mine...
<a href="http://www.youtube.com/v/-dFgIjQuVwM" target="_blank">http://www.youtube.com/v/-dFgIjQuVwM</a>
hope you enjoy it
jens
if it's tits or tires, it's gone be trouble
Andi/DFL
« Reply #28 on: January 31, 2007, 21:11:33 pm »
just two vids (sorry for the bad quality) that I used to check youtube:
<a href="http://www.youtube.com/v/B0rSomMMFnI" target="_blank">http://www.youtube.com/v/B0rSomMMFnI</a>
<a href="http://www.youtube.com/v/zdQK0Urcj-Y" target="_blank">http://www.youtube.com/v/zdQK0Urcj-Y</a>
