November 03, 2026, 07:16:10 am
| | |-+  how amateuristic can you be?
Author Topic: how amateuristic can you be?  (Read 6714 times)
« on: May 18, 2008, 19:08:36 pm »
my way of torquing the flywheel Smiley
« Reply #1 on: May 18, 2008, 19:13:12 pm »
if it works........... Grin
Bewitched666
Bewitched
« Reply #2 on: May 18, 2008, 19:51:28 pm »
Yeah,if it works why not,i have seen worse kinda things Grin
Fast vw beetle's rule
« Reply #3 on: May 19, 2008, 00:04:16 am »
remind me to tell you some "Ty" stories sometime.......
Bewitched666
Bewitched
« Reply #4 on: May 19, 2008, 07:20:33 am »
Jim just a reminder, can you tell us about some "Ty" stories Grin
GreenTom
« Reply #5 on: May 19, 2008, 07:58:55 am »
maybe a stupid question Smiley how do you put crank seal ather doing taht before putting into case Tongue annd how do you set a end play Grin or you just do it to check something Cheesy
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
« Reply #6 on: May 19, 2008, 11:22:14 am »
this was to set endplay Smiley
how much torque does the gland nut need anyway?
found a torquewrench at work that can go to 750 Nm Smiley
WhiteTrash
« Reply #7 on: May 19, 2008, 22:58:44 pm »
The torque setting as per VW manual is 350Nm which i think is about 220lb/sq,
but a little more dosnt hurt. Don't forget the Loctite.
Bugpack sell this tool, I just made one myself looking similar in about 20min out of some 2x1 box section and flat 10mm steel plate with some holes drilled
http://www.bugpack.com/content.php?id=619
HOFF#67
« Reply #8 on: May 19, 2008, 23:08:21 pm »
you bet I can...
in fact this guy "ty" is related to sheep... no kdding
he taught us all what not to do when tuning a VW for more power. Drained his mom's To#¤ta Celica's oil from the motor, ran it through a pair of her panty hose into his Bug motor when it was low. He didn't believe in exhaust manifold sealing (of any type), rear windows, working electrical, or brakes. Watched him port a head with head on engine, with a hand drill, then blow port out with air. Watched him "do a valve grind" by slathering valve-grind paste onto seat, inserting valve and runing the stem in a drill chuck. Yes with heads on car. Best though, had to be his carburetor linkage. He "got" a pair of Weber 44's from his uncle that raced 914's but no linkgae. So he "fabbed" a setup that I have yet to see again...  he made a simple swivel off top of case, out of an 8mm stud and pipe-strap. From there he ran two lenghts of pipe strap to each carburetor, but he had to cut slots in the fresh air ducts for the pipe strap to push and pull through. Ugly doesn't begin to describe it.
Car always sounded ragged..... wonder why... Roll Eyes
Jim
« Last Edit: May 19, 2008, 23:50:33 pm by Jim Ratto » Logged
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #9 on: May 20, 2008, 05:40:36 am »
Jim,
   Did he have a beryl green '62 63 ish with 356 front brakes and rims???  Newell Dunn recently bought said car and it had a linkage just like you describe. Also had a micro switch setup rigged on the turn signal lever to flash high beams.... hmmm crazier things have happened.
Jason
« Reply #10 on: May 20, 2008, 16:13:54 pm »
Jim,
Jason
Hey Jason.... no it was a muddy, dirty, primer grey 64 or 65 Bug with repro 5 spokes.... this was 1987 or so up in Livermore (N Calif)
Your colleagues car sounds MUCH nicer...  Grin
I forgot to mention his vise-grip window cranks, inside door handles and at one time, even a steering wheel (no kidding)
« Last Edit: May 20, 2008, 16:19:07 pm by Jim Ratto » Logged
Jason Foster
« Reply #11 on: May 21, 2008, 00:43:19 am »
  it's amazing how careless people can be with something they put their lives in.
