October 12, 2026, 16:30:35 pm
Summer ride....
Topic: Summer ride.... (Read 42447 times)
Christofe
Summer ride....
April 28, 2008, 09:39:18 am »
Time has come to present my summer 2008 ride...
The base is a 1960 turkish green car, restored 10 years ago and then stored in a corner of a body workshop.
Unfortunatly half of the body had primer spray marks , took my 3 days to have it all off.
The front bonet has been resprayed (had default).
The restauration work hve been done propoerly, body off, pan in epoxy etc...
The car is originally equiped with a Dehne fuel jauge, a motometer voltmeter and a VDO watch in the glovebox door.
Also has reclining seats.
Have now equiped the car with a sway-a-way, and a very nice set of centerlines... looks quite good I think.
Drives very smooth (the wife is happy)))))
Last Edit: April 28, 2008, 10:27:20 am by Christofe
Christofe
Re: Summer ride....
April 28, 2008, 09:50:04 am »
pictures.......
Christofe
Re: Summer ride....
April 28, 2008, 09:52:58 am »
and the result.....
Christofe
Re: Summer ride....
April 28, 2008, 09:59:22 am »
and a few others...
Plans are (if I keep the car)
1776 cc and a 8X31 gearbox to make it the perfect cruiser....
Frank LUX
Back...Soon...hopefully!!!
Re: Summer ride....
April 28, 2008, 10:25:44 am »
Very Nice Car Chris...
Needs a Bigger Motor...
Frank
Christofe
Re: Summer ride....
April 28, 2008, 10:25:58 am »
and the last plan would
be this option......
Last Edit: April 28, 2008, 10:41:25 am by Christofe
Christofe
Re: Summer ride....
April 28, 2008, 10:29:25 am »
Frank,
I have the engine
just need to rebuild it. (still looking for a 69 conterweight crank)
and if any one has a 8x31 gearbox I might be intrested...
Christofe
Frank LUX
Re: Summer ride....
April 28, 2008, 10:32:47 am »
Quote from: Christofe on April 28, 2008, 10:29:25 am
Frank,
I have the engine
Christofe
There goes the Happiness of your Wife...
Frank
Christofe
Re: Summer ride....
April 28, 2008, 10:40:57 am »
Frank ,
don't tell her
Christofe
Olaf A./DFL
Re: Summer ride....
April 28, 2008, 11:33:03 am »
great car -looks mighty fine!
http://www.dflvwclub.de/
Re: Summer ride....
April 28, 2008, 15:32:50 pm »
nice ride chris hope to see this one this year
rgd
fabs
lowfastbus
WUNDERWAFFE
Re: Summer ride....
April 28, 2008, 19:27:12 pm »
Love the green steering wheel and shifter... nice factory options!!
Jelle
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Christofe
Re: Summer ride....
April 28, 2008, 20:57:25 pm »
Quote from: speedwell on April 28, 2008, 15:32:50 pm
rgd
fabs
You will Fab ... at KGM 6 ....will be a blast..
Christofe
Re: Summer ride....
March 31, 2009, 22:52:16 pm »
so digging up this post for a few updates....
Found a long 8X31 gearbox, complete revision, its in the car.
Wit the the help of PAT(
www.pat.be
) also found the time to close the 1776, thanks to him for his time and advises...
Engine is now in the car, 12v conversion is done except for the turn signals -) can't make them work.
It's an after august 60 so 61 model front turn light and small taill light.
now I still need to work on the rear-end height and put some spacer on the back wheels...
and last but not least swap the front drums for disc brakes, beacause they won't keep up long !!!!
pics from the first drive this afternoon
Re: Summer ride....
April 01, 2009, 12:40:43 pm »
it's an export model right
with my standart i've the same problem , i never understand how the rear lights works
, my 61 doesn't have the semaphores but had the front turns signal
yours made the 3 positions , lights ,brakes and, turn signals
normally in an european car (non export) <- 61 you have 3 wires in the comodo , and on the export model & <-aug 61 standart model you have 5 wires in the comodo
take an 60 US electrical wiring diagram
donder
Re: Summer ride....
April 01, 2009, 20:41:10 pm »
nice car dude.
peach_
Re: Summer ride....
April 04, 2009, 12:27:08 pm »
Cool car dude
SAS RENN-WAGENS
and proud
#CALLOOKDRAGS
Christofe
Re: Summer ride....
April 08, 2009, 09:15:56 am »
Quote from: speedwell on April 01, 2009, 12:40:43 pm
Thanks Fab !
Still I can't see why its not working
On the 12V relay I have the following connections
31 : Ground
49 : from the commode
49 B : from the commodo + signal to the dashboard.
I can only get to work permantly, meaning the turn signal goes on when using the commodo but it's not flashing !!!!!
Anyone having an idea, guys from the US should know the problem ?
Regards
Christofe
Re: Summer ride....
April 08, 2009, 12:07:06 pm »
i've the same problem i know thatxavier change my relay i will take pictures if you want
Re: Summer ride....
April 08, 2009, 21:10:19 pm »
Quote from: Christofe on April 08, 2009, 09:15:56 am
Thanks Fab !
31 : Ground
Regards
Christofe
try using a 2 wire flasher with the + to the switch going threw it
Christofe
Re: Summer ride....
April 09, 2009, 20:39:39 pm »
finally getting there ....
I can now start working on the Orange '72...
Christofe
Re: Summer ride....
April 09, 2009, 20:40:50 pm »
and a few more !
Re: Summer ride....
April 09, 2009, 21:51:39 pm »
It looks good !
Re: Summer ride....
April 10, 2009, 12:57:15 pm »
the turn signal works now
Re: Summer ride....
April 10, 2009, 17:30:28 pm »
great looking car! well done.
please check your PM
DVK ~
Christofe
Re: Summer ride....
March 16, 2011, 23:07:27 pm »
Bringing this thread up as the car is now at the bodywork shop for,
a ragtop roof section weld, remplace 4 wings by original vw's, replace the rear original decklid by a convertible version,
and a full respray ....pics will come soon
But my main question is : anyone on here knowing where I could buy a ragtop canvas like this one
Regards
fredy66
Re: Summer ride....
March 16, 2011, 23:37:19 pm »
cool ride
arabia slugs
Rocket Ron
It's old school for a reason
Re: Summer ride....
March 17, 2011, 11:50:54 am »
Christofe
try here
http://www.thesamba.com/vw/classifieds/detail.php?id=1090545
13.12 @ 101.84
Grooving out on life
Christofe
Re: Summer ride....
March 17, 2011, 12:03:43 pm »
Ron,
I saw that one, but the colour seems
does anyone know if Lenny sells other colours ?
mychatype3
Re: Summer ride....
Reply #29 on:
March 17, 2011, 14:50:07 pm »
Hello Christofe,
Try
http://www.himmelservice.de/english/home.html
Greetings mycha
1968 fastback "in resto"
1970 Westfalia from the States
