June 10, 2026, 07:16:44 am
mvptkfjb
Cam choice
Topic: Cam choice (Read 12814 times)
Sander/DVK
Cam choice
April 20, 2008, 11:24:07 am »
I have te split my case , and I thinking about to switch the W110 cam for a FK cam.
What do you guys recomend? FK7, FK8 or something else.
The engine specs are 1776cc with ported heads, and 40x35,5 valves.
Edit, the engine is for street use.
Sander
Last Edit: April 20, 2008, 11:25:46 am by Sander/DVK
John Rayburn
Re: Cam choice
April 20, 2008, 17:45:16 pm »
It all depends on your headwork. How extensive the work and who performed it. Also, your compression should factor in to the equation.
I also park at Nick's.
Sander/DVK
Re: Cam choice
April 21, 2008, 18:15:09 pm »
Thanks, than I have an another question. What cam would you buy, and what kind of heads for an 1776cc?
Cheers.
John Rayburn
Re: Cam choice
April 21, 2008, 22:33:13 pm »
I'd run a set of Jeff Denham non welded 041 heads with a 42 or 44 intake and a W 130 with 1:25 rockers or an FK8. If you went with Jeffs heads, you should tell him which cam you will be using so he can set you up with what you need. Good luck with your combo!!
Re: Cam choice
April 22, 2008, 01:51:39 am »
Quote from: Sander/DVK on April 20, 2008, 11:24:07 am
Sander
Are you going to buy ratio rockers or stick with standard?assuming you have 1.1/1s right now?
cheers richi,uk
Sander/DVK
Re: Cam choice
April 22, 2008, 06:53:41 am »
Hi Richie, I have now 1:1 rockers on my w110 cam, but I have also a set of 1:4 rockers, that I will use with another cam.
Bewitched666
Bewitched
Re: Cam choice
April 22, 2008, 07:26:35 am »
Sander go with a FK8 cam with the 1.4 rockers
otherwise for street i would buy a w120.For daily street use maybe the FK8 cam will be to radical but all depends on what you want with the engine.
For street i always used the w120 cam with great result.
Suc6 dude
Fast vw beetle's rule
Re: Cam choice
April 22, 2008, 16:38:49 pm »
With 1.4s i would go with a fK43,maybe a FK8 but I think the 43 would be much more drivable,chers richie,uk
Bewitched666
Bewitched
Re: Cam choice
April 23, 2008, 11:41:31 am »
x2
Re: Cam choice
April 23, 2008, 19:18:05 pm »
depends on which carburetors too
JeePee/DVK
Re: Cam choice
April 23, 2008, 19:24:35 pm »
Let me do:ienemienemute?
Bewitched666
Bewitched
Re: Cam choice
April 23, 2008, 20:22:57 pm »
Think Sander has 40mm carbs Jim
Sander/DVK
Re: Cam choice
April 23, 2008, 22:37:42 pm »
I have 36ers with 30 vents, but I think I would go for the W120. The FK43 is for large displacement, and I have only 1776cc
Thanks for thinking with me guys, I appreciated that!
Cheers,
Sander
Re: Cam choice
April 23, 2008, 23:11:02 pm »
Quote from: Sander/DVK on April 23, 2008, 22:37:42 pm
Cheers,
Sander
Hi Sander, sounds like fun. However, I see your carbs as kind of limiting the powerband and going too radical on the cam. The ideal vent diameter for your size motor needs to be 32-34mm to spin up to 6000. I think the Engle 110 will actually be a good cam for you in this case.
Bewitched666
Bewitched
Re: Cam choice
April 24, 2008, 07:15:07 am »
Or buy bought the cam(w120) and 40mm carbs
