August 12, 2026, 19:19:24 pm
Where to get brakes for spindle mount wheels?
Topic: Where to get brakes for spindle mount wheels? (Read 9263 times)
Prowagen
May 04, 2008, 22:52:44 pm »
I have some Weld spindle mount wheels that fit onto Stange spindles. But I also want to run brakes up front as its has to be road legal, anyone know where I can get brakes that will work with this wheel setup? I am sure I have seen them somewhere before?
Rob.
Adele AW
Re: Where to get brakes for spindle mount wheels?
May 05, 2008, 22:19:04 pm »
JCL Racecars in the states! I looked at these for mine but I opted for bolt on just to be on the safe side for road use. They are about $1000 for the fronts in either spindle mount or bolt pattern like mine.
I presume you will still run either K&L or Balljoint? If you do run the spindle mount fronts they will also need machining to accept VW bearings! Wayne Allman would be who I suggest for this seeing as the wheels are already in the UK!
I've got a picture of JCL's front set-up somewhere too..
Steve
O/FF 621
Adele AW
May 05, 2008, 22:30:03 pm »
PIcture..
O/FF 621
Prowagen
May 06, 2008, 03:17:54 am »
Cheers steve,
Yeah going on BJ beam, How do the brakes attach to the wheel? Theres no fixings on the back face of the wheel, do you know? If not I best ring JCL.
Cheers,
Rob.
Adele AW
May 06, 2008, 18:27:15 pm »
Looks like the bolt to the wheel from this other picture..
Best bet would be to ring Jimmy or even PM his son Austin on the cal-look.com forum
O/FF 621
jr59
May 09, 2008, 12:54:23 pm »
CMS wheels (those whop make erco wheels) have a billet model front wheel that you can purchase with the disck already bolt on them.
Art Gumpfer is running them on his fast back:
http://home.comcast.net/~agumpfer/wsb/html/view.cgi-home.html-.html
You can mail him he will answer you for sure!
http://speedshop.skynetblogs.be/#
