September 22, 2026, 06:16:03 am
| | |-+  do i need a shim between crank and flywheel?
Author Topic: do i need a shim between crank and flywheel?  (Read 8108 times)
« on: March 26, 2008, 00:30:37 am »
hey guys,
i m calculating end float and its maybe stupid, but i dont know if i need a shim between crank and flywheel.
with this shim i mean a shim with 8 holes that slides over the dowels.
i seem to remember that an original engine has one with four holes that sits between flywheel and crank.
thanks guys!!
K-Roc
« Reply #1 on: March 26, 2008, 00:43:46 am »
No shim there.  Just the 3 large ones for your end play.
« Reply #2 on: March 26, 2008, 00:48:46 am »
Thanks dude;
now i can sleep well tonight Cheesy
drgouk
« Reply #3 on: March 26, 2008, 18:30:26 pm »
Does the flywheel have an oring ?
« Reply #4 on: March 27, 2008, 01:34:59 am »
hey guys,
thanks guys!!
Early Model motors used a Paper gasket or metal shim because the flywheel was a non O ring Flywheel If your Flywheel has a grove in it for an O Ring then all you need is the 3 larger shims and a New Flywheel Seal the shims differ in thickness so you need the measure the end play without the shims then determin  what three shims you need to use to get your end play set.
benssp
www.callookvw.com
« Reply #5 on: March 27, 2008, 15:25:58 pm »
Has anyone had the centre main shimmed? saw a tech article in hot vw's last year, think Rimco offer the service using steel backed bearings
www.vwheritage.com  My Job
YMCA
airstuff
« Reply #6 on: March 27, 2008, 20:11:55 pm »
can you scan the article?
« Reply #7 on: March 27, 2008, 20:45:01 pm »
This is for flanshed cranks
« Reply #8 on: March 31, 2008, 16:12:48 pm »
Thanks guys!
its an o ring flywheel
