November 02, 2026, 18:12:25 pm
| | |-+  2276-W125-1.25:1 or W120?
Author Topic: 2276-W125-1.25:1 or W120?  (Read 14353 times)
airstuff
« on: April 12, 2008, 17:27:47 pm »
How fast would I be in the 1/4 mile with the mentioned combo in the stock weight 72. beetle,no interior Grin
At the moment,I have Engle 120,Engle 125 lying around,",waiting for crankshaft which is on it's way
Which of these would be superior street combo,I heard that w125 with 1.25 rockers is close to an fk8 with 1.4 rockers?
I will be using 1.25:1 rockers
In the motor goes 82 crank,5.4 I-beams,lightened flywheel
For the heads as said before I have few choices:
1: New CB Mini Wedge
2:Steve Timms Stage 2
3.DRD L5
It will be topped with 44 IDF carbs for now,later on maybe I'll move to more serious IDA's.
« Last Edit: April 12, 2008, 17:56:00 pm by cal-look » Logged
Bewitched666
Bewitched
« Reply #1 on: April 14, 2008, 09:54:23 am »
With that combo you will run in the 14's i bet.
What kind of gearbox do you run with? 4.37?
Go with the W125 cam and those rockers.
For heads i think all the 3 options are great but i would choose the DRD L5 heads.
Succes dude. Cool
Fast vw beetle's rule
airstuff
« Reply #2 on: April 14, 2008, 10:18:36 am »
Succes dude. Cool
At the moment,I have stock 4.37 gearbox Grin It needs to be rebuild,I need to change synchros and put the Super Diff in or it will go kaboom Grin
I was also searching for the 4.125 gearbox,will see if I can find any.
airstuff
« Reply #3 on: April 14, 2008, 11:27:42 am »
here is a similar engine combo?
http://www2.cal-look.com/members/Bond/Bond.html
anyone else has a combo close to this?
airstuff
« Reply #4 on: April 14, 2008, 18:12:53 pm »
any other cam reccomendations?
jr59
« Reply #5 on: April 17, 2008, 07:54:38 am »
You can also run a web109 with 1.25 works very fine too!
but if you don't have rocker alerady I would go with an FK + 1.4 Wink
Bewitched666
Bewitched
« Reply #6 on: April 17, 2008, 11:50:58 am »
FK8 + 1.4 rockers Grin
jr59
« Reply #7 on: April 17, 2008, 13:25:01 pm »
yes or FK44
airstuff
« Reply #8 on: April 17, 2008, 13:32:37 pm »
guys,don't forget that I only Have I-beam rods Cheesy
jr59
« Reply #9 on: April 17, 2008, 21:08:45 pm »
you don't have to worry with the I beam rods if you have goods one with good ARP bolt,with both cam!!  max power will be around 6000rpm with good heads  so...
we ran a 78mm crank with Gene Berg 191S vw  rods  wich rev around 8000  and 10.7cr  with no PB!!
« Reply #10 on: April 18, 2008, 10:37:29 am »
I don't have any experience of this cam, but Mark Herbert recommended the FK10 to me several years ago for use with stock gears. Of course, I ended up buying a close ratio 'box before I built a motor so ended up with an FK89... Wink
