October 13, 2026, 04:57:26 am
Black magic problem
Topic: Black magic problem (Read 10131 times)
Elnef
Black magic problem
June 13, 2008, 16:39:58 pm »
As you can see on the picture I have some crack problems with my disk
is that normal for one year of use ? I have a spare one also short time used but that have also small beginning cracks so what disk do you guys use one your race engine ?
I have used the disk with a stage 1 kennedy
the engine is a 2979ccm type 4 276hp and 290nm
thanks John
Re: Black magic problem
June 13, 2008, 17:27:54 pm »
I never had problems like this , but heard about it . Almost watch for cracks .
www.Udobeckertuning.de
K-Roc
June 13, 2008, 18:58:16 pm »
Hi I looked as close as I could in your picture's but can not see the SFI label or the Mcleod "Clover" stamp on that disc and that would leave me to believe it is a Chinese Copy of the original American made product,
Where did you purchase that Disc from?
K-Roc,
Frank LUX
Back...Soon...hopefully!!!
June 13, 2008, 19:53:09 pm »
Quote from: K-Roc on June 13, 2008, 18:58:16 pm
K-Roc,
Don't wanna play the Smart Ass here, but I noticed the Same...
PS: I joined a Picture of my Black Magic Disc...
Frank
Oliver Frey
June 13, 2008, 20:33:51 pm »
Quote from: Frank LUX on June 13, 2008, 19:53:09 pm
K-Roc,
Frank
Off topic, but it sure is nice for RLR to include a set up guide for this clutch. I ordered mine elsewhere and was told basically figure it out on your own.
K-Roc
June 13, 2008, 23:20:18 pm »
K-Roc,
Frank
Ya I hope my comment isn't taken as a slam as it was not intended that way, ( Although I am known as a smart ass from time to time However)
Here is a link to the Chinese ones.
http://www.qscusa.com/clutch.htm
Thanks K-Roc
Steve D.
June 14, 2008, 01:23:03 am »
I've seen probably a dozen real black magic disks with loads of cracks in them, but none of them ever actually failed like that- the owners just noticed the cracks during teardowns/maintenance.
Also, all of those clutches had the clover stamp as well.
Über Alles
10.77 avg. on pump fuel.
238I
June 14, 2008, 03:38:38 am »
Also look at the center hub where the splines are Franks is thicker then the other one
Elnef
June 14, 2008, 07:35:45 am »
Thanks for youre replys
There was a sfi label on it and if I renember right it says "SFI 1.3" and my spare one has the same center as Franks so maybe my spare one is a china copy or a RLR but what do you guys think buy a new black magic and replace it when the crack come and so on or change to a sort of a super disk and go up to stage 3 in presure plate ??
John
Roman
June 14, 2008, 08:12:23 am »
I used a super Daikin and a stage 2 last year on my bug. It could just hold the torque, but started to slip after a like 8-10 runs. A stage 3 might have cured it, but I am going for a 4-puck and a stage2.
June 14, 2008, 08:23:33 am »
Removed by my choice
Last Edit: June 14, 2008, 17:37:39 pm by richie,uk
June 14, 2008, 13:52:14 pm »
K-Roc,
Thanks for the link K-Roc. Jesus these guys copy about everything, check out those "racing Heads" and Aluminium cylinders.....
Frank LUX
June 14, 2008, 14:27:09 pm »
Quote from: FDK/Hurry on June 14, 2008, 13:52:14 pm
K-Roc,
What I heard is that those Aluminium/Nikasil Cylinders are great...
Frank
Jay Aldred
June 14, 2008, 17:31:28 pm »
Mine has also cracked as well as destroying at least 3 brand new Kennedy Stage 2s, one of them on one pass. I have now changed combo to the competition engineering twin floater set-up, hopefully this will work for me.
Jay..
GetBackOnTrack
June 15, 2008, 16:02:04 pm »
Hi John. The exact same thing happend to my black magic disc last year. Ran it with a stage 1 pressure plate for like 3 month before it end up cracked like yours, I didnt even ran slicks with it. Dont know if it had that stamp you all talk about. Besides the cracked black magic disc I cracked 2 of my syncroes in my gearbox.
I just shifted to a stage 3 with superdisc a couple of days ago, havnt had the chance to drive with it yet, but a stage 2 with superdisc couldent hold my engine, you know the specs John.
Spring.
Check: gbot.dk
