October 13, 2026, 10:20:25 am
| | |-+  Your favorite way of removing a wedge mated flywheel.
Author Topic: Your favorite way of removing a wedge mated flywheel.  (Read 20676 times)
« on: March 12, 2008, 15:11:09 pm »
Due to some nasty blue spots i have too get my flywheel skimmed. But I don't really want to split the case. I have heard of guys trying Gene Bergs trick with the rivet gun, without luck, wrong size gun?. I'm thinking about making a wedge mate "puller" out of an old clutch? I have seen one, but I don't remember where?
How do you get them of?
« Reply #1 on: March 12, 2008, 16:51:20 pm »
Ron Lummus sold a wedgemate breaker back in late 90's... not sure if he still does.
I have seen the Berg technique used a few times, no issues those times. I think the bit about using right size driver is important so you don't gouge cavity in crank.
Some non wedge flywheels can be a royal bitch too.
Rune
SCC Crew
Screwdrivers #7
« Reply #2 on: March 12, 2008, 17:51:08 pm »
Jon, Biltema (  Roll Eyes ) has a large brakedrum puller.. I drilled some additional holes in it so it would fit the flywheel... Has worked fine for me.
« Reply #3 on: March 12, 2008, 18:12:51 pm »
And I have made a puller that is a "copy" of the Lummus version. Let me know.
Best rgs
BB
« Last Edit: March 12, 2008, 18:15:34 pm by BeetleBug » Logged
« Reply #4 on: March 12, 2008, 18:16:36 pm »
Rune
SCC Crew
Screwdrivers #7
« Reply #5 on: March 12, 2008, 18:20:10 pm »
Nice looking tool. The biltema version will do the same thing, and look crap while doing it to.. Cheesy  But then again, it costs next to nothing.
It's ofcause a lot bigger than it looks..
« Last Edit: March 12, 2008, 18:24:17 pm by Rune » Logged
« Reply #6 on: March 12, 2008, 22:19:21 pm »
Wow thanks guys, I will look in my wallet and decide what I will do when I get back from the states.
Jim, about the rivet gun, how big and how much force would you say? If there is a way to describe it at all?
« Reply #7 on: March 13, 2008, 00:40:30 am »
Get a friend to use two big screwdrivers to lever behind the flywheel (apply pressure but not enough to damage the case), then put an extension bar from a socket set into the recess in the crank, and hit hard with a BIG hammer once or twice. That works and costs nothing. Smiley
stealth67vw
« Reply #8 on: March 13, 2008, 01:06:22 am »
AC.net rents or sells the RLR puller.
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=TZE0031&cartid=
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
dave greiner
« Reply #9 on: March 18, 2008, 01:13:36 am »
Here is one that I make.
http://www.thesamba.com/vw/classifieds/detail.php?id=335403
« Reply #10 on: March 18, 2008, 06:17:48 am »
Hey Johnny,
If you want one of Dave's pullers, let me know and I'll take you by Dave's shop while you're here.
Rick
Dominick Luppino
« Reply #11 on: March 18, 2008, 15:31:10 pm »
You will like Dave's shop, he is always cleaning it. Grin
« Reply #12 on: March 18, 2008, 22:41:36 pm »
He is always sitting on his ass when i go by there doing nothing Cheesy
Hi Dave Grin
cheers richie,uk
dave greiner
« Reply #13 on: March 22, 2008, 00:59:12 am »
Thanks for the kind words, guys,
« Reply #14 on: March 22, 2008, 03:26:52 am »
alway's!
DKKBRIAN
« Reply #15 on: March 22, 2008, 04:10:20 am »
BE NICE DANNY! BP
DUH..WINNING !
Chuck Fryer
« Reply #16 on: March 22, 2008, 14:31:29 pm »
I made a puller out of an old flywheel. Drill out the clutch mounting holes slighly larger, so an 8mm bolt will go through. This way you can bolt the spare flywheel face to face with the one on your engine. Next you will need a piece of threaded rod or a long threaded bolt. I think I used 1/2", not sure. Then weld a nut washer combo in the center of the flywheel. Now you wiill need that extra long bolt or threaded rod. thread it through and crank it down. Once it is good and tight whack the bolt with a hammer and it will pop loose.
Chuck
