November 02, 2026, 19:30:09 pm
Con rods
Topic: Con rods (Read 9338 times)
boxertje
Con rods
March 10, 2008, 20:51:48 pm »
Hi guys,can anybody tell me how to mount the Empi chrome moly I beams
The Note that was included with the I beams tells me to mount the notch at the top side(like a standard) But the beam has no notch at all!!! Are the big end and the small end in line?
I'm confused, the note says otherwise.
I also need a good tip to split a case with shuffle pins , I'm mocking up a new engine and split it already several times, it was very difficult so I'm afraid to damage the case.Hope to see some good advise,thanx!
Roman
Re: Con rods
March 10, 2008, 21:44:22 pm »
They have a notch! The bearing notch, just where the bearing halves meet. If they don't have a bearing notch you have a BIG problem...
boxertje
Re: Con rods
March 10, 2008, 22:06:58 pm »
yes,they do have the notches for the bearings.But they dont have the forging on one side like the originals.The note also says to match the sides with the numbers (on the big end)you guess,...no numbers.
Okay,..I know that you mount them with the notches opposite and I mount them on the same way they came out of the box but it confuses me,does Empi always provide incomplete or bad mounting instructions?
Re: Con rods
March 11, 2008, 19:27:02 pm »
Bearing notch Down.
boxertje
Re: Con rods
March 11, 2008, 22:08:37 pm »
thanx !! done
boxertje
Re: Con rods
March 12, 2008, 09:37:48 am »
Somebody good tips on splitting shuffle pin casses?
Rune
SCC Crew
Screwdrivers #7
Re: Con rods
March 12, 2008, 18:46:45 pm »
Case splitter tool?
http://www.vwparts.net/mm5/merchant.mvc?Screen=PROD&Product_Code=LR000121&Store_Code=VWP&search=case+splitter&offset=&filter_cat=&PowerSearch_Begin_Only=&sort=&range_low=&range_high=
Re: Con rods
March 12, 2008, 20:25:29 pm »
Quote from: boxertje on March 12, 2008, 09:37:48 am
On the bottom where the case joins use a flat end screwdriver on top of a stud levering against the fin,slide in the flat of the screwdriver between the fins,you usually need to do this both ends,this will give you enough gap to open it up at the top as well,I usually go between the case right at the top where it doesnt affect the sealing area,cheers richie,uk
Re: Con rods
March 12, 2008, 21:17:38 pm »
Quote from: richie,uk on March 12, 2008, 20:25:29 pm
Perfect, and if that still doesn't work. Heat up the case with your wife's hairdryer and the halfs will part easily. My 2 cts.
Last Edit: March 12, 2008, 21:19:27 pm by FDK/Hurry
boxertje
Re: Con rods
March 12, 2008, 22:25:18 pm »
okay,...thanx!!Hope I dont have to open this case anny more
