November 02, 2026, 20:52:10 pm
| | |-+  Fan shroud
Author Topic: Fan shroud  (Read 11634 times)
airstuff
« on: March 22, 2008, 10:46:56 am »
Is it ok to block the heater outlets like this?I will use this shroud for my motor project.
I am going to have it powdercoated black.
« Reply #1 on: March 22, 2008, 12:04:23 pm »
Jake Raby suggested to drill holes to not disrupt airflow..
thats what i ll be doing
http://www.thesamba.com/vw/forum/viewtopic.php?t=153387
airstuff
« Reply #2 on: March 22, 2008, 12:21:57 pm »
and what about this OEM low profile shrouds sold on Samba?
http://www.thesamba.com/vw/classifieds/detail.php?id=374858
Sam K
« Reply #3 on: March 22, 2008, 15:04:14 pm »
I helped a friend put one of those "low profile" shrouds on a type 3 not too long ago and we were prettty pleased with it. Also, with a little careful grinding, you can remove all of those litle tabs n the front of it.
airstuff
« Reply #4 on: March 25, 2008, 08:53:59 am »
are they worth the money?
Type1/DVK
« Reply #5 on: March 25, 2008, 15:42:00 pm »
I did this yesterday.. Smiley
With heater tabs.
And without! cut and grind, welded it and some bondo, and a slap of paint Smiley
We'll see if it works, i think it is better than a chrome 36hp aftermarket one Wink
airstuff
« Reply #6 on: March 25, 2008, 16:41:19 pm »
it looks nice,sure Cheesy
What engine do you have over there? Smiley
« Last Edit: March 26, 2008, 09:41:12 am by cal-look » Logged
Sam K
« Reply #7 on: March 26, 2008, 03:08:07 am »
I thought so. It wasn't much more than the aftermarket 36 horsepower doghouse type shrouds, plus it's a genuine VW part so the fit and overall quality of it was nice.
NoBars
« Reply #8 on: March 27, 2008, 10:03:48 am »
Looks just like a Thing (Trekker?) shroud, nice work.
I have heard the vanes in the Thing shroud are different, someone should outline the changes so they can be applied to regular doghouse shrouds with the vents blocked off...
Anthony
Scott Novak
« Reply #9 on: March 27, 2008, 16:47:34 pm »
I've got a doghouse Thing fan shroud without the fresh air ducts and the internal vanes look the same as the regular doghouse.  But I'll take a look again tonight to make sure.
Scott Novak
