October 14, 2026, 05:32:23 am
| | |-+  Cam selection for my 2276
Author Topic: Cam selection for my 2276  (Read 6971 times)
ianmac
« on: May 06, 2008, 09:48:38 am »
I took the motor out of my '63 for a good old clean up, its about 10years old, but thought whilst it is out I would go the whole way and strip the bottom end. To be honest I have never liked the FK-87 cam, I always found the engine to be all or nothing. When I originally built the motor I just wanted an animal, now I am getting older I want it a bit more streetable, for this reason I have decided to change the cam.
Spec of motor is:
82mm crank
5.5 rods
Jeff Denham 044 heads (44x37mm valves)
48IDAs
Do I go for an FK-10 or an alternative?
Whats do you guys reckon??
Also would I benefit from dropping to a 1 5/8" header?
Ian Grin
By the way the car is a full weight street driven '63 bug.
airstuff
« Reply #1 on: May 06, 2008, 11:48:38 am »
I will be using FK 10 soon in my motor.
67worshipper
« Reply #2 on: May 09, 2008, 19:28:42 pm »
FK 8 wouldnt be a bad choice either.
vw hot rod heaven
71CALRIPPER
« Reply #3 on: May 09, 2008, 20:29:54 pm »
ask jeff what he thinks seeing as though he did the heads
JS
« Reply #4 on: May 09, 2008, 22:42:11 pm »
I have a similar setup with the FK-8. Itīs like driving a hi-power turbo diesel engine. Up to 3500rpm, that is.  Grin
Signature.
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #5 on: May 21, 2008, 00:33:41 am »
I run FK10 and love it.  it comes on around 1800 till about 6200. Great street cam.
« Reply #6 on: August 29, 2008, 20:57:12 pm »
Not sure if you're still interested or have made a choice but I would shorten your rod length to Vw length or even better, 912 length. I would go with 1.75" header.
Also, which carburetors are you going to use?
40mm Webers: too small for this cylinder cc really to get hp, so very mild cam timing like no more than 250 deg @ .050
44mm Webers: something like Engle 125 or K8 or FK44 or 86B Web
48mm IDF or IDA: Engle 130, Web 86C or if car is light and has really close gears, FK87
I really enjoy my Pauter R6E8 in my 2165cc, 9.7:1, 48mm Webers, comes on just under 3000, really comes alive @ just under 5000
