April 19, 2024, 17:26:41 pm
350680 Posts in 28573 Topics by 6819 Members
Latest Member: Umanisti
Pages: 1 ... 23 24 [25] 26 27 ... 34 Print
Author Topic: The weight saving thread  (Read 520969 times)
« Reply #720 on: September 09, 2014, 23:40:31 pm »
Here's a free one.  The steel guide tube is 67g, the plastic one is 32.
« Reply #721 on: September 11, 2014, 21:43:52 pm »
I didn't know you could get a plastic one! Where are they from Bruce?
spanners
« Reply #722 on: September 12, 2014, 07:34:13 am »
I want the ferrous one in my circuit car, plastic can melt at race clutch temperatures.
Best regards, spanners.
« Reply #723 on: September 14, 2014, 06:05:31 am »
This is worth at least a quick breeze through:
http://www.thesamba.com/vw/forum/viewtopic.php?t=418307&postdays=0&postorder=asc&start=0
After it's all said and done he will have taken nearly 800 grams out of an 82mm crank, and reduced windage considerably.
« Last Edit: September 14, 2014, 06:45:39 am by Zach Gomulka » Logged
Andy Sykes
« Reply #724 on: September 14, 2014, 15:07:22 pm »
I got asked to make a solid early shifter connector so I did and few others have them now and said the work great so I make a lighter one
empi bendy thing
lighter solid one a good 50% saving
cheers andy
Pas
« Reply #725 on: September 14, 2014, 19:30:46 pm »
Very nice Andy, I will take one.
Andy Sykes
« Reply #726 on: September 14, 2014, 20:24:22 pm »
I will bring one to track and fit it myself how about that for sevice lol
« Reply #727 on: September 16, 2014, 03:24:07 am »
Genuine VW!  It's got a part number on it, I will post it soon.  Anyone know the part number of the early steel one?
Pas
« Reply #728 on: September 16, 2014, 16:57:17 pm »
You can't get better than a Andy Sykes fitter Grin
« Reply #729 on: September 16, 2014, 17:56:56 pm »
Be careful, I think its a trick to get you to actually bring the car to the track Shocked Angry Cheesy
Andy Sykes
« Reply #730 on: September 16, 2014, 18:15:13 pm »
Dam I've been sussed out
Pas
« Reply #731 on: September 16, 2014, 19:56:16 pm »
Be careful, I think its a trick to get you to actually bring the car to the track Shocked Angry :
I'm not falling for that one  Grin
« Reply #732 on: September 18, 2014, 01:39:36 am »
113 141 181 B
I don't know if you will get this plastic one if you went to your local VW agency.  The early steel collar was used in the mid 80s by Porsche on the 924/944  The Mexican Beetles with their Brazilian made gearbox also had the steel one up to 2003.
dangerous
« Reply #733 on: September 18, 2014, 02:37:09 am »
091 bus came with the plastic ones too.
Jim Smith
« Reply #734 on: September 25, 2014, 08:37:07 am »
These will save a little weight.....3Kg each, early or late.
www.cotsweld.co.uk      Race car fab   01242 232084
« Reply #735 on: September 26, 2014, 12:58:32 pm »
Thats nice! are they fixed lexan windows only i'm guessing?
Griebel
« Reply #736 on: October 19, 2014, 01:50:43 am »
Wink
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
« Reply #737 on: October 25, 2014, 01:19:26 am »
Can you get them without the JPM embossed in them?
Titanium coil strap:
« Reply #738 on: October 30, 2014, 01:56:35 am »
The Ti coil strap has been in the car for about a year now.  It's quite flexy, so I had to give it a bit more slack on the 12V lead.
The stock strap is over 100g, the Ti one is under 20.
Here's the hefty Al strap (26g) that survived Central America:
« Reply #739 on: November 04, 2014, 03:55:44 am »
I thought I found another free one with the oil filler cap.  The common stock one from the 60s and 70s is stamped from steel, and I learned the first ones used in 56 were Al, so I was on the hunt for one.
It is a disappointment at only 10% lighter than the steel one.  This is very perplexing since Al is only 36% of the density of steel, and the sheet thickness appears to be the same.
« Reply #740 on: November 04, 2014, 04:14:41 am »
Love it.
AL is on the right?
« Reply #741 on: November 05, 2014, 03:55:23 am »
Yep, identified by the fine serrations on the OD.  Note that it also has Al rivets!
spanners
« Reply #742 on: November 14, 2014, 18:45:45 pm »
Heavy 944 cv joints out, lightened and blueprinted 100mm bus units in. More power, less weight, oh yay. [ Attachment: You are not allowed to view attachments ]
« Reply #743 on: November 16, 2014, 02:44:39 am »
Mystery solved.  It's steel.  I guess the magnet I tested it with was kinda weak.  It has the right colour for Al.  Maybe I will figure out how to form one myself.
« Reply #744 on: November 16, 2014, 02:45:25 am »
Do you have a better pic showing how you lightened it?
Weights? before and after?
« Reply #745 on: November 16, 2014, 03:32:11 am »
Ahh, that explains it. I went rummaging around my buddy's shop for one, found a serrated one but it didn't pass the magnet test.
spanners
« Reply #746 on: November 18, 2014, 18:44:02 pm »
The pic quality goes away with re sizing for posting here, but they are machined  circumferentialy if you look.
Weights for stock 944 cv = 1490 gms.
Stock 100mm VW Bus = 1410 gms
Lightened bus cv= 1155gms.
« Reply #747 on: April 14, 2015, 04:27:04 am »
Mystery solved again!
At a local swap meet I brought along a magnet and tested oil filler caps.  The one on the right is indeed made from Al.  It's half the weight of steel.  Suspicious is the lack of the VW logo...
« Reply #748 on: April 14, 2015, 07:37:23 am »
Very cool Bruce. I'll keep my eye out for them from now on Smiley
What are the weights?
« Reply #749 on: April 15, 2015, 02:46:49 am »
Light and ultralight.  I wonder if the Al one is 356?
« Last Edit: April 15, 2015, 02:48:24 am by Bruce » Logged
