September 24, 2026, 18:16:07 pm
| | |-+  box ratios.
Author Topic: box ratios.  (Read 10309 times)
67worshipper
« on: April 07, 2008, 22:55:10 pm »
is  a 1.21 4th gear with 3.88 ring and pinion gonna be to revvy for motorway use.im going to run 205/70/15 tyres to try and counteract it. whats the rpm at say 60mph or 90kph gonna be?
vw hot rod heaven
Dougy Dee
« Reply #1 on: April 08, 2008, 01:47:34 am »
My calculator shows:
3000 rpm = 50 mph
3500 rpm = 58
4000 rpm = 67
4500 rpm = 75
Turn the radio up...
67worshipper
« Reply #2 on: April 08, 2008, 14:07:06 pm »
thats what i worked it out to be as well dougy. a bit steep need to keep the revs down. whats everyone elses cruising speed?
vw hot rod heaven
Randy Jewell
« Reply #3 on: April 08, 2008, 20:13:28 pm »
I have the same tyre size,ring and pinion and a 1.21 fourth gear and at 65mph is about 4000 revs
But acceleration is awesome Grin
67worshipper
« Reply #4 on: April 08, 2008, 20:49:41 pm »
do you motorway drive it randy? lookin to drive to avon park and santa pod which is 80 and 160 miles away but unsure of driving it.
vw hot rod heaven
Randy Jewell
« Reply #5 on: April 08, 2008, 21:21:57 pm »
Yep, the bug see's regular motorway use like today as it was nice and sunny.
67worshipper
« Reply #6 on: April 08, 2008, 23:12:34 pm »
whats your cruising speed then randy?
vw hot rod heaven
Peter Roberts
« Reply #7 on: April 09, 2008, 14:21:33 pm »
Randy cruises at 60 mph , I followed him up to the Volksworld show in my Mercedes Sprinter van , that has a pretty acurate speedo .
He brought the car to work today , as the sun is shining , layed rubber right across the car park  Cool
67worshipper
« Reply #8 on: April 09, 2008, 17:46:13 pm »
its not overly stressed then pete at that speed? nice pair there! n i wasnt even lookin down somebodys top! Grin
vw hot rod heaven
Peter Roberts
« Reply #9 on: April 09, 2008, 18:55:18 pm »
No , 60 is about 3500 , seems fine , depends on how much lift you are running , Randy runs 0.585" , if you go over 0.600" I would probably keep it to 3000 RPM .
67worshipper
« Reply #10 on: April 09, 2008, 19:19:44 pm »
im running an fk8 with 1.4 ratio rockers.not sure what the lift is but not as lairy as randys.
vw hot rod heaven
