November 03, 2026, 01:54:11 am
| | |-+  Not enough end play at flywheel
Author Topic: Not enough end play at flywheel  (Read 4797 times)
« on: May 14, 2008, 20:48:48 pm »
Yesterday, I check the end play of the engine I'm building for my 68.
I found a play of 0.27mm with 2 shims of 0.24mm. So, I need a 0.17mm shims to have the ideal play.
But, the thinner shim available is 0.24mm.
What have I do wrong?  Huh
I was thinking of a wrong size of bushings, but the crank turn freely.
« Reply #1 on: May 14, 2008, 21:17:11 pm »
Hi
what crank and flywheel do you have ? I would cut the flywheel as much as you need to get the right endplay with 3 shims .
« Reply #2 on: May 14, 2008, 21:19:59 pm »
how much end play do you have with no shims?
Germanlkmanx
« Reply #3 on: May 14, 2008, 21:45:57 pm »
Let me guess. Are you using a LEPE 69mm crank? I have had to do this many times when forced to use those cranks. I would take 0.010" off the flywheel thrust face and re-shim from there...
tom.
« Reply #4 on: May 15, 2008, 06:38:07 am »
I use an stock crank with a stock 200mm flywheel. Machined for 8 dowels.
Without shims, I have 0.80mm.
