October 12, 2026, 08:44:10 am
'68 cal-look (kinda)
7
8
9
10
13
Topic: '68 cal-look (kinda) (Read 601593 times)
Re: '68 cal-look ;)
Reply #210 on:
September 18, 2010, 19:41:06 pm »
A few pics on the way to Hills Race in Italy...
Re: '68 cal-look ;)
Reply #211 on:
September 22, 2010, 16:30:09 pm »
I've collected some parts for the engine... the project is a mild road engine, 1776cc (or 1835cc
Here are the parts, what do you think ?
All parts are original, made in Germany. And never used since it's been rectified/machined
*CASE*
Magnesium VW F engine case
Dual oil pressure relief
Rectified crankshaft line
Machined for 90,5mm cylinders (96mm machining)
*HEADS*
Aluminium VW 040 cylinders heads
New spark plug location
Machined for 90,5mm cylinders (98mm machining)
Combustion chambers machined for 8.5 compression rate (2mm machining)
*CRANKSHAFT*
69mm rectified VW crankshaft
*RODS*
311 VW I-beams rods
Case...
Last Edit: September 22, 2010, 19:51:55 pm by Nico86
Re: '68 cal-look ;)
Reply #212 on:
September 22, 2010, 16:32:46 pm »
Re: '68 cal-look ;)
Reply #213 on:
September 22, 2010, 16:34:27 pm »
Heads...
Re: '68 cal-look ;)
Reply #214 on:
September 22, 2010, 16:35:48 pm »
Crankshaft and rods...
Re: '68 cal-look ;)
Reply #215 on:
September 22, 2010, 19:19:28 pm »
I think the logo before the serial number indicate it's been a factory rebuild engine. That's why it has dual oil pressure relief.
Good start to have a fun and easy to live with engine.
Re: '68 cal-look ;)
Reply #216 on:
September 22, 2010, 19:56:36 pm »
Quote from: j-f on September 22, 2010, 19:19:28 pm
I'm reading some stuff now.
Re: '68 cal-look ;)
Reply #217 on:
September 22, 2010, 21:26:57 pm »
those parts look good!
DVK ~
Re: '68 cal-look ;)
Reply #218 on:
September 22, 2010, 22:01:21 pm »
Quote from: 67-indeed/DVK on September 22, 2010, 21:26:57 pm
Re: '68 cal-look ;)
Reply #219 on:
September 22, 2010, 22:16:33 pm »
Quote from: Nico86 on September 22, 2010, 19:56:36 pm
Does this book worth to buy it?
I check on amazone and it is not cheap.
Re: '68 cal-look ;)
Reply #220 on:
September 25, 2010, 23:26:11 pm »
An engine is nice, but you better keep an eye on it, the dash has been cut and painted...
Re: '68 cal-look ;)
Reply #221 on:
September 26, 2010, 07:26:10 am »
Hey Nico, have just the right speedo for ya then run VDO gas, Temp, and Pressure gages in the dash!
Ted
Re: '68 cal-look ;)
Reply #222 on:
September 26, 2010, 17:23:31 pm »
I already have some gauges Ted, and I will never use the second half of this speedo
Re: '68 cal-look ;)
Reply #223 on:
October 04, 2010, 19:39:20 pm »
The plug threads look awfully large in this picture, like it needs an insert in there. Maybe it's just the angle...
Re: '68 cal-look ;)
Reply #224 on:
October 04, 2010, 19:55:03 pm »
Quote from: Zach Gomulka on October 04, 2010, 19:39:20 pm
They are 12mm
Re: '68 cal-look ;)
Reply #225 on:
October 05, 2010, 09:10:38 am »
and those heads seem to be allready flycut. so you can scratch that of your list
. you need to measure them though.
and everytime is see those wheels, i kinda miss them, but i know they look better on your car then they ever will look on my type3.
Re: '68 cal-look ;)
Reply #226 on:
October 05, 2010, 19:20:28 pm »
Quote from: nicolas on October 05, 2010, 09:10:38 am
Yes chambers have been flycuted of 2mm, to get a theorical 8,5:1 CR with the 90.5mm cyl. kit. I will check that before doing anything else on the heads.
they are in good hands now !
Re: '68 cal-look ;)
Reply #227 on:
October 10, 2010, 21:51:20 pm »
Gauges are on the dash plates...
Re: '68 cal-look ;)
Reply #228 on:
October 10, 2010, 21:53:58 pm »
Nico, lets see the front side...
Ted
Re: '68 cal-look ;)
Reply #229 on:
October 17, 2010, 21:48:15 pm »
Quote from: racecraf on October 10, 2010, 21:53:58 pm
Ted
No more teasing...
I get this, but it looks better without the wood style plate.
Re: '68 cal-look ;)
Reply #230 on:
October 17, 2010, 21:50:04 pm »
Everything works fine, except the oil pressure gauges that is going to be repaired.
Flow
Re: '68 cal-look ;)
Reply #231 on:
October 17, 2010, 22:44:36 pm »
Perfect dashboard !
http://70scallook.skynetblogs.be/
Re: '68 cal-look ;)
Reply #232 on:
October 17, 2010, 22:47:59 pm »
Thanks ! White plastic on the last pic fills the hole of the pressure gauges that I have to send for repair, there's a lot of fresh air going through it !
Nico-67
Re: '68 cal-look ;)
Reply #233 on:
October 18, 2010, 07:09:38 am »
Very nice Nico, I like that !
http://nico-67.skynetblogs.be/
Benou67
Re: '68 cal-look ;)
Reply #234 on:
October 18, 2010, 11:38:39 am »
Woaw !!!!!
http://flat-four.skynetblogs.be
Felix/DFL
Re: '68 cal-look ;)
Reply #235 on:
October 18, 2010, 12:11:39 pm »
Hi Nico,
sorry I have to say that but if you colud you may want to use an other case...
It looks very corroded at some important connection spots. Maybe you could recut the spots where the washer goes. Look carfully at those spots twice, cause the stiffness of the connection will suffer when the material it corroded that far.
You want to paint your case, don`t you? otheriwse it will corrode even more...
Best greetings,
Felix
Re: '68 cal-look ;)
Reply #236 on:
October 18, 2010, 14:11:12 pm »
Quote from: Nico-67 on October 18, 2010, 07:09:38 am
Quote from: Benou67 on October 18, 2010, 11:38:39 am
Woaw !!!!!
Thanks guys ! I like it too
. I've been working hard all the summer to get it but it worth it !
Last Edit: October 18, 2010, 14:25:27 pm by Nico86
Re: '68 cal-look ;)
Reply #237 on:
October 18, 2010, 14:29:17 pm »
Quote from: Felix/DFL on October 18, 2010, 12:11:39 pm
Hi Nico,
Best greetings,
Felix
Felix, I took new pics of the case (other pics were made with direct spotlight and reworked with Photoshop), here are unmodified pics. I noticed 4 major corroded spots, 3 on the right side of the case, 1 on the left side, under the sump it is just dirty and with little scratches.
First 2 corroded spots seems to be superficial, washers emplacements are in good shape.
This is on the right side of the sump, a little more important.
And the most annoying is this on the left side, where the cylinder has been spot faced.
Well I cant' afford a new case or an used one+all the machining for now. First 3 corroded spots seems OK, but for the 4th one you think I can have the case spot faced again ? But it will put the cylinder in an un-correct height ? Or I have to have the 4 cylinders machined again of 1mm ?
And yes, case will be painted.
Last Edit: October 18, 2010, 15:27:47 pm by Nico86
didi
Re: '68 cal-look ;)
Reply #238 on:
October 18, 2010, 19:39:04 pm »
Hi Nico
As previous noted, a perfect case is something different.
But if you want to go with it, i wouldn't spot face the barrel seats surface again. Fill the corrosion holes with Dirko-S Profi Press HT (black, not the red one) or something similar during the assembly process. The rest of the surface look so far ok and is strong enough to keep the head studs preloaded. Be carefully, that the barrels are not sitting on the head stud case savers!
Greetings
Didi
Didi - Aircooled VW
http://didivw.blogspot.com/
Re: '68 cal-look ;)
Reply #239 on:
October 18, 2010, 20:28:02 pm »
Thanks didi, I will try with this. Got a link to get this product ?
7
8
9
10
13
