October 13, 2026, 06:49:53 am
welded (as in repaired) ali cases
Topic: welded (as in repaired) ali cases (Read 6504 times)
Rocket Ron
It's old school for a reason
April 19, 2008, 17:09:31 pm »
Hi guys
Would you use a ali case with a crack that's been repaired by welding to the area around the full flow oil return for a hi power engine ?
Ron
13.12 @ 101.84
Grooving out on life
benssp
www.callookvw.com
Re: welded (as in repaired) ali cases
April 21, 2008, 14:53:22 pm »
I've used a Mag case which had to be repaired after the machinist got a bit carried away with the mill with no problems, JB weld should sort it out
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
ugly duckling
April 24, 2008, 05:42:24 am »
run it. just as long it was welded properly. thats what is nice about aluim cases they are very weld freindly. UD.
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
April 24, 2008, 09:48:07 am »
As long as it can withstand the oil pressure you will be fine using it.
Rocket Ron
April 24, 2008, 11:46:41 am »
Thanks guy for the reply but LikeI may be sorted for an engine now so dont have to worry about this now
Nice to know you can use a welded case
Regards Ron
13.12 @ 101.84
