November 04, 2026, 03:57:06 am
67 Vert Lids
Topic: 67 Vert Lids (Read 10045 times)
dth
67 Vert Lids
May 21, 2008, 22:15:08 pm »
Guys ,can anyone help with dimensions of a 67 vert lid ,ie where the vents go ,from top pf lid to top of vents etc,can kinda figure it out by lookin at pics ,just wanna get it right,
Thanks Donald
Re: 67 Vert Lids
May 21, 2008, 22:32:54 pm »
Hi Donald the Easy way is to cut a vent section out of a 68 or later vert lid you section it in as one piece not two vents I will post some pictures
http://www.sandiegovwparts.com/gallery.htm
you drill the spot welds out along the top edge and then cut along the line lay the new vent section over the 67 deck lid mark where it needs to be cut and go for it. an easy way to line it up is the top hole for the Volkswagen emblem make sure the emblem fits in all three holes the top hole will be the new section the bottom and middle holes will be the Original 67 Deck Lid here is a Picture of a 3 Vent Deck Lid I built for my 67
Last Edit: May 21, 2008, 22:49:58 pm by Shubee2 (DSK)
dth
Re: 67 Vert Lids
May 21, 2008, 22:43:15 pm »
Thanks ,very intrested to see some pics ,the only problem being the vents are allready cut out the donor lid (2 pieces),i have the size for between the vents ,really need the size from the top down
Re: 67 Vert Lids
May 21, 2008, 22:44:53 pm »
Even an easier method; contact Danny Gabbard and call it a day. If I ever score a decent paying job again... I'll be doing that for my '67 sedan.
Re: 67 Vert Lids
May 21, 2008, 22:53:16 pm »
Quote from: dth on May 21, 2008, 22:43:15 pm
I would not use the two vents as when welding them in it warps the deck lid to much and they are hard to get straight the one piece way it fall's in to place I would get another Doner Lid there Cheap.
Last Edit: May 21, 2008, 23:39:35 pm by Shubee2 (DSK)
dth
Re: 67 Vert Lids
May 21, 2008, 23:07:26 pm »
Cool ,thanks for the info guys ,much appreciated
Re: 67 Vert Lids
May 22, 2008, 00:49:23 am »
Or with decklid emblem.
dth
Re: 67 Vert Lids
May 22, 2008, 06:18:15 am »
Thanks Fred
Re: 67 Vert Lids
May 22, 2008, 12:15:40 pm »
Donald, I seem to remember hearing that the Karmann vents are 5mm longer than the '68-on vents, although the position is close enough. I know it's not an issue unless you're going for chrome trims on the decklid vents, but worth mentioning all the same!
Neil
dth
Re: 67 Vert Lids
May 22, 2008, 17:24:32 pm »
Thanks Neil ,i,ll keep that in mind
Jordy/DVK
Re: 67 Vert Lids
May 22, 2008, 20:09:30 pm »
What would an orig. '67 vert lid be worth?
DVK ~
"The Full-Throttle Cruisers"
1951
medium brown splitwindow beetle
(resto in progress)
1968
Cal-look(-a-like)
(my daily driver)
Martin Greaves
10.88@128.58
Re: 67 Vert Lids
May 22, 2008, 20:13:18 pm »
Quote from: Jordy/DVK on May 22, 2008, 20:09:30 pm
About £30 so i tell you what i give you £25 for it.
deano
Re: 67 Vert Lids
May 22, 2008, 22:13:13 pm »
If you follow Samba for example, they go (are offered at) from anything in the $400-$1200 range. I have an NOS one lurking about....
Anglia Obsolete Guru
'67 Heaven
Re: 67 Vert Lids
May 23, 2008, 01:41:15 am »
I Had An NOS 67 Vert Lid and NOS 67 rear Apron Sold them Long Ago the Deck Lid From The Dealer was $112.37 and the rear Apron was $63.00 Boy have things Changed now you get Junk for $400.00 to $700.00 Bring Back The Old Days When Gas was a $ .25 Gallon LOL and you got Blue Chip or S&H Green Stamp's LOL, Also I remember when the Walk in Show was $ .25 And The Drive In Theater was $1.75 A Car Load Damm Now I am Showing my Age LMAO
Re: 67 Vert Lids
May 23, 2008, 08:55:24 am »
But back then... they were not as popular as they are now... so it balances out...
Ivan
Re: 67 Vert Lids
May 23, 2008, 14:38:17 pm »
I've got an NOS one up in the roof of my shed. I got it a while back just in case my '67 got rear ended and the Cabrio lid on it got damaged.
