September 22, 2026, 10:41:43 am
Vertigate shifter
Topic: Vertigate shifter (Read 18903 times)
sven
Vertigate shifter
June 15, 2008, 07:58:57 am »
Hi everybody,
I'm new here.
To be ready for the
European Bug Inn
I still need to find a vertigate shifter, is their somebody who can help me?
Thanks.
Sven
www.dbsvw.be
Re: Vertigate shifter
June 15, 2008, 11:27:54 am »
Cant help with the shifter......
But car looks great!
Tekken
www.proturbovw.com
June 15, 2008, 11:29:19 am »
There are a few types,JCL in the US makes a really sweet but expensive one.Here is the one from MSE/RLR..(click chassis parts-mounting hardware)
http://www.ronlummusracing.com/Race_store.htm
sven
June 15, 2008, 18:06:18 pm »
Thanks, I have send a mail to RLR, I hope that they have one in stock.
Last Edit: June 15, 2008, 21:14:00 pm by sven
lowfastbus
WUNDERWAFFE
June 17, 2008, 12:58:59 pm »
Hey Sven,
Good luck on getting the car ready!!
Jelle
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
June 17, 2008, 13:45:37 pm »
Awesome looking car! Speak to Peter Englezos at Cogbox - he runs one in his Fiat and would probably be able to talk through set-up too. Bernard Newbury also runs one I think.
benssp
www.callookvw.com
June 17, 2008, 14:56:16 pm »
Bernie, Travis and Dave Dinning all run them
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
Joe_G
June 17, 2008, 21:13:13 pm »
Quote from: benssp on June 17, 2008, 14:56:16 pm
Me too, if I can ever get the clutch sorted!!!!
Anyone got instructions for a J&G floater clutch in a Pauter case with a t2 box
Tekken
www.proturbovw.com
June 17, 2008, 22:41:05 pm »
Quote from: Joe_G on June 17, 2008, 21:13:13 pm
Hi Joe G,what kind of instruktions are you looking for?
Martin
Cash Converter....
June 18, 2008, 09:38:48 am »
Quote from: sven on June 15, 2008, 18:06:18 pm
I got mine direct from MSE.
001 570 754 7209
http://msebg.org/product.html
Martin
www.taylormachine.co.uk
OFF/500
Elnef
June 20, 2008, 11:14:55 am »
Any one there can tell how it works ?
yes I know 1-2-3-4 but what about 4--3 or 4-2 and how will it always go to first not 3rd ?
maybe a stupid question but I will like to know
benssp
www.callookvw.com
June 20, 2008, 11:26:12 am »
It's a drag shifter 1-2-3-4-neutral, cool down,fill up,1-2-3-4, repeat until broken
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
Martin
Cash Converter....
June 20, 2008, 13:07:19 pm »
Quote from: Elnef on June 20, 2008, 11:14:55 am
for 1st squeeze the trigger and push forward
for 2nd pull the shifter backwards
for 3rd push the shifter forwards
for 4th pull the shifter backwards
to go from 4th to 3rd push the leaver forwards
to go from 3rd to 2nd squeeze the trigger and pull the shifter backwards
and from 2nd to 1st squeeze the trigger and push the shifter forwards
you have to bear in mind that the shifters change gear so fast that you have to use Pro rings in the box. Peter found this out on his own car.
Last Edit: June 21, 2008, 14:43:38 pm by volksman
Martin
OFF/500
Elnef
June 21, 2008, 08:12:06 am »
RMS Boxer Service
June 21, 2008, 12:46:28 pm »
My friend Bang have bought a very fine shifter from a german company,
http://www.cae-racing.de/
I know, it's a H pattern shifter
Fast delivery and super service.
/Rolf
Last Edit: June 21, 2008, 12:57:37 pm by Callook_67
bang
June 21, 2008, 13:41:42 pm »
and it is so nice to use, i have testet it many times now and have not misssed a gear yet. i know the vertigate shifter is nice to but there is alot of work to bu if you want to fit it on a standart pan..
sven
June 23, 2008, 18:15:44 pm »
How does it works? I use a 091 bus box with the shifting rod mounted above the chassis .
bang
June 23, 2008, 19:43:55 pm »
i run with a bus gear aswell and use the original shift rod inside the pan. you just have to make a small bracket to mount the shifter on.. can post you pictures of mine if you want.
Tekken
www.proturbovw.com
June 23, 2008, 21:20:00 pm »
With vertigate,instead of using the H pattern to select gears,you have one rod directly on each gear.
