October 12, 2026, 20:17:52 pm
| | |-+  CB Performance New Mini Wedge Port
Author Topic: CB Performance New Mini Wedge Port  (Read 30485 times)
airstuff
« on: March 08, 2008, 22:21:59 pm »
Anyone running those,or are these just to new? Smiley
I saw it today on theirs web page.
airstuff
« Reply #1 on: March 20, 2008, 21:11:21 pm »
I think I will take a pair and try out
http://www.cbperformance.com/catalog.asp?ProductID=1704
« Reply #2 on: March 20, 2008, 22:07:57 pm »
The port opening looks like the 2 sets of AJ Sims heads Ive had done. And did you see the chamber volume?? 69cc?! Is that a typo or what?!
« Reply #3 on: March 20, 2008, 22:38:29 pm »
Nope, my cnc wedgeports were the same when I got them.
Bewitched666
Bewitched
« Reply #4 on: March 21, 2008, 08:57:43 am »
Isnt 69cc way to much chamber volume?
Fast vw beetle's rule
airstuff
« Reply #5 on: March 21, 2008, 09:04:46 am »
Can't It just get flycut?
« Reply #6 on: March 21, 2008, 16:43:56 pm »
Yes, but you can only flycut so much. CB told me max flycut for their heads is .140", after that you start running into the fins. And then the valves will start getting awfully close to the pistons...
1915 with .04" (1mm) deck and 69cc chambers give.... 7.3:1 CR!  Roll Eyes
airstuff
« Reply #7 on: March 21, 2008, 17:08:36 pm »
figure it out,if you use zero deck and slightly flycut the heads............ Smiley
I really don't know why they made the chambers so big,the chambers volume is ideal for turbo...hm.....
« Last Edit: March 21, 2008, 17:17:41 pm by cal-look » Logged
« Reply #8 on: March 21, 2008, 17:10:27 pm »
Yeah I was thinking turbo too.
« Reply #9 on: March 21, 2008, 17:14:12 pm »
Turbo what??
« Reply #10 on: March 21, 2008, 17:15:10 pm »
A friend of mine had AJ do his 1914 heads a few years back, and they ended up 60+ cc too.... I ended up having to help my friend out with 94 cylinders I had that were trimmed .040 on top, but heads had been flycut AND still had 60+cc, and fins touched fins, and....
What's the trip with these swimming pool chambers? Only guys that can make use of them are big stroke stuff with long rods and turbo guys it seems.
« Reply #11 on: March 21, 2008, 17:16:55 pm »
Turbo what??
These heads would make decent turbo heads. smaller ports, big chambers, etc.
« Reply #12 on: March 21, 2008, 17:18:01 pm »
Never heard of it. Wink
« Reply #13 on: March 21, 2008, 17:18:46 pm »
DRD has come out with a line of CNC heads. Been looking at a set maybe for my engine. I like the CNC concept of all ports being equal. Price is pretty good too.
« Reply #14 on: March 21, 2008, 17:46:41 pm »
With the CNC thing that CB does, i just don't like the intakes. They just wack all material away around the intake guides. I think the old skool hand job  Wink is the way to go. And yes, like Jim mentioned: swimming pool  chambers anyone? My 2 cts.
« Reply #15 on: March 21, 2008, 18:30:20 pm »
seems to me a head should have quench. Tight deck, quench or you just have big old hole for mixture to go stagnant in.
Big Power
« Reply #16 on: March 21, 2008, 19:44:23 pm »
We can do any one of our CNC chamber's you want in this head. This chamber is close to the ultra wedgeport chamber but can be used with a 90.5 bore. I just finished a 74x94 2054cc engine with these heads. The engine was for a road coarse race car. I used a 5.500 length rod, #2288 cam This is a near clone to an Web 86b, 42x37.5 mini wedgeport heads with the LS-1 springs, 10-1 compression, 1-7/8 merged header and a pair of 48 IDA's with 42mm vents. The engine pulled 170 Ft Lbs. of torque at 5500 rpm and 195 horsepower at 6800 rpm. I'm not sure why someone said that the head can only be flycut to .140 befor you loose a fin. If I remember correctly, I think it's more like .180
« Reply #17 on: March 21, 2008, 19:59:20 pm »
Pat i'm just a home wrencher. What about the lifetime of the head when so much material has been taken away around the guides. And with a 10-1 compression i'm sure it will make that power. But were not all racers.
« Reply #18 on: March 21, 2008, 20:11:57 pm »
That's what CB told me! Roll Eyes
Big Power
« Reply #19 on: March 21, 2008, 21:13:55 pm »
Other than the boss being removed, there is not much material removed around the guide. In fact the floor of the port has just enough material removed so that the CNC will clean up. I was not aware that 10-1 compression was considered race compression. How about this, Today I am running an 7.8-1 compression 2332cc engine for a street car. It has 44 IDF weber carbs, mini wedgeport heads with the standard VW dual spring, #2246 cam, very close to a Engle 130,  stock ratio rockers, 1-5/8 stainless exhaust with muffler. This engine is making 170 Horsepower and 162ft lbs. torque.
ST DRAGN
« Reply #20 on: March 21, 2008, 23:52:23 pm »
I was not aware that 10-1 compression was considered race compression.   Grin
Frank LUX
Back...Soon...hopefully!!!
« Reply #21 on: March 22, 2008, 00:25:05 am »
10-1 is for Nice Street Motors...My opinion is that Race compression starts at 12.5 to 1.... Wink Grin Grin
Frank
« Reply #22 on: March 22, 2008, 12:31:15 pm »
Oh, is that so...
« Last Edit: March 22, 2008, 17:45:37 pm by FDK/Hurry » Logged
drgouk
« Reply #23 on: March 24, 2008, 22:23:16 pm »
Pat, can you buy the mini wedge port heads bare? And what are the cc differences in the different chambers that you offer?
David Gouk
Casey
« Reply #24 on: March 24, 2008, 23:37:57 pm »
I think there are pros and cons to cnc heads. For me I would stick with a hand ported head taylored to the motor.  If I had too I would go with the mini wedge for better air speed. The port is still huge and flows well. I won't even begin to speak my mind on the compression comment! I've been jumped before at the "other" place. Hello again Pat, hope all is well. Casey
airstuff
« Reply #25 on: March 25, 2008, 08:42:20 am »
David Gouk
It would be great if there are those heads with 55 or so cc's.
« Reply #26 on: March 25, 2008, 12:20:57 pm »
I got mine with 57 cc ,
but i bought them second hand from a belgian guy, not directly from cb
drgouk
« Reply #27 on: March 27, 2008, 06:01:55 am »
Pat?
« Reply #28 on: March 27, 2008, 22:23:39 pm »
To me a real advantage of CNC heads is if 1 gets damaged is real easy to replace it with another exactly the same straight of the shelf,unfortunately CB seems to have decided this isnt a good idea,hence there add stating only sold in pairs,seems very strange Huh
airstuff
« Reply #29 on: April 11, 2008, 13:29:04 pm »
they are out of stock  Cheesy
