October 13, 2026, 16:03:00 pm
| | |-+  67-Indeed's 48IDA's probzz
Author Topic: 67-Indeed's 48IDA's probzz  (Read 16576 times)
Type1/DVK
« on: April 14, 2008, 20:53:38 pm »
Diederick presented me his IDA's for ultrasonic cleaning, prior to this i had a inspection at the main shaft and butterfly valves.
This here below isn't.. good at all.., To me the valves should close álmost to the body, only a few mm of gap should be there for creating a progression vacuum.
This is the situ in ONE IDA:  (bent main shaft)
Not so good to me..
The pivot arm is fully in back position, the upper area is touching the body, below it isn't! and to make it
worse, different gaps..   grr..
Are IDA butterfly valves always angled?
And a bent main shaft... also...
What do the carb-'pro's' say? driveable?  Huh Shocked
« Reply #1 on: April 14, 2008, 21:32:10 pm »
somebody probably tried tightening shaft nuts (on nut left from mixture screw) without idle speed stop and screw in place, in turn using the butterflies as the "stops" bad bad bad.... they're soft brass. Not only are these bent but the shafts are most likely twisted too....  I tell guys, CHECK THE BUTTERFLIES against the throats with feeler gauge!!!!!
Yikes,
I have never been brave enough to mess with butterflies and those screws that hold them to shafts.  Shocked
« Reply #2 on: April 14, 2008, 21:43:04 pm »
He'll need these part #'s
1005.426 (throttle shaft) x 2 (if both are tweaked)
64005.091 (butterfly) x 4 (if all are bent)
64570.009 (butterfly screws) x 8 (never re-use)
41570.001 (bearing dust boot) x 4 (need to be replaced when servicing shafts and bearings)
55520.004 (shaft lock washers) x 4 (never re-use)
41705.021 (carb cover gaskets) x 2 ( in case his rip or are shrunk)
Try here for parts: http://www.piercemanifolds.com/products.htm
Type1/DVK
« Reply #3 on: April 14, 2008, 22:10:34 pm »
Jep, those are the parts, i had a call with died this evening.. he was at the pub Wink drinking away the problems  Wink Grin (lolz)
I had first hand experience with bent throttleshafts and broken screws etc. it's a hell of a job if you want to do it correctly. Even the weber book doesn't recommend it!
Dellorto.co.uk also has the parts i think.. Matt helped me with my IDF's.
Good luck Died! let me know what you want me to do..
« Reply #4 on: April 15, 2008, 00:24:19 am »
Not so good to me..
Send them to Jaycee make 51's out of them  or check with Jack at Jaycee he has a ton of takeoff parts for IDA's
« Reply #5 on: April 15, 2008, 00:31:46 am »
that's another way to fix them, but 51's are going to be too big for his 1914cc.... I guess he could sell them after having them poked for 51mm...
The Ideaman
« Reply #6 on: April 15, 2008, 01:53:44 am »
Steve Hollingsworth has bushed a few of mine with a brass bushing.  No need to open them to 51.5mm.  Then replace the throttle shafts and butterflies.
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
« Reply #7 on: April 15, 2008, 04:30:53 am »
he replaced the bearings?  Huh
The Ideaman
« Reply #8 on: April 15, 2008, 04:51:16 am »
Replace bearings on outers and bush the center two.  Seems over time, they wear and leak vacuum. Mine were so bad that at full throttle the pump shooters would squirt fuel down the throats of the carbs.  Bushings and new shafts fixed it.
« Last Edit: April 15, 2008, 15:52:27 pm by The Ideaman » Logged
It is the soldier,
« Reply #9 on: April 15, 2008, 15:44:51 pm »
Finally found the topic Wink
Sounds like a shitty problem! What's the best solution now...
« Reply #10 on: April 15, 2008, 19:28:45 pm »
Check with Jack at Jaycee He has a ton of takeoff parts because he makes them in to 51's so all the stock stuff is not used give him a call he can fix them easy.
Bewitched666
Bewitched
« Reply #11 on: April 16, 2008, 12:02:03 pm »
Wont be cheap,better to sell them as they are
Fast vw beetle's rule
« Reply #12 on: April 16, 2008, 15:10:37 pm »
well, i dunno why it would be better to sell "them"...
as far as i'm concerned i'll decide when i get a price quote for the parts needed...
martijn, is it K9 or L9 we're talking about?
Type1/DVK
« Reply #13 on: April 16, 2008, 15:42:31 pm »
I got to have a look wich is the worse..
The throttleplates are bent with all 4.
Quote
4x New Bearings!
I think you are done with this!
« Last Edit: April 16, 2008, 15:44:07 pm by Type1/DVK » Logged
« Reply #14 on: April 16, 2008, 16:20:58 pm »
Bent on all 4?
You mean both carbs are f*cked?
So, you need to replace all of em?
« Reply #15 on: April 16, 2008, 16:34:36 pm »
oh no.  Sad
« Reply #16 on: April 16, 2008, 16:36:27 pm »
Died, have a talk with the guys from ABC tuning. Maybe they can help.
Bewitched666
Bewitched
« Reply #17 on: April 17, 2008, 11:53:16 am »
Yeps,try ABC tuning.
Man thats the hassle of buying stuff on the internet,you never know what you will get.
Goodluck Died Cool
Type1/DVK
« Reply #18 on: April 17, 2008, 15:23:17 pm »
Goodluck Died Cool
Spot on!
« Reply #19 on: April 17, 2008, 19:17:36 pm »
Goodluck Died Cool
Spot on!
If its USED Angry
« Reply #20 on: April 17, 2008, 21:23:53 pm »
yeah, well i suppose unused italians are well outta my league...
« Reply #21 on: April 17, 2008, 21:25:39 pm »
Art Thraen might be able to help too!
