September 22, 2026, 11:59:34 am
| | |-+  How to dial in a FK89 cam, ## ???
Author Topic: How to dial in a FK89 cam, ## ???  (Read 5408 times)
RMS Boxer Service
« on: May 12, 2008, 09:22:31 am »
Hi all,
I'm helping a friend building a 86X101.6 mm Oxyboxer engine with JPM heads for his 64 drag racing sedan and need a little help.
My question is, should I  mount it sraight up or retarded/advanced a few degrees??  I have searched both this site and the shoptalkforum
without finding an answer.
What did you guys do when installed your FK89 cams??
/R
Roman
« Reply #1 on: May 12, 2008, 16:37:49 pm »
Why don't you ask JPM? The reason you won't find any info is that there is very few JPM 4" heads out there, I had the very first in a running engine and that was exactly a year ago. My guess is that he tells you to set it at 106 degrees.
GetBackOnTrack
« Reply #2 on: May 13, 2008, 15:24:53 pm »
Why not do a trial assembly and see where your at?
Check: gbot.dk
RMS Boxer Service
« Reply #3 on: May 13, 2008, 20:37:58 pm »
Roman,
You were right Smiley Johannes says 106 degree Grin
Getbackontrack,
I like to know what to aim for. I'll assembly and dial in the cam to Johanns' recommandations.
/R
Chris Andrews - The Mailman
Gaelic lineage with Yankee blood
« Reply #4 on: May 15, 2008, 02:30:32 am »
Hi all,
/R
Dialing in your cam depends on the camshaft's actual lobe separation (lobe center). It is assumed that you have a standard Engle FK-89 with 108° lobe centers.
Years ago, I was scolded by a cam grinder, that I needed to run my cam intake lobe centerline at 104°. Being naive I reluctantly obliged and set the cam 4° advanced. What I am attempting to convey is, one does not know for certain what the engine requires until it is run on a dynometer and the torque and horsepower verses RPM is measured. Then you can make adjustments to the camshaft to optimize the power band.
Have fun.
"A simple way to take measure of a country is to look
at.....how many want in.......and how many want to get out."
-Prime Minister Tony Blair of Great Britain
"...Government of the people, by the people, for the people, shall not perish from the Earth."
-Abraham Lincoln, Gettysburg Address, November 19, 1863
"A man's country is not a certain area of land, of mountains, rivers, and woods, but it is a principle and patriotism is loyalty to that principle."
- George William Curtis
"Good fences make good neighbors."
- Robert Frost, The Mending Wall - 1914
