September 12, 2026, 23:49:46 pm
352304 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  2387 engine with carb issue
Author Topic: 2387 engine with carb issue  (Read 18989 times)
GetBackOnTrack
« on: April 13, 2008, 03:16:10 am »
My new 2387
comp: 13:1
FK89
Comp eliminator heads
51.5 idas
« Last Edit: April 14, 2008, 21:01:06 pm by GetBackOnTrack » Logged
Check: gbot.dk
GetBackOnTrack
« Reply #1 on: April 13, 2008, 18:08:13 pm »
Just started it up today, but have some problems finding the right hight for the float boal. Anybody have any tips to -easy- accomondate the right hight without having to try 10 times back and forth which I allready have been doing without any luck  Sad
By the way the carbs are the reproduced 51,5 idas with a glass ball vent..
Hope somebody can help..
Jakob
Check: gbot.dk
Sander/DVK
« Reply #2 on: April 13, 2008, 22:51:21 pm »
You forgot the ignition wires!  Grin
GetBackOnTrack
« Reply #3 on: April 14, 2008, 21:00:09 pm »
Am I the only one running reproduced 51.5 idas with fucked up float levels??? Come one guys, somebody must have had similar problems. Im just wondering if its the carbs there is something wrong with or it really just is an adjusting issue!
Check: gbot.dk
« Reply #4 on: April 14, 2008, 21:24:12 pm »
No you`re not the only one. What fuel pressure are you running?
GetBackOnTrack
« Reply #5 on: April 14, 2008, 21:52:04 pm »
3.4 psi.
Check: gbot.dk
« Reply #6 on: April 14, 2008, 21:54:38 pm »
3.4 psi.
I had to turn mine down to 1.9 to make them work. 51,5 with glass ball vent, 2386ccm, FK98...
« Last Edit: April 14, 2008, 22:00:05 pm by BeetleBug » Logged
GetBackOnTrack
« Reply #7 on: April 15, 2008, 06:54:20 am »
Interresting beetlebug, im gonna try that next time I get the chance to work a little on the car.
But the funny thing is I put my buddys floater and vent in my carbs, (he has a set of aftermarket 48 ida with steal vent) and the problem was solved.. But I think he wants them back again Tongue
Check: gbot.dk
« Reply #8 on: April 15, 2008, 07:57:50 am »
Probably because of the steal vents?
« Last Edit: April 15, 2008, 08:57:01 am by BeetleBug » Logged
GetBackOnTrack
« Reply #9 on: April 15, 2008, 09:21:43 am »
Maybe because of the steel vent yes, but dont know for sure... Is the glass ball vent normally more sensitive than the steal ones?
Check: gbot.dk
« Reply #10 on: April 15, 2008, 10:05:05 am »
Normally I don`t know but mine sure was. Try with less pressure to see if you experience the same as I did.
benssp
www.callookvw.com
« Reply #11 on: April 15, 2008, 13:24:33 pm »
what crank and case are you running? Grin
www.vwheritage.com  My Job
YMCA
GetBackOnTrack
« Reply #12 on: April 16, 2008, 06:19:48 am »
Il try to turn the pressure down, but do you still have enougf pressure to fill the carbs when you keep your right foot down Cool Beetlebug?
Crank: 86 CB
Case: CB high roof alu case
Jakob
« Last Edit: April 17, 2008, 08:53:15 am by GetBackOnTrack » Logged
Check: gbot.dk
« Reply #13 on: April 16, 2008, 06:39:51 am »
Crank: 86 scat
Jakob
Hi Jakob, volume was no problem, pressure was. Holley blue pump, Holley regulator and 10mm line all the way from the tank to the carbs.
Best rgs
BB
« Reply #14 on: April 16, 2008, 17:35:56 pm »
This picture makes me itch!!!
GetBackOnTrack
« Reply #15 on: April 17, 2008, 20:32:45 pm »
So, I got the problem fixed I think Undecided Bend the little thing on the floater back and forth a couple of times and came up with a setting that worked out.But how can I be sure that the chamber is full when the glass ball vent close for the flow? So that I will not run out off gaz when I put the pedal to the metal Cool
Jakob
Check: gbot.dk
