November 02, 2026, 22:55:55 pm
Cool vid (short but sweet)...
Topic: Cool vid (short but sweet)... (Read 22960 times)
Tim C
October 02, 2006, 10:01:31 am »
A short clip of 3 of our club guys on a drive through a tunnel this weekend... Car 1 is a 2276cc 66, second car is my 2165cc 63 and the last car is a 2276cc 56....
http://www.youtube.com/v/FIJI_2hnKEw
Not a long clip but the feel of speed is quite cool.
Needs sounds.
JG54 Greenhearts
Re: Cool vid (short but sweet)...
October 02, 2006, 10:13:37 am »
Tunnels loves lookers... other motorists may not
Cool vid!!!
October 02, 2006, 11:34:21 am »
looks cool! but i don't hear much apart from the hiss...
they're bad ass though
DVK ~
Rasser
October 02, 2006, 15:17:13 pm »
Don´t hear much... try this clip instead
Here is a video of me driving my 62 ragtop with my old engine (1914- 147hp). Cruising down the tunnel in 4. gear, then shifting to 3. midway through and racing to the top before shifting to 4. again (gearbox - 4.12RP- std. gears)
I miss my old engine ;-)
http://video.google.com/googleplayer.swf?docId=-5782694275058868534
Last Edit: October 02, 2006, 15:19:21 pm by Rasser DK
1955 type1
1966 type2 13w deluxe
Tim C
October 02, 2006, 15:44:10 pm »
Now that is a cool clip...
JG54 Greenhearts
Olaf A./DFL
October 02, 2006, 16:11:50 pm »
oooh yes -how i love that tunnel sound…
http://www.dflvwclub.de/
Rasser
October 02, 2006, 17:41:03 pm »
Quote from: olaf on October 02, 2006, 16:11:50 pm
sorry to let u guys down, but it´s the sound of 40 dellortos and not 48IDA´s
1955 type1
October 02, 2006, 18:18:01 pm »
Quote from: Rasser DK on October 02, 2006, 17:41:03 pm
sweet!!!
would you mind sharing the specs of your potent 1914? sounds like a champ to me
anyone else that has some vids?
DVK ~
Rasser
October 02, 2006, 18:37:35 pm »
Quote from: 67-indeed on October 02, 2006, 18:18:01 pm
sweet!!!
unwelded 040 heads 40-37,5mm
w130 cam
1.25:1 rockers
CB ultra leight weight lifters
Manton pushrods
911 style adjusters
JPM valve springs (w130 + 1.25 rockers require insane pressure if you don´t want to float the valves)
40mm dellorto carbs with 37 vents
69mm DPR crank
stock rods
mahle piston/cylinders
1-5/8" merged header
2½" magnaflow exhaust
C/R 10.85:1
Straight cuts
sump
etc.
etc.
max power at 6750 rpm
Last Edit: October 02, 2006, 20:18:13 pm by Rasser DK
1955 type1
October 02, 2006, 20:08:29 pm »
damn, i already thought it would need high revs, 130 cam...
was it driveable in town though?
DVK ~
maX cal-look
October 02, 2006, 20:09:20 pm »
Too short ...
I speak about video, not anything else !!
Nostalgia Skirt's Raiser member !
http://maxcal-look.skynetblogs.be/
http://nsr.skynetblogs.be/
Rasser
October 02, 2006, 20:16:56 pm »
Quote from: 67-indeed on October 02, 2006, 20:08:29 pm
Perfectly driveable !!!!! It´s all in the carb tuning/tweaking.
Listen to the video once again, and pay close attention to the idle when waiting for green light, and the sound when driving slowly away.
1955 type1
Heebah
October 05, 2006, 11:21:12 am »
Yeah.
Tunnelsounds are nice. Me like.
http://video.google.com/googleplayer.swf?docId=-6690553909418429263
-Heebah-
October 05, 2006, 16:26:28 pm »
Quote from: Heebah on October 05, 2006, 11:21:12 am
Yeah.
-Heebah-
Is this your's? Nice dash
if so, do you have any pics?
I think he broke his gearbox in that last sprint though...
DVK ~
Frank LUX
Back...Soon...hopefully!!!
October 05, 2006, 21:06:07 pm »
Nice one...
Frank
Heebah
October 06, 2006, 11:16:51 am »
Here´s a shot from my dash.
The lambda-meter is usually out of sight, not like in the picture.
And nope, I didn´t broke my trans in that one, it was before that and later in the summer...3 boxes in one summer.
Now I have Weddle all-the-way and Karpiola axles. Should have listen to late Gene Berg: By the best, cry ones...
-heebah-
October 06, 2006, 15:57:01 pm »
looks pretty bad ass to have a monster tach right in the middle.
what kind of speedometer is it you're using? and the other instrument is a fuel gauge right? but did i notice the indicator reflected in the gauge?
p.s. 3 boxes wow!
DVK ~
Heebah
October 13, 2006, 13:09:54 pm »
Speedo is an old vdo-meter with trip, works fine. (from scaniavabis I think)
On the right is an old Dehne fuel cauge.
I have hidden the indicator-, charging- and highbeamlight behind the speakergrill.
Shiftlight is in ignitionkeys original place, I have a original streeringlock with ignition now.
I had to make some room with machinefile to fit the Monster tach.
-heebah-
Quote from: 67-indeed on October 06, 2006, 15:57:01 pm
p.s. 3 boxes wow!
Tom G.
January 25, 2007, 17:36:47 pm »
Quote from: Rasser DK on October 02, 2006, 15:17:13 pm
Hi,
you have nice concept....i have seen your video...:-))
Your magnaflow make a really nice sound, you can hear it..How is your fuel consuption (l/ 100km) with the 40 DRLA??
I think if you use 45 DRLA it would give a + in HP and more torque!!!
I have to change in my 1951ccm to bigger valves, damm i want also good HP :-))It´s not enough with 120 HP....
Bye
Tom
Rasser
January 25, 2007, 20:44:48 pm »
cruising at 100km/h = 8-9l/100km
yeah magnaflows rock !!!
1955 type1
Tom G.
January 26, 2007, 23:45:34 pm »
Quote from: Rasser DK on January 25, 2007, 20:44:48 pm
what
...what is your jet size of your carbs (idle,main,air,needle valve)??
Bye
Tom
January 27, 2007, 00:52:08 am »
My 2176 superflow IDA engine also gives that liters pr Km ratio...
Tobi/DFL
January 27, 2007, 09:49:02 am »
I can second that. On the way home from the last Hessisch Oldendorf meeting in 2005 my 2176ccm IDA engine needed about 10-11 litres of Shell´s V-power per 100km while cruising the autobahn with about 100-110km/h.
What it needs when you push the throttle is another story...
January 27, 2007, 14:21:41 pm »
Then it needs a bigger tank!!
January 27, 2007, 15:06:55 pm »
Quote from: Tom G. on January 26, 2007, 23:45:34 pm
what
Bye
Tom
I did some research for you
If you check his last posts you'll see that the first 3 times he gives away his specs he says it had 37mm vents, the last 2 times the vents have shrunk to 36mm
DVK ~
Tom G.
January 31, 2007, 00:02:50 am »
Quote from: 67-indeed on January 27, 2007, 15:06:55 pm
what
Bye
Tom
Yes you are right , but he didn´t tell us or me, what his jet sizes are!!
But thanks for your research
Bye
Tom
Rasser
January 31, 2007, 08:59:02 am »
what
Bye
Tom
yeah and both are right :-) I first build my 1914 with w120 cam using 34mm vents.... next year w130 using 36.... final 2006 season 37mm vents (custom made by a Gribel MIB).
why i mixed it up - I hope i have cleared it up now.
Jetting was 57/160/160 - 37vents (yeah I know it sounds strange with 160/160 - but it was dynoed by a superprof. carb guy, and ran great)
What do you mean by needle valve ?...are you thinking about the emulsion tube ?
Last Edit: January 31, 2007, 09:01:31 am by Rasser DK
1955 type1
richarzzz
January 31, 2007, 13:02:38 pm »
nice vids, so i try to complete this threat with one of mine...
http://www.youtube.com/v/-dFgIjQuVwM
hope you enjoy it
jens
if it's tits or tires, it's gone be trouble
Andi/DFL
January 31, 2007, 21:11:33 pm »
just two vids (sorry for the bad quality) that I used to check youtube:
http://www.youtube.com/v/B0rSomMMFnI
http://www.youtube.com/v/zdQK0Urcj-Y
http://www.dfl-vwclub.de
http://www.flickr.com/photos/andidfl/
http://www.andreasreinhold.com
