September 22, 2026, 11:43:07 am
| | |-+  high perf engine post (pics and detail)
Author Topic: high perf engine post (pics and detail)  (Read 15994 times)
« on: March 23, 2008, 17:24:13 pm »
Post one:
Ok guys, this is where I will start the engine post, with pictures and descriptions of what pictures are. First I just wanted to say thanks for the Lounge, and everybody who keeps it up and going, this is the best VW forum around, hands down. Second, thanks to Frank (sheep), Derek (kafercup) and Diederick (67-indeed) for letting me take pics of your hot rod parts, as your stuff comes together. Right now my own stuff is in the car running, and will stay there as long as I can keep it happy.
Reason I wanted to do this was because recently, my father in law and I enrolled in a free instructional class to learn how to fly fish (thanks again to sheep for getting us into f.f. and the equipment Smiley) down here in L.A. It was a 4 week course, and the amount of info these hardcore guys shared with us was amazing....and for free to boot. Real enthusiasts doing what they love to do and having fun sharing their know-how. So I was so impressed I wanted to pass on what I like to do (write and build old VW engines).
Point I want to make: There are a variety of ways to do this engine building thing, and the way I do it isn't the "right way" it is just the way that has worked for me, and I change the way I do it if I learn something new, but basically this way has done the job for me. Hopefully, if you want, the same methods will work for you.
Second point: I often hear people say they want to build the "shortblock" and let it sit and wait while they source the top end stuff to finish the "longblock". I really suggest against building the motor in stages like that. If you cook yourself a hamburger at home, do you grill up the meat until done, then set it aside and go to grocery store to buy the buns and mayo and so on? No, because once you got back to the meat, it would be cold and disgusting. You get that burger together because you've got the stuff to make it. Same thing with making an engine. Don't build "part" of it and then run to store to buy heads or rockers or whatever....make sure you have everything before you bolt motor together.
The first posts will be pictures of tools I use and then all the little junk, distributor end play shims, case washers, cam plug, oil pump nuts, valve adjusters, etc. I will number each post so we can go back and talk about the pics later in another post.
« Reply #1 on: March 23, 2008, 17:29:25 pm »
Post two:
here is where you guys can throw tomatoes at me or ask for pics of me in a dress, whatever....
http://cal-look.no/lounge/index.php/topic,4772.msg67524.html#new
CHR!S/DVK
« Reply #2 on: March 24, 2008, 13:37:00 pm »
Cool! Really looking forward to it Jim  Wink
Member of DVK - Der Vollgas Kreuzers
« Reply #3 on: March 24, 2008, 17:29:34 pm »
This is going to be way cool.
« Reply #4 on: September 14, 2008, 02:06:17 am »
Hi guys, remember this thread? Some slow progress on Sheep's 88 x 74 motor today.
case is finally deburred, larger oil pickup exchanged in for the small one that came with new case, got one 40PII carb stripped and cleaned, checked IDF/PII carbs for where I need to drill and tap them for the Solexes, cleaned crank and made a list of stuff I still need.... stock crank gear (helix), circlip, spacer, distributor pinion....
I'll post some pictures later tonight.... time to eat.
« Reply #5 on: September 14, 2008, 02:14:52 am »
A few pictures of progress
1. one 40PII after a cleaning
2. smoothed and boattailed center main
3. new large pickup swapped into case
4. stack of some of parts; 74mm DPR crank, Rimco rods, V26 Engle, Bosch 010
John Rayburn
« Reply #6 on: September 14, 2008, 05:00:44 am »
Can we see pictures of you in a dress?
I also park at Nick's.
« Reply #7 on: September 14, 2008, 05:59:53 am »
yeah use the "search" function....   Grin
John Rayburn
« Reply #8 on: September 14, 2008, 07:58:53 am »
Found it. Thanks.
« Reply #9 on: September 14, 2008, 15:23:42 pm »
Very nice work on the case.
« Reply #10 on: September 14, 2008, 22:46:43 pm »
Found it. Thanks.
 Cheesy
dth
« Reply #11 on: September 15, 2008, 18:58:39 pm »
Hi Jim ,lookin good on the case there ,can i ask what you mean when you say "boattailed" on the center main?
Cheers Donald
kafercup
« Reply #12 on: December 31, 2009, 19:41:54 pm »
What happened with this thread Jim??   Cool
« Reply #13 on: December 31, 2009, 19:51:02 pm »
He discovered girls...
« Reply #14 on: December 31, 2009, 20:54:21 pm »
yeah have you seen the "how to" post on that?
kafercup
« Reply #15 on: January 01, 2010, 06:10:16 am »
Where??   Does it have pics??  Grin
