August 12, 2026, 16:38:14 pm
'68 cal-look and another one
5
13
Topic: '68 cal-look and another one (Read 574381 times)
Re: Another late (almost)cal-look : 68 beetle !
Reply #60 on:
March 04, 2009, 19:17:47 pm »
Reply #61 on:
March 05, 2009, 09:35:06 am »
Nico, you need what is known as a "mag nut". You have a stud for the drum/disc and the nut that holds the wheel on has a slimmer section that slides into the wheel. A flat washer locates against the face of the wheel to spread the load. My old American Eagle wide five fuchs had them. They're quite common on American made wheels. I'll have a look on the samba for a picture.
Reply #62 on:
March 05, 2009, 17:28:16 pm »
Ok thanks ! That's the kind of nuts I can use ?
Last Edit: March 05, 2009, 17:34:23 pm by Nico86
Reply #63 on:
March 05, 2009, 17:33:27 pm »
Sorry double post
Reply #64 on:
March 06, 2009, 10:53:39 am »
That's the ones! Couldn't find a picture on the samba, which is wierd because I'm sure i've seen them on there before!
But al least you've found the right ones. I was thinking about the conical hole and I suspect that it has been modified to take a locking wheel bolt.
Reply #65 on:
March 06, 2009, 18:44:19 pm »
Thanks for the infos Neil ! Maybe one hole have been modified, I can't see on the pics I found on the internet if all wheels are like this or not. That's not a problem as I'll also use a locking bolt.
I also found these washers, they are made for Erco's, and seem to allow mounting conical bolts on flat holes ?
And also I can put this kind of flat nuts with studs and flat washers ?
Last Edit: March 06, 2009, 18:48:45 pm by Nico86
ESH
Reply #66 on:
March 06, 2009, 20:13:05 pm »
Quote from: Neil Davies on March 05, 2009, 09:35:06 am
... you need what is known as a "mag nut" ...
For a minute there I thought you were referring to Fabian.
Reply #67 on:
March 12, 2009, 12:56:12 pm »
Quote from: Nico86 on March 06, 2009, 18:44:19 pm
I think the idea of the long shoulder is to go inside the wheel and centre the wheel on the studs. Without those, the wheel could rattle around on the studs. If the holes are the same size as the studs, you'll be able to use the Erco-style washers and conical nuts, but I'd measure the diameter of the stud holes first.
Reply #68 on:
March 12, 2009, 12:56:44 pm »
Quote from: Mat Sanchez on March 06, 2009, 20:13:05 pm
If the cap fits...
Reply #69 on:
March 12, 2009, 17:19:45 pm »
Ok thanks Neil ! I'll check the stud-holes diameter.
Reply #70 on:
March 12, 2009, 21:37:48 pm »
The diameter of the stud holes on the Shelby is 16mm, on the Flat4 it's 15,5/16mm, and the bolts I have are og vw diameter (14mm if I remember well). So I can't use mag nuts with shoulders I think ?
I will go with conical bolts and Erco-style washers , I will try to make them myself.
Here are the parts my dad made for the center of the Flat4 wheels, It's machined in a full aluminium cylinder. I don't know the name of this part in english, I need it because strangely the Flat4 wheels don't fit exactly on my front discs brakes, they are vw brakes though and go ok with og steel wheels and all other wheels I've tried.
Reply #71 on:
March 13, 2009, 20:31:13 pm »
Today we made the parts that holds the center caps, it's again machined in aluminium. I'll replace the BTR screws that look too modern.
Last Edit: March 13, 2009, 20:32:50 pm by Nico86
Reply #72 on:
March 19, 2009, 18:09:38 pm »
Go !
After a few hours the inner sides are clean.
Last Edit: March 19, 2009, 18:18:34 pm by Nico86
Re: Another late 68 (almost)cal-look
Reply #73 on:
March 20, 2009, 13:46:31 pm »
A quick "before and after" :
roland
lates are the new splits...
Reply #74 on:
March 20, 2009, 16:53:02 pm »
Nice!
Reply #75 on:
March 25, 2009, 14:28:13 pm »
Quote from: roland (DAS) on March 20, 2009, 16:53:02 pm
Nice!
The washers for the Shelbys are ready, we made it with stainless steel. There will be 3 "flat" washers per wheels, and 1 "conical" washer for the hole that's already conical on the wheel. It's almost finished, now I have to polish and clean washers, bolts, center cap adaptators and wheels outer sides.
My whashers are the same style as the blue ones on this beetle.
Last Edit: March 28, 2009, 19:34:19 pm by Nico86
Reply #76 on:
March 28, 2009, 20:00:42 pm »
Pics from last year, with the old BRMs and turbo muffler.
Last Edit: October 12, 2010, 01:36:26 am by Nico86
Reply #77 on:
March 28, 2009, 20:27:09 pm »
Nice car Nicolas.
When are the new wheels coming?
Reply #78 on:
March 28, 2009, 20:30:20 pm »
Quote from: vwcab on March 28, 2009, 20:27:09 pm
Nice car Nicolas.
Thanks ! I'm now hand-polishing the outer sides of the Shelbys, I want them as clean as the Enkeis, that's a long work
. I hope to have everything finished and mounted on the car next week.
I was thinking about the tire sizes for my new wheels, on these 4 pics I was running 185R15 and 155R15, both Vredestein Sprint Classic. That doesn't look bad.
Last Edit: October 12, 2010, 01:36:42 am by Nico86
JeePee/DVK
Re: Another late '68 (almost)cal-look
Reply #79 on:
March 29, 2009, 09:14:11 am »
Nice car and nice wheels.
But the stickers on the side windows??
Nico??
Reply #80 on:
March 29, 2009, 10:38:27 am »
Quote from: JeePee on March 29, 2009, 09:14:11 am
Nico??
Yes I know
, but don't worry I want to buy pop-out windows that will come without any stickers, and my current windows will go to the wall of my garage.
Last Edit: March 29, 2009, 10:43:37 am by Nico86
Reply #81 on:
April 05, 2009, 19:46:39 pm »
Front wheels are ready, and rear wheels are clean.
tikimadness
Reply #82 on:
April 05, 2009, 20:22:10 pm »
Should look cool on the car Nico
Michael
NIDGAFWYT
Reply #83 on:
April 19, 2009, 18:41:30 pm »
Quote from: tikimadness on April 05, 2009, 20:22:10 pm
Michael
Yep' !
No news about the wheels, I'll order new tires and I'm waiting for it.
But this weekend a new carpet kit was installed.
Last Edit: October 12, 2010, 01:36:57 am by Nico86
Reply #84 on:
April 19, 2009, 18:43:39 pm »
Do you like blue ?
I really really need a cooler shifter !
Last Edit: October 12, 2010, 01:37:07 am by Nico86
Paulus
Reply #85 on:
April 19, 2009, 19:16:25 pm »
Damn, looks really good Nico !!
Hope to see the enkeis soon under your car
Less is More !
Reply #86 on:
April 20, 2009, 11:02:47 am »
Quote from: Paulus on April 19, 2009, 19:16:25 pm
Thanks !
Nico-67
Reply #87 on:
April 20, 2009, 11:05:31 am »
These wheels are very cool !!!
That will be look very good on your car
http://nico-67.skynetblogs.be/
Reply #88 on:
April 20, 2009, 11:09:52 am »
Quote from: Nico-67 on April 20, 2009, 11:05:31 am
Yep I can't wait to get my new tires and mount them !
Reply #89 on:
April 24, 2009, 18:13:46 pm »
I received the rear tires, the front are comming but are out of stock for the moment.
5
13
