August 12, 2026, 15:29:47 pm
The perfect Cal-look tire combo?
Topic: The perfect Cal-look tire combo? (Read 48788 times)
Re: The perfect Cal-look tire combo?
Reply #30 on:
April 27, 2008, 15:42:34 pm »
Don't seem that expensive to me
DVK ~
Reply #31 on:
April 27, 2008, 16:50:12 pm »
The 155s are not too pricey, but the larger sizes start getting expensive.
Reply #32 on:
April 27, 2008, 16:55:57 pm »
mmh, just checked and the 185s are around 88 EUR
and you're right about the 205s, those are pretty hard to find too.
DVK ~
Reply #33 on:
April 27, 2008, 17:57:37 pm »
i don't know why i saw those 185 vredestein more expensive than 88€
Gaz1
Reply #34 on:
April 27, 2008, 18:51:09 pm »
145XZX's and 185XWX ,nice combo i think
Reply #35 on:
April 27, 2008, 18:54:29 pm »
Quote from: speedwell on April 27, 2008, 17:57:37 pm
the shop of my link is pretty cheap! and you can get the tyres delivered to quite a few tyre shops in any area, get them mounted there and go for a drive. pretty cool huh?
DVK ~
Reply #36 on:
April 28, 2008, 07:15:38 am »
OK and what does look good on a type3... i am not a fan of the small and big combo on a type3, but a little difference is accepted. think early porsche.
now i run 165/65.15 up front and 165/15 at the back. i was thinking about a little bigger tire. 155 front and 185/70 back, but i am not sure about clearance...
Reply #37 on:
April 28, 2008, 17:36:18 pm »
Quote from: Gaz1 on April 27, 2008, 18:51:09 pm
Coming soon to my GTV
Gaz1
Reply #38 on:
April 28, 2008, 19:14:35 pm »
Good choice
donder
Reply #39 on:
April 28, 2008, 19:31:09 pm »
Quote from: nicolas on April 28, 2008, 07:15:38 am
Your front tires look oké, but those 165/80's at the rear just are to narrow to be at the rear. I reckon a 185/70 or even a 195/70 would sort that problem out without giving it too much big'n little tire combo ( i thought that wider than a 195 isn't possible on a type3 with stock axles due to clearance probs or you could mount short beetle axle's like on wim's type 3 notch).
if i where you, i would n't mount a tire any higher than the 168/80's you have now, but just mount a tire that has the same heigth but wider.
I really like you're car, but the rear tires just don't do it for me. And soon with you're new power plant you're car has to have the right attitude.
Last Edit: April 28, 2008, 19:37:37 pm by donder
Reply #40 on:
April 28, 2008, 19:48:54 pm »
yeah the rears are a bit skinny, but in a previous post all the 'old guys' were running 165's as well and with quite good results. i want something bigger but nothing that rubs or looks too fat. i like skinny... but maybe a little more tracktion wont hurt... someting like a 185/70
i have had a 185/80 on the square and got good milage, but those looked a little wrong... i still regret getting rid of those tires. they were a special high velocity tire forn the 70's ( i think for a benz)
donder
Reply #41 on:
April 28, 2008, 20:06:25 pm »
maybe a 185/70 is then the correct size of tire for your car. not as high as a 185/80 and still a bit fatter than the 165/80's. If you can still find some 185/70's offcourse....
off topic:
tell us something more 'bout the square...
Reply #42 on:
April 28, 2008, 20:15:51 pm »
still offtpic: it's a 67 square which i have for 4 or 5 years now and that i basically fel in love with at first sight and that was a good idea at the time because the fastback was completely taken appart and i didn't know how to put it back together again...
true story.
i was looking for some bottom moldingstrims for the fastback and saw the advert.
went to look and saw this beauty. it has been repainted (still not good enough...) to VW blue again and it has a lightgrey interiour with black carpets for now. it should be made back to a good second car for the family. but it needs a new pan (that i have already powdercoated) and a lot of love and attention. but it is a sound car with good panels and a pretty clean interiour. but this year i want to finish the fastback and afterwards i wil get the square on the road again. the engine that i used for the bugtour is actually the one out of the squareback. i will try to scan some pics that i have later this week...
thanks for your interest
Reply #43 on:
April 28, 2008, 20:21:20 pm »
I wonder about the ride and handling characteristics of Pirelli CN36 vs Michelin XWX, on a VW beetle. the XWX was o.e. on heavy, high horsepower GT cars of the 1970's.... i.e. Ferrari 365GTB, Maserati Bora, the pre-flare Lamborghini Countach Lp400. The CN36's were, I believe, used on smaller, lighter sporting model and GT cars, i.e. Carrera 911, Lancia HF, and the sort. I wonder if the sidewall characteristics of the big XWX is too stiff for the light weight VW?
One thing is for certain, the XWX is truly a gorgeous tire. On a 1970's Italian supercar, nothing can really substitute... but i am getting waaaay off topic here.
Some interesting reading in an old book I have about hot rodding 356's for slalom, circuit, autocross. Now if i could find the book.....
Reply #44 on:
April 28, 2008, 22:08:56 pm »
Quote from: donder on April 28, 2008, 19:31:09 pm
( i thought that wider than a 195 isn't possible on a type3 with stock axles due to clearance probs..
I fit 205/70's on my Fastback with long axles and stock t3 4 lug brakes, you just need 5.5" 914 wheels and it all works
Reply #45 on:
April 29, 2008, 07:11:42 am »
Quote from: Zach Gomulka on April 28, 2008, 22:08:56 pm
yep thos tuck in nicely, but i am planning on keepin my 8 spokes, i have a little less play.
Reply #46 on:
April 29, 2008, 10:12:30 am »
Just a little tyre porn....
ESH
Reply #47 on:
April 29, 2008, 10:15:42 am »
Quote from: JHU on April 29, 2008, 10:12:30 am
In fairness the car's not too bad either.
Reply #48 on:
April 29, 2008, 11:34:24 am »
Quote from: Mat Sanchez on April 29, 2008, 10:15:42 am
mmm, not that shaby, it has a callook feel to it.
Reply #49 on:
April 29, 2008, 18:09:20 pm »
Quote from: nicolas on April 29, 2008, 07:11:42 am
True... backspace on the 8's is 4 3/8", and on the 914 wheels it is 4 3/4" (I think? I'll check tonight), not much, but enough to make a difference. I had to roll the inside of the fender lips to get my 205/70's to fit.
If I was in your shoes, I would install short axles, disc brakes, and put 185/70's on those 8 spokes
Reply #50 on:
April 29, 2008, 18:29:11 pm »
uuuaaaaaahhhhhh
Borrani Wire Wheels... I think I need a cigarette,
Reply #51 on:
April 29, 2008, 20:44:48 pm »
i like these:
Reply #52 on:
April 30, 2008, 07:38:28 am »
yeah i have been looking at 185/70's and those look good indeed. but discs are not an option... Belgian law forbids changes on the car. i could try but if they find out i need to bring it back to stock... so i will stick with dums i guess. and find some short axles.
thanks
btw Lids: those wheels rock, but i would run them on an early car... like sprintstars.
Reply #53 on:
April 30, 2008, 17:38:35 pm »
Quote from: nicolas on April 30, 2008, 07:38:28 am
thanks
Belgian law forbids improving the safety of your car
That settles it, I'm never moving to Belgium
Reply #54 on:
April 30, 2008, 19:34:20 pm »
yep it is forbidden. i think we have some of the stupidst laws regarding carregulations here.
here is another one. all tires must be the same size. BUT you could get away with a 145 all round; or 185 allround, but not combined... it is all just small stupid stuff. basicly everything you change on an original car (mechanicly or bodywise) is forbidden.
and if you would consider moving here in the future, when you learn about all the beautifull things about Belgium, bring raingear.
what was this topic about again? sorry dudes.
still my favorite tire combo on a bug 155 front and 185 back
Frank LUX
Back...Soon...hopefully!!!
Reply #55 on:
April 30, 2008, 19:51:29 pm »
Quote from: nicolas on April 30, 2008, 19:34:20 pm
Nicolas,
You have never been to Luxembourg, I'm not even alloewd to drive my Car on the Streets....Belgium is pretty Cool for Me...
Frank
Reply #56 on:
April 30, 2008, 19:59:52 pm »
yes that is true. it is even worse in luxemburg. everything that is not factory options is illegal there, right?
but some cool cars have some luxemburg licenseplates on our roads...
Reply #57 on:
May 01, 2008, 03:46:39 am »
Hey nicolas, I don't know were you are at but in california at one time if you got a ticket for something wrong with a modification to your car we would fix it, and go to the local police dept. and have ticket signed off. an then go home and put the car back to the way it was. can changeing tire combo to legal set-up for your country's law's then put it back to cal-look?
Reply #58 on:
May 01, 2008, 08:33:15 am »
that is what we do. i went with two stock wheels with 165's on the front and my two 8 spokes on the back with 165's and i told them the tires were the same. they bought it and let me go. once home i put my other 8 spokes on the car. it is sometimes a bit stupid what may or may not be done. but i can understand there way of thinking. especially when i look at some cars (i think you call them imports, Japanese cars) and see what stupid and and unsafe things happen with those.
qubek
Reply #59 on:
May 01, 2008, 11:32:01 am »
Their way of thinking is to forbid everything, so there is no difference between 'safe modifications' and 'unsafe modifications'. The result is that when you change something in your car, you brake the law anyway, so you don't care whether it's safe or not (from legal point of view). By forbidding all modifications, all they achieved is that they lost control over what people do to their cars, because everything went underground. This law is stupid and dangerous.
I really hope our legislation won't go that way.
Last Edit: May 01, 2008, 11:33:40 am by qubek
