September 19, 2026, 22:05:51 pm
352309 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  The Slingle Cab and The GTV race for pink slips, TONIGHT!
Poll
Question: Who is the slowest?
The Slingle Cab
The GTV
Author Topic: The Slingle Cab and The GTV race for pink slips, TONIGHT!  (Read 25273 times)
« on: May 16, 2008, 18:13:46 pm »
Who is the slowest? We will settle this once and for all. Firebird Raceway, Friday Night Drags, tonight.
The first and only time The Slingle Cab ran a few years ago, it was mostly stock, running 1600 single port fitted with an 010 and a Kadron header. Ran 22.9's all day long, and I swear I saw it burn flames onto the track just like the Delorean in Back To The Future. Except it ran out of asphalt before it made it to 88mph. Now it's sporting a Treuhaft equipped 1600cc, many suspension upgrades for improved aerodynamics, and a fancy new glass pack and Porsche 912 tach installed just yesterday. This time, expect time warpage.
The GTV on the other hand is still sporting its tried, true, and trusty 117k mile, original 1600 dual port.  At Phoenix BOR last year it ran back to back 20.32's- but it was still sucking through the stock Slo-ex carb, and exhaling out the blown and rusted original muffler. Now things have improved! A buttery smooth Zenith 32 NDIX carb has been installed for nearly twice as much venturi area, with phenolic spacer no less, as well as a header and a sweet sounding S&S glass pack muffler. A Pertronix ignition in the 010 brings it bang up to date. It is defintely going to be hard to steer when I get rubber in all 4 gears.
Place your bets gentlemen!
67worshipper
« Reply #1 on: May 16, 2008, 18:16:57 pm »
come on zach! Wink
vw hot rod heaven
« Reply #2 on: May 16, 2008, 18:45:42 pm »
Adding a tach lowered my e.t. in the '67, so it might be a real race!  Or lunch break.
« Reply #3 on: May 16, 2008, 19:22:52 pm »
Votes? 2 to 1 against the GTV so far! Well Zach, you now know who your friends are! Grin
Frank LUX
Back...Soon...hopefully!!!
« Reply #4 on: May 17, 2008, 09:42:03 am »
I Vote for the GTV... Wink
Frank
« Reply #5 on: May 17, 2008, 14:02:07 pm »
GTV if it were not for the engine it sure has better aerodynamics so it will be ahead at the end of the track
congratulations with the new single cab Zach  Grin Grin Grin
« Reply #6 on: May 17, 2008, 18:53:50 pm »
Results are in!
Race 1-  GTV wins! 19.79 to 19.96. But he has me by 4mph through the lights, I know if he gets a good launch Im going to be done for. For some reason I didnt pre-load and I had massive motor hop! The velocity stack actually banged itself into the decklid, flattening the lip out quite nicely! Cheesy
Race 2-  Slingle wins! 19.91 to 20.18. This time I pre-load, but leave at too low RPM. The Slingle is making headway...
Race 3-  GTV wins! 19.68 to 19.86. Now we were thinking it was going to be close, but we had no idea it was going to be this close. I cut an .023 light, I am proud of this.
Race 4-  Slingle wins! 19.22 to nothing. I cut a red light, and the stupid S hook on the throttle cable pops off of the pedal as I bang second gear. This pisses me off because it was my fastest 60 foot. I limp it down the track. Slinger got the launch down and knocked .6 off of his previous best!
Race 5-  Slingle wins! 19.31 to 19.84. He clearly has me beat on hp.
Race 6-  Slingle wins! But we dont know what the time was because the tower fucked up somehow! Angry It felt pretty strong on my end (relatively speaking!).
And that is that. I wanted another run since we didnt get our last time slips, but I decided I had punished my car enough. Running 66mph through the traps in 3rd gear on an original motor can not be good for too long. It was fun, and I cant wait until I rebuild the top end and give it another go next spring. On a side note, we were the only VW's there last night, and we did not represent well. We were the 2 slowest cars there! Cheesy
67worshipper
« Reply #7 on: May 17, 2008, 20:14:07 pm »
we need some pics zach of this side by side action. are you hooked on drag racing now zach?
vw hot rod heaven
« Reply #8 on: May 17, 2008, 20:19:24 pm »
I didnt get much in the way of pics Sad Sling brought his video camera, but we didnt get any of the action on that either!
Ohh, and this isnt my first trip down the strip Wink
67worshipper
« Reply #9 on: May 17, 2008, 20:26:55 pm »
you gonna bolt on some more go faster goodies for a bit of time tumbling?
vw hot rod heaven
« Reply #10 on: May 18, 2008, 01:45:15 am »
Yessir. The plan this winter is to exchange the worn out 85.5's for a set of forged 87's, cut down the cylinders for .040" deck (brings the CR up from 7.3 to 7.9), and add a pair of EMPI 1.4 rockers for a .120" increase in valve lift. Also I am contemplating boring out the Zenith to 36mm's and installing 28mm vents!! Cheesy
67worshipper
« Reply #11 on: May 18, 2008, 10:12:33 am »
should be good for a 16 ish if you dont pull a cherry Grin
vw hot rod heaven
67worshipper
« Reply #12 on: May 18, 2008, 10:13:23 am »
what cam you got?
vw hot rod heaven
« Reply #13 on: May 18, 2008, 18:32:14 pm »
Its the stock cam, the motor is original!
« Reply #14 on: May 18, 2008, 20:09:36 pm »
So Zach Did You Hand Over The Pink Slip? Grin  you only get three trys on the Real Pinks  LMAO Grin Grin
« Reply #15 on: May 18, 2008, 21:32:56 pm »
Unfortunately, I didnt get any racing shots Sad But I did snap these 2 shots of our motors in "race" guise  Cheesy
67worshipper
« Reply #16 on: May 18, 2008, 22:26:28 pm »
i love those trumpets Grin
vw hot rod heaven
« Reply #17 on: May 19, 2008, 17:27:31 pm »
velocity stack  Grin Grin
team97
3M TA3
« Reply #18 on: May 19, 2008, 20:18:12 pm »
touche' Fabs
Der Kleiner Panzers III
D.K.K.
« Reply #19 on: May 19, 2008, 20:31:56 pm »
hehe Wink
SlingShot
« Reply #20 on: May 20, 2008, 06:25:12 am »
Zach where is MY Pink Slip?Huh Don't make me gather up all my Italian friends  Grin
Will Race For Beer !!!
alex d
« Reply #21 on: May 20, 2008, 09:04:58 am »
damn, I didn't see this post before! I was going to bet for the single cab anyway  Grin
« Reply #22 on: May 20, 2008, 16:46:29 pm »
Double or nothing at Phoenix BOR next year!!
And dont give me this "Italian friends" bullshit. No Italian would be friends with you, you're just as Polish as I am! Cheesy
SlingShot
« Reply #23 on: May 20, 2008, 17:39:08 pm »
"Italian Friends" sounds better and more intimidating than "Polish Friends"  Wink
