October 13, 2026, 04:38:15 am
| | |-+  welded (as in repaired) ali cases
Author Topic: welded (as in repaired) ali cases  (Read 6502 times)
Rocket Ron
It's old school for a reason
« on: April 19, 2008, 17:09:31 pm »
Hi guys
Would you use a ali case with a crack that's been repaired by welding to the area around the full flow oil return for a hi power engine ?
Ron
13.12 @ 101.84
Grooving out on life
benssp
www.callookvw.com
« Reply #1 on: April 21, 2008, 14:53:22 pm »
I've used a Mag case which had to be repaired after the machinist got a bit carried away with the mill with no problems, JB weld should sort it out Grin
www.vwheritage.com  My Job
YMCA
ugly duckling
« Reply #2 on: April 24, 2008, 05:42:24 am »
run it. just as long it was welded properly. thats what is nice about aluim cases they are very weld freindly. UD.
« Reply #3 on: April 24, 2008, 09:48:07 am »
As long as it can withstand the oil pressure you will be fine using it.
Rocket Ron
« Reply #4 on: April 24, 2008, 11:46:41 am »
Thanks guy for the reply but LikeI may be sorted for an engine now so dont have to worry about this now
Nice to know you can use a welded case  Wink
Regards Ron
13.12 @ 101.84
