September 25, 2026, 14:04:15 pm
FOR SALE: 67 Cal-look bug
Topic: FOR SALE: 67 Cal-look bug (Read 16082 times)
mcvw
March 26, 2008, 16:41:35 pm »
Hi,
In order to fund our next bus purchase - and also mostly for reasons of practicality - the bug's gonna have to make way
For those who are interested I can put together a better spec later, but for now...
- Gearbox: stock, 1200 - was serviced/rebuilt by CogBox back in 98/99
- Brakes: stock, but all new parts, pipes, hoses and drums all-round
- Suspension: Bugpack blues on the front, KYB's (I think - if not, stock) on the rear. Beam came with car when I bought it. PO said it was a "Puma" adjustable beam. Pretty sure it's narrowed, but have never measured it.
- Engine: 1776. Jeff Denham heads (40 x 35.5, cc'd, ported & polished, 3-angle valve job - if you know Jeffs work - you'll know how good these are), genuine Okrasa 69mm c/w crank, twin Weber 44 IDF's, match ported manifolds, Berg linkage, Berg breather, Berg bolt-together rockers, Berg elephants feet, fully-flowed case, deep sump, external oil-cooler, Pertronix ignition, ceramic header, Tiger muffler. Engine was assembled by CogBox, and regularly serviced by Ian Clarke (@ WPS).
- Body: dechromed, NOS GT bug black window trim, Talbert Berlin mirrors, Berg shifter, VDO gauges, Haneline door post & headlight bucket trim, all-steel decklid with flared nostrils/eyebrows, NOS rear valance, ERCO's.
As you can see, it's not stock - but could be returned to stock very easily. Simply drill some holes for the trim, raise her front up, fit some indicators on the wing tops, swap the decklid (I also have a matching original style - with the volkswagen script on it) and put some steel wheels on. Or alternatively make her a "sleeper"
You might also want to put a 1200 lump in the back too
Few more pictures here...
http://s179.photobucket.com/albums/w287/mcvwuk/67%20bug/
Best 1/4 mile (from memory) was just under 15 seconds (14.9 summat) at Santa Pod - back in 2001/02 or so. And I'm sure there's more to be had out of this motor
£price is dependant upon how it's sold - i.e. stock or as is. If it's of any use the agreed value for the insurance is £12k. I'm open to offers in stock-form (i.e. I remove all the trick bits) or as is. Our next purchase is going to be a 68 deluxe tintop so if you have one we may consider a px + cash...
Car is located approx 3 miles from Sandown Park - handy if you're at the Volksworld show next weekend. PM me for more details/arrange viewing etc.
Thank you,
Mike
Last Edit: March 26, 2008, 21:30:59 pm by mcvw
71CALRIPPER
Re: FOR SALE: 67 Cal-look bug
March 26, 2008, 17:13:03 pm »
Fook me thats nice , Dude where abouts are you then , i am in Surbiton ?
mcvw
March 26, 2008, 17:41:54 pm »
We're right on the border of Walton-on-Thames and Hersham
KT12 5NS
Prowagen
March 26, 2008, 19:26:59 pm »
Quote from: mcvw on March 26, 2008, 16:41:35 pm
http://s179.photobucket.com/albums/w...vwuk/67%20bug/
Mike your link doesn't work.
Thanks,
Rob.
jmarkha1
March 26, 2008, 19:34:29 pm »
Mike,
shame you have to sell this - lots of history with this car.
hope all is well - Jake.
mcvw
March 26, 2008, 21:35:31 pm »
Prowagen: link to photobucket now fixed. Thanks for that
jmarkha1: Hey there matey! Very long time no see!!! You still on SWT into City? PM me - would be good to catch up
mcvw
March 27, 2008, 22:31:24 pm »
For those who requested... a more detailed spec
1967 Java Green 1200 sedan.
Owned since 1994. Subjected to 99% full resto (except body off) between 94 & 97.
Awarded best Cal-look at Volksworld 1998. Featured in Volksworld Feb 99.
Exterior:
ERCO's (135 Michelin ZX & 205/70 Bridgestone Duellers), Dechromed, WCM rubbers all round, steel eyebrow decklid (have painted original style too), Talbot mirrors, hex T-bars (also have previously fitted buggy bars), OEM GT-bug black window trim, Cibie US spec headlights (Haneline headlight bucket trim)
Interior:
Forumuling France wheel, Berg shifter, Simpson harnesses, VDO gauges (mph, fuel, oil temp, oil press, cyl hd temp), Autometer tach, EMPI dash knobs, EMPI door knobs, EMPI glove-box catch, re-trimmed seats, Dylan Cheasley carpets (OEM rubbers), original floor mats, Haneline A-post covers & sill covers
Engine:
1776, new case (full flow), Berg engine build kit, Berg nut-bolt set, Berg dual oil-pressure kit, Berg oil pump, pump-cover & full-flow kit, deep sump, traction bar, lightened & 8-dowelled flywheel, Kennedy 1700lb pressure plate, genuine Okrasa 69mm c/w crank, Berg achiever pulley, Berg gland nut, balanced VW rods, Mahle barrels & pistons, Berg 300a cam, Berg standard gear, Berg cam followers, Berg cam bearings, Berg push rods/tubes, Jeff Denham heads (40x35.5 - bought new in 1993/4), Berg rockers, Berg swivel feet, Scat manifolds (match ported), Weber 44 IDF's, Berg linkage, 009, Pertronix ignitor & flamethrower coil, ceramic header, Tiger muffler
Misc:
Puma adjustable/narrowed beam, new tie-rods, ball-joints, new m/c, new brake pipes (copper & flexi), new drums (all round), new bearings (all round), stock 1200 g/box serviced & rebuilt by The CogBox
Last Edit: March 31, 2008, 23:38:50 pm by mcvw
mcvw
April 01, 2008, 12:55:07 pm »
Bump, for the updated spec
mcvw
April 02, 2008, 10:52:17 am »
£6500 will get you this fabulous bug
But I get to keep the motor
April 02, 2008, 12:10:55 pm »
did you have buggy bars and fuchs before , when she was featured in vowo
she was one of my favorite at the time
mcvw
April 02, 2008, 13:22:54 pm »
Hi Speedwell,
Thanks for the comments - it's makes your day when people remember your car - especially when it was from nearly 10 years ago
And, yes, you are correct. In the early days (when she was at the Volksworld show and in the mag) she did have buggy bars and early Fuch's.
I still have the buggy bars, and they can still be fitted - although not at the rear as they would foul the Tiger muffler (when they were fitted previously I was running a Berg dual-muffler).
Thanks again
Cheers,
Mike
April 02, 2008, 14:34:11 pm »
mcvw
April 03, 2008, 15:08:46 pm »
Hmmm
Should I remove all the cool bits from the car and sell it as a stocker?
jamiep_jamiep
April 04, 2008, 14:24:10 pm »
Still find myself drooling over your car in Volksworld years after it was featured...
One of my fave ever UK cal look bugs.
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
mcvw
April 04, 2008, 22:44:52 pm »
Kaferboy: Thanks for the kind words
But that's the thing... I still drool over it too... I totally love this car to bits, and I know I'll probably not build another bug to the same spec again... But drooling is as far as it goes. I simply don't get anywhere near enough time to appreciate it
Perhaps I'll put the front buggy-bar back on just for all you droolers out there
mcvw
April 08, 2008, 22:26:19 pm »
Bump! Cos The Mighty blues are through to the semi's!!!!
mcvw
April 14, 2008, 13:54:07 pm »
Anybody with a 68 bay deluxe tintop that wants to do a px...
mcvw
April 19, 2008, 13:54:50 pm »
This engine has only done 7700 miles since it was built... which gives you an idea of how much this car has been used (or not used!) over the past ten years...
Less than 1000 miles a year on a car like this - that's almost a criminal offence
mcvw
April 21, 2008, 10:39:59 am »
This bug is in serious need of some 1/4 mile action!!
Buy it now in time for Big Bang
mcvw
April 28, 2008, 17:01:33 pm »
Should mention that car will be sold with a full years MOT...
Can put stock wheels & o.e.m decklid back on for those that don't like ERCO's (but I can't think who that might be
mcvw
May 21, 2008, 23:30:02 pm »
Have decided the motor is too sweet to part with...
So... get yourself a cool cal-looker - just add the HP and you'll be the new cheshire cat
Offers to the usual address please...
