November 02, 2026, 18:13:13 pm
| | |-+  Oil sump
Pages: [1] 2 Print
Author Topic: Oil sump  (Read 34352 times)
airstuff
« on: April 25, 2008, 16:10:51 pm »
How big oil sump do I need for a 2276cc street driven engine?
I like the looks of Scat and CB sumps.
Is 1 .5 quart enough?
« Reply #1 on: April 25, 2008, 17:16:32 pm »
Oil pump size,RPM and ground clearance are my considerations,i use the Scat 2 quart right now,but also am putting something together with a 3.5 quart
empi sump which actually gives more clearance,the only pain with the cb sump is it uses a different size gasket on the bottom plate which is available everywhere
cheers richie,uk
Sam K
« Reply #2 on: April 26, 2008, 03:12:37 am »
I've always figured that more oil = better. I've had a berg 3.5 quart on my car for several years along with a system 1 filter and a huge cooler with a fan. It takes nealry  8 quarts to fill my oil sysem when it's dry. Grin  I'm not a big fan of the CB sump because I still use the stock oil strainer as well.
airstuff
« Reply #3 on: April 26, 2008, 12:56:20 pm »
26mm oil pump and revving not past 7500 rpm.More closely to 7000
« Reply #4 on: April 26, 2008, 16:10:01 pm »
I ve got a 3.5 quart too..
i will have a similar engine like you..
also 26 mm pump
« Reply #5 on: April 26, 2008, 17:20:32 pm »
At that RPM at least the 2 quart,proberly go 3.5
cheers richie,uk
« Reply #6 on: April 26, 2008, 17:30:11 pm »
i've a empi oil pump 32mm with oil filter on and an empi oil sump(small one) for  a 1200cc  Roll Eyes
« Reply #7 on: April 26, 2008, 19:24:52 pm »
That's what I've got, except I have the more common EMPI sump. Hopefully it will work for the 88x82, 6500 MAX Wink
« Reply #8 on: April 26, 2008, 21:35:18 pm »
i've got a racetrim for my 1915 that will rev up to 7,000.
is that not enough then?  Roll Eyes
« Reply #9 on: April 27, 2008, 03:57:39 am »
I would be nervous...
« Reply #10 on: April 27, 2008, 13:10:50 pm »
of oil starvation?
Bewitched666
Bewitched
« Reply #11 on: April 27, 2008, 16:27:44 pm »
2 qrts good for you Died Cool
Fast vw beetle's rule
« Reply #12 on: April 28, 2008, 17:30:54 pm »
of oil starvation?
Of sucking the sump dry at high rpm's. Maybe a drain back from the valve covers to the sump would be a good idea?? Huh
« Reply #13 on: April 28, 2008, 17:47:53 pm »
I would go for 3.5qt for any motor that can achieve revs very quickly, not only considering how high it will rev, but how fast it will get up there. Considering light flywheel and larger oil pumps on most hot rod's, I'd say the 3.5qt is the way to go.
Figure if you need dual valve springs or if you have some type of rev limiter, you need a 3.5
airstuff
« Reply #14 on: April 29, 2008, 12:45:40 pm »
cheers richie,uk
How's the quality of these Empi 3.5 Sumps??.Are they worth the money.They aren't too expensive,but I've seen people finding chunks of sand in there from the sander. Cheesy
« Reply #15 on: April 29, 2008, 17:58:16 pm »
It would be neat to cut and section in a piece of aluminium to make that Race-Trim sump deeper, wider, or both. You could use one of the Bugpack sumps as extra material as they are the same casting, and cheap...
« Reply #16 on: April 29, 2008, 18:05:21 pm »
I would like to hear more about that experimental Berg sump that Doug or Clyde was working with, that had the "air tubes" going through it longitudinally.
Bugatti did the same thing way way way back in the 1920's with their Type 35 straight 8 (I think they used 8 tubes running lengthwise through wetsump)
« Reply #17 on: April 29, 2008, 19:28:07 pm »
Something like this transmission pan??
« Reply #18 on: April 29, 2008, 20:31:11 pm »
yes the Bugatti sump looked similar
stealth67vw
« Reply #19 on: April 30, 2008, 03:45:35 am »
Better to have too big of a sump than too small. I like the 3.5 and 4 qt sumps from Berg. I've got a 4 qt. for my 2165 and used the same sump on my IDA'd 1776.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #20 on: April 30, 2008, 07:22:22 am »
I did that a couple of years ago.  I took a vintage Lang sump and sectioned it and added 1".  Then I got some 1/8"x1 Al flat bar and bent it in a square that matched the OD of the sump.  I clamped it all together and TIG'd it up.  The result was a sump that held 3qts and was the same depth as a Berg 3.5 qt extra wide sump.  And weighed 60% less.
« Reply #21 on: April 30, 2008, 17:34:26 pm »
The Lang sump is a good cantidate for that. Next one I find, I'm keeping Wink
« Reply #22 on: May 06, 2008, 16:38:03 pm »
this got me thinking of going for a CB super deep 4qt sump.
those are relatively cheap compared to the wider thinline sumps they also sell...
however, this got me thinking:
"too deep for use on street sedans"
does that count for us cal-lookers as well?
« Reply #23 on: May 06, 2008, 17:14:19 pm »
Just dont forget that the thing is hanging down there, and you should be fine. If you buy one of those sumps, get a basket of gaskets to go along with it, as you can see they dont use the standard VW one Wink
airstuff
« Reply #24 on: May 06, 2008, 17:17:48 pm »
I have decided to use Scat 2 quart sump for my 2276 project.It looks like a nice casting and overall quality
« Reply #25 on: May 06, 2008, 20:13:17 pm »
Cheesy
but 4 1/2" low!! and dutch speed bumps... mmh.
will my racetrim sump really be that bad?
zach, i thought you were gonna use the same on your racetrim 2276cc some time in the future...
« Reply #26 on: May 06, 2008, 20:26:34 pm »
Cheesy
Hi Diederick
With as fast as your new motor should accelerate, I would think it would be wise to have a safety margin as far as capacity. Cold oil doesn't want to flow back to sump very quickly. Let's say you fire car up, not have oil to temperature and want to stab it... you'll send all the oil up into heads (especially) if going through corner, and the sump "may" run low. Even a mild 1776 I built in 2000 with little 40IDFs got a 3.5qt sump. How many other motors that can rev to 7000rpm (+) are running under 5 qts of oil? I would bet not many. We have the disadvantage of being a horizontal motor and an antiquated bypass setup. My Suby runs to 6800 very quickly and it holds 5qt of oil (which, if I had my way, would have another 2 added). Under "ideal" conditions, your 1.5 may be enough.... but how often will conditions be "ideal?"
« Reply #27 on: May 06, 2008, 21:08:29 pm »
Cheesy
i only have 4.5 litres of oil,shift at 7800rpm and have no issues,BUT i do use a thin synthetic oil that will drain back quickly and I am always carefull to see some oil temp before I get on it
cheers richie,uk
« Reply #28 on: May 07, 2008, 02:16:37 am »
Cheesy
Yes, I will use the Race-Trim 1 1/2 quart sump... but my motor (both motors, the 1835cc as well) will also be dry sumped Smiley
« Reply #29 on: May 07, 2008, 15:09:35 pm »
richie, what kind of oil? 10w40?
i guess i can always change the sump later on...
i need to get building soon, but i keep waiting for parts to arrive.
Pages: [1] 2 Print
