November 03, 2026, 03:11:10 am
| | |-+  Nitrous Oxide and Cal-Looks...
Pages: 1 [2] 3 Print
Author Topic: Nitrous Oxide and Cal-Looks...  (Read 38538 times)
Frank LUX
Back...Soon...hopefully!!!
« Reply #30 on: October 25, 2006, 21:34:42 pm »
Here's a picture of the NOS Controller....
Frank
Frank LUX
« Reply #31 on: October 25, 2006, 21:38:39 pm »
Here it is in the car...
Frank
Frank LUX
« Reply #32 on: October 25, 2006, 21:40:04 pm »
Here is my my Fuel Set-up for the Nitrous...
Frank
Frank LUX
« Reply #33 on: October 25, 2006, 21:45:47 pm »
This is something I'm working on...
It's an adapter for the NOS activation Button that goes on the Empi GT Wheel, as i don't want to drill holes in my Sterring Wheel!!!
It'll be hold on the Wheel by two little lips on the adapterplate and one little screw that will go thrue the original Opening in the spoke of the Wheel...
Frank
« Reply #34 on: October 25, 2006, 21:54:44 pm »
That's a slick piece to put the NOS button on the wheel.
Frank LUX
« Reply #35 on: October 25, 2006, 22:33:33 pm »
Thanxs Rick... Wink
Frank
« Reply #36 on: October 26, 2006, 07:50:27 am »
Looking good Frank!
Me too have the NOS button on the steering using a self made adapter quite similar to yours (thanks to Tekken for the nice looking piece) I liked the idea to have a button instead of a trigger down at the pedal or around one of the carbs. I have the flat4 copy of your steering wheel.
I installed the solenoids on top of the fan house and I have mounted the nozzles on the inside of the manifolds using flexible wires from the solenoids. I drilled the jets on the nozzle side to oversize (1mm) and I change jets on the solenoid side instead. This way I only change 2 jets instead of 8 down at the manifolds.
Best rgs
Frank LUX
« Reply #37 on: October 27, 2006, 17:43:33 pm »
Looking good Frank!
Best rgs
Hi Beetlebug,
Do have more Pics of your NOS Set-up?
What Nozzles are you Using there, or are they simply Polished?
Frank
« Reply #38 on: October 27, 2006, 20:56:51 pm »
Hi,
I`m crazy but I`m not that crazy that I would polish my nitrous nozzles  Smiley
They are the annular discharge stainless straight spray ones from NOS. I do have some more picks, I just need to find them. Is it anything special you want to see a picture of? It is a very simple set up but it works.
On this year engine my manifolds are heavily welded but there is still room for them on the inside.
Best rgs
Frank LUX
« Reply #39 on: February 25, 2008, 18:34:46 pm »
Any More Opinions on this subject... Wink
Please Post Pictures of your Own Nitrous Installations... Wink
Frank
« Last Edit: February 25, 2008, 18:36:55 pm by Frank LUX » Logged
« Reply #40 on: February 25, 2008, 18:43:46 pm »
Frank
Shit, I totally forgot. I will see if I can find some of mine set up. You can aslo check out Roars set up here; www.nitrousbeetle.com His engine is really nice and pushes his race car over the line in 10 something. If I remember correctly it dynoed 253 without the NOS and then he added around 135hp. You can find all the info you need on his page.
Look forward to the first time you push the button.. I did the happy happy dance outside first time I pushed it and people thought I was loosing it  Smiley
Frank LUX
« Reply #41 on: February 25, 2008, 18:48:16 pm »
Frank
Thanxs for the Infos Dude,
Looks there is little interest on the Subject.....exept for us... Wink
Frank
Ivan
« Reply #42 on: February 25, 2008, 18:51:45 pm »
back in 1995 I put my line-loc button on a similar piece of ally mounted on my steering wheel in the correct location for my right hand thumb - it works really well. a lot of non-VW people ask what it's for, and the easiest way to explain is to show them... Wink
thehanz DVK
« Reply #43 on: February 25, 2008, 19:02:21 pm »
hee frank
i am also in the process off getting a complete system and i am looking what to buy at this moment my toughts where the wet system and the didital processor also, but i see you are also running a complete extra fuel system is that correct ??
Frank LUX
« Reply #44 on: February 25, 2008, 19:04:16 pm »
hee frank
Yes it is, and probably the only way to do correctly... Wink
Frank
« Reply #45 on: February 25, 2008, 19:16:32 pm »
hee frank
Frank
First year I used one pump, one 8mm line, 8mm outlet from the original tank and two regulators - worked fine and nothing bad happened. But I only had a 40hp shot. I did not retard the ignition and I did have a fuel pressure drop. Lucky? Perhaps. I did install two pumps and one extra 10mm line the year after - no problems. If you have a effective pump, big enough fuel line I do believe you can get away with a singel system up to a certain level.
I used Holley blue and their crappy regulators but I will never buy that pump and regulator again. Noisy and cheap looking both the pump and the regulator. I do like their new black series though but have not tried them.
I would love to see a VW with a real professional system with 2,3 or 4 stages and one hell of a shot.
Best rgs
BB
« Last Edit: February 25, 2008, 19:35:37 pm by BeetleBug » Logged
autobarnhauler
« Reply #46 on: February 25, 2008, 19:19:10 pm »
nice one,! lob it on Cool Cool
GWB, founder member
.... there and back again, a rocket buses tail....
NAO
« Reply #47 on: February 26, 2008, 07:46:32 am »
Nitrous...it is fun to work with as long as you stay on safe side.
I also use a separate gas tank for the Nitrous and I run BOSCH fuel pump for the injection with regulater(with fuel return bypass).
Many said keep the fuel pressure as 6psi for nitrous....or so but since I use injection pump, I run with 47psi !!!(Fuel jet size #16)  and my current Nitrous jet size in #28
Also use MSD multi retard system, so every time I squeeze it timing will retard 4degree.
So far, no problem on this set up. Roll Eyes
team97
3M TA3
« Reply #48 on: February 26, 2008, 17:26:22 pm »
What do you Guys think?
Is Nitrous part of the Cal-Look or is it a No No...
Frank
Nitrous is IT. Do it the man way, (NO TIMING RETARD, NO FULL THROTTLE MICRO SWITCH,) just like Mason, grab a handfull and GO
Der Kleiner Panzers III
D.K.K.
Frank LUX
« Reply #49 on: February 26, 2008, 17:43:06 pm »
Frank
Thanxs for the Pictures... Wink
How much Nitrous do you inject???
Would love to see Dave Mason around here on the Lounge Wink!!!
Frank
team97
3M TA3
« Reply #50 on: February 26, 2008, 17:50:37 pm »
Frank
Frank
I think it's a #24 or 22 jet in the nitrous and a #26 on the fuel. I've got a Holley fuel pump and a separate -8 hard line for the nitrous. It's been a long time since I've messed with the jetting, but it runs strong. I've been bugging Dave to come on here, I usually see him on Saturday mornings at Cars and Coffe in Irvine. I'll bug him again. Glenn
D.K.K.
Frank LUX
« Reply #51 on: February 26, 2008, 18:00:31 pm »
Sounds great...Get him overhere!!! Wink
What is your best ET so far..Huh
Frank
« Reply #52 on: February 26, 2008, 18:54:16 pm »
I like your attitude - look at pauter-tom here on the Lounge (http://www.bugwahn-dragracing.de/ ). If I remember correctly he used a 200hp shot without any kind of retard or controller. That got to be on hell of kick!
Here is a question to you; why do you change jets at the nozzle end forcing you to change more jets compared to what you could get away with if you changed it at the solenoid end. By doing this you only change two jets and it takes 10 minutes. I drilled my nozzle side jets to a oversize (1,5mm) and used one 34 and one 32 jet.
Best rgs
BB
« Reply #53 on: February 26, 2008, 19:29:25 pm »
Frank
I didn't know you were squeezing!
« Reply #54 on: February 26, 2008, 19:30:20 pm »
Frank
Frank
I didn't think that he even had a cornputer...  Grin Grin Grin
Frank LUX
« Reply #55 on: February 26, 2008, 20:31:25 pm »
Go get Dave Mason a Computer then... Wink Grin Grin
Frank
Frank LUX
« Reply #56 on: February 26, 2008, 20:33:36 pm »
I did not get something there, you running 47 PSI Fuel pressure on the Nitrous Side???
Frank
NAO
« Reply #57 on: February 27, 2008, 03:16:57 am »
Fuel for the Nitrous come from separate fuel tank @ 47psi,  Nitrous pressure @950  Roll Eyes
Ntrous jet#28 Fuel#16
Squeeze on 3rd and 4th only made 12.17@112.6mph
« Reply #58 on: February 27, 2008, 05:45:25 am »
Frank
Frank,its just like on an EFI car Wink  and a more consistent fuel pressure is the bonus Cheesy
cheers richie,uk
« Reply #59 on: February 29, 2008, 22:19:37 pm »
I took this pictures at Euro bug in. I forget the name of the owner of the car and I'm sure he's on the lounge (Sorry  Roll Eyes), but that's the one which receive the price for best cal look. A VW from the DFL.
Take a look how the Nos buttons is mounted.
« Last Edit: February 29, 2008, 22:21:57 pm by j-f » Logged
