September 23, 2026, 18:13:05 pm
| | |-+  48 IDF Fuel leak
Author Topic: 48 IDF Fuel leak  (Read 4053 times)
Ovalboy
« on: May 18, 2008, 21:21:48 pm »
 Angry
Hi guys can anybody out there help me.
I'm running 48 IDF's on my Oval and seem to have developed a fuel leak, this is what happens:
Start up no problem, run no problem no fuel leak and then when I turn the engine off (and fuel pump) after about 1-2 minutes I get a fuel seapage through the mixture screw and then through the throttle shaft underthe carbs.
Today I installed a service kit including the o ring on the outside of the mixture screw, needle valve, fuel inlet filter but I've still got a leak.
Just wondered if anybody could help.
Dave
« Reply #1 on: May 18, 2008, 21:29:58 pm »
i had also fuel leaking in the carbs and that would cause a hiss of the hot fuel dripping in the hot manifolds. the O rings were cracked and i cured it with new ones. but i managed to twist one when installing it and the problem stayed with that barrel. so make sure the o-rings don't twist and are good.
and maybe clean the block off balls inside the carb... if the fuelchambers are dirty.
