October 13, 2026, 05:01:02 am
| | |-+  berg linkage
Author Topic: berg linkage  (Read 7364 times)
« on: March 25, 2008, 21:54:09 pm »
I have a berg linkage   bought in 97 never use/mount on engine and I would have liked to know if this one adapted with all the weber carbs  40/44/48 idf and 48ida Huh thank you to leave you opinion because the person who little will be to take again my linkage to me puts me the question
cheers
fabs
Frank LUX
Back...Soon...hopefully!!!
« Reply #1 on: March 25, 2008, 22:10:44 pm »
The Linkage Itself will work with whatever Carbs you have... Wink
The only difference for IDF/IDA/DRLA Carks is the Linkage Arms.... Wink
You can them Seperate from the Bergs...for little money... Wink
Frank
« Reply #2 on: March 25, 2008, 22:12:37 pm »
and mine frank which one is it Huh
Frank LUX
« Reply #3 on: March 25, 2008, 22:22:47 pm »
Could be for IDF's, the Linkage Arms look kinda Long...
But then again if the Guy you want to sell it to has short IDA Manifolds the Long Linkage Arms could work... Huh
Frank
Roman
« Reply #4 on: March 25, 2008, 22:25:26 pm »
It is hard to tell by the pictures, call Berg and tell them your measurements.
It is missing the lower ball joints and the carb arms, but Berg sells them separate.
« Reply #5 on: March 25, 2008, 22:44:03 pm »
Or better yet, stop by and talk to them when you're out here!
JS
« Reply #6 on: March 25, 2008, 22:49:44 pm »
Could those arms be for IDA/IDF´s on low manifolds?
Signature.
Scott Novak
« Reply #7 on: April 03, 2008, 10:06:53 am »
Those linkage rods look just like mine, which is setup for Weber 40IDFs and the short Berg 580A intake manifolds .
Scott Novak
Kaferdog
« Reply #8 on: May 05, 2008, 05:44:41 am »
I had the same arms and had to cut some off.... worked just fine
