October 13, 2026, 10:20:55 am
| | |-+  JPM double springs
Author Topic: JPM double springs  (Read 6704 times)
Airspeed
« on: May 25, 2008, 21:56:15 pm »
Does anyone know if these have comparable, bit less or more seat and opening pressure compared to the GeneBerg double VW spring set?
Where to buy them?
Tnx,
Walter
RMS Boxer Service
« Reply #1 on: May 26, 2008, 14:17:57 pm »
Translated from JPM's homepage in swedish (the ino is not present in the english version)
Valvespring messurements:
Outer spring:
open length 54mm
Coil bind 20 mm
Outer dia 31,8 mm
tread dia 4,00 mm
L1 25.0mm
F1 928N
Inner spring:
open length 54mm
Coil bind 20 mm
Outer dia 22
tread dia 3,00 mm
L1 25.0mm
F1 580N
Íf you still have questions, send Johannes an email and I'm sure he will answer you, he's a very friendly guy Cool Cool
/Rolf
Rasser
« Reply #2 on: May 26, 2008, 18:38:24 pm »
I went from GB273A springs (had valvefloat problems).
All i can say is I didn´t have the problems after changing to JPM springs - I´ll leave the math to someone else ;-)
highly recommended.
1955 type1
1966 type2 13w deluxe
Roman
« Reply #3 on: May 26, 2008, 19:55:49 pm »
I had them om my old engine. They can take 16.4 mm valve lift with 2 mm to coil bind. My set had 170 lbs seat pressure and it was enough to control a 46 mm steel valve over 8000 rpm.
Airspeed
« Reply #4 on: May 26, 2008, 21:32:07 pm »
Thanks !
I was looking for a set to control a turbo engine and they seem the right part for the job!
Thanks for the translating job as well  Smiley
