September 23, 2026, 08:21:17 am
| | |-+  Erco and discbrakes
Author Topic: Erco and discbrakes  (Read 7341 times)
GetBackOnTrack
« on: March 13, 2008, 20:49:27 pm »
Anybody in here run discbrakes up front with the erco bubble rims, If you do so, how did you get it to fit inside the rim?
I wanna ad discbrakes, but dont wanna get rid of my erco starcut wheels. Heard something about the wilwood caliber will allmost clear the rim, is that true??
any input would be appreciated...
Regards, Jakob
Check: gbot.dk
deano
« Reply #1 on: March 13, 2008, 23:27:58 pm »
I was over at CMS the other day (who makes Ercos....), and they make an outer half, and an inner half. The inner half has a larger ID-shape to clear most disc brake kits, unlike the old DDS wheel, where the inner and outer were the same. Hope this helps.
Anglia Obsolete Guru
'67 Heaven
Randy Jewell
« Reply #2 on: March 13, 2008, 23:38:10 pm »
I run wide 5 bubble offset erco's and i'm using a CB disc brake kit .
To make this work all i had to do is clearence the caliper slightly .
Andy
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #3 on: March 14, 2008, 01:29:05 am »
had a friend also with ercos and CB kit we had to clearance the caliper also worked fine.
GetBackOnTrack
« Reply #4 on: March 14, 2008, 14:26:40 pm »
Sounds cool, any of you guys has a link to the brake system at CB performance?? Just wanna make sure I get the right set if there happens to be different kits..
Regards, jakob
Check: gbot.dk
dth
« Reply #5 on: March 14, 2008, 17:51:49 pm »
Andy
I got a set of Zero off set Erco,s ,tried them on with CSP discs ,didnt fit ,tried them on Colins silver 54 with CB discs ,no problem ,hence he runs zero offset and i dont Smiley
EL PINGO 66
« Reply #6 on: March 15, 2008, 05:21:08 am »
I PUT A WHEEL SPACER IN MY DISK BRAKES FOR  CLEARENCE THE CALIPPER AND USE A LONG STUDS.. I HAVE AN OG. DISK BRAKES
« Last Edit: March 15, 2008, 20:07:48 pm by EL PINGO 66 » Logged
« Reply #7 on: March 15, 2008, 16:56:07 pm »
Looking good Martin Smiley
EL PINGO 66
« Reply #8 on: March 15, 2008, 20:09:39 pm »
thank´s zach I HAVE A SOME TEKATE BEERS WAITING FOR YOU.... Grin Grin Grin
ballbag
« Reply #9 on: March 15, 2008, 23:03:42 pm »
Regards, Jakob
No help i'm afraid but I love erco stars, do you have any pics of the car?
This is my friends old car Smiley
I would like to know the answer though as i have zero offset centrelines and would like a disc set up  Smiley
something funny!
