September 22, 2026, 22:18:10 pm
| | |-+  Fuel Line Size
Author Topic: Fuel Line Size  (Read 9849 times)
« on: May 29, 2008, 00:51:24 am »
I am getting ready to run a new hard line in the pan. I am planning to use seamless stainless 3/8 tubing. Is there any specific stainless alloy and wall thickness I should use?
Thanks,
Brian Silva
« Reply #1 on: May 29, 2008, 05:37:47 am »
Louis,
I just recently installed my fuel line through the tunnel as well. I purchased my fuel line from jegs. Here is the link http://www.jegs.com/i/JEGS/555/63036/10002/-1/757155%7C10019.
Let me know if you have any questions.
-Brian
« Last Edit: May 29, 2008, 05:40:44 am by Brian Silva » Logged
« Reply #2 on: May 29, 2008, 12:36:23 pm »
Thanks for the link. I will take a look at it.
Russell
« Reply #3 on: May 29, 2008, 15:34:31 pm »
get the fuel line from Earls along with the flare tool and the fittings its the best way. AN-6 size all the way.
Best Regards
Russell
« Reply #4 on: May 29, 2008, 15:38:34 pm »
Hi Louis, Jegs even sells a kit complete with the right tool.
« Reply #5 on: May 29, 2008, 15:46:21 pm »
Thanks. Looking at the kits though, they use Aluminum line. I was hoping to use stainless steel. Though Alum would probably work fine. I will give it some thought.
« Reply #6 on: May 29, 2008, 16:44:59 pm »
Al is far easier to bend.  I see no reason to use SS.
« Reply #7 on: May 29, 2008, 18:34:00 pm »
Thanks for the input. I will take another look at the aluminum kits.
Brian Silva
« Reply #8 on: May 30, 2008, 04:36:25 am »
I actually purchased the kit in -6 steel with with all the tools from jegs.
Here is the link---http://www.jegs.com/i/JEGS/555/63036K/10002/-1
Worked out very well.
« Last Edit: May 30, 2008, 04:38:24 am by Brian Silva » Logged
« Reply #9 on: May 30, 2008, 05:18:36 am »
I ended up going with 3/8 .035 316 seamless stainless steel tubing. I got the AN fittings, 6 AN, from HotrodVW from the other forum. It is a little more expensive but it will outlast the rest of the car. Once I get the line run I will post some pics. Thanks to everyone who gave input.
