September 23, 2026, 00:17:46 am
heads for 1951ccm engine..
Topic: heads for 1951ccm engine.. (Read 7161 times)
Tom G.
June 09, 2008, 08:22:10 am »
Hi There,
So in past i have often talk about my engine 2 litre type 1 with std. heads (35,5x32) with my german cam 324°,@0.50 276°, 9,7mm (0,380")cam lift, Udo becker lifter, std. rockers..now 48 IDA with 37 vents...
My question i want to go as high as much with heads..the engine block shouldn´t be split. Only the heads, rockers, compression ratio could be changed...
So which max. valve sized i could go for?
- 40x35,5
- 42x37
- 44x37
which port design are allowed? CE heads (nice B-form chambers); SE;oval; Wedge,D-port??
Daily driving is not more my first whish, but it should be driveable for sometimes cruising!!
But first of all is HP for 1/4 mile....
Thanks and best regards
Tom
Last Edit: June 09, 2008, 08:27:41 am by Tom G.
Bewitched666
Bewitched
Re: heads for 1951ccm engine..
June 09, 2008, 12:38:47 pm »
44x37 with 10.1 cr and wedgeports
Fast vw beetle's rule
Tom G.
June 09, 2008, 15:26:34 pm »
Quote from: Bewitched on June 09, 2008, 12:38:47 pm
You drive it on an 1951ccm engine?
Bye
Tom
Bewitched666
Bewitched
June 09, 2008, 21:12:19 pm »
Nope but you asked how high on the heads and street driving is of less concern,otherwise same cr but 42x37 valves will work great too.But for more hp and flow go for the 44x37 valves with that cam and can even run 11.0 cr
dirk zeyen
June 10, 2008, 22:31:56 pm »
hello tom,
if you run a stock ratio gearbox don't go to big in valvesize!!!
close ratio with 44/37.5 or stock ratio with 40/35.5.
dirk zeyen
back again!!!
besserwisser
June 10, 2008, 22:44:06 pm »
Whats that orange shit between the case halves?
dirk zeyen
June 10, 2008, 22:46:22 pm »
another idea
if i'm right you run a wbx-crank with 90.5 cylinders?!?
get a set of 94 slip in cylinders, so you don't have to open the case and use 42/37.5 valves with a stock ratio gearbox.
dirk zeyen
back again!!!
Tom G.
June 10, 2008, 23:50:20 pm »
Quote from: besserwisser on June 10, 2008, 22:44:06 pm
a little bit too much of gasket fluid... ::)But the engine is dry since 9000km...
Tom
Tom G.
June 10, 2008, 23:55:07 pm »
Quote from: dirk zeyen on June 10, 2008, 22:46:22 pm
another idea
dirk zeyen
i am run a CB 76mm crank......
Tom
