October 13, 2026, 05:14:49 am
falling down while dancing like Tinkerbell
Topic: falling down while dancing like Tinkerbell (Read 14035 times)
June 17, 2008, 16:31:48 pm »
Try and build the hottest hot-rod motor you can,
using only factory internals
... Webers and headers are ok... post your ideas.
leading up to another post idea....
see ya,
Jim
Last Edit: July 12, 2008, 22:06:26 pm by Jim Ratto
Re: using only Volkswagen parts....
June 17, 2008, 16:35:23 pm »
Cool idea, Jim. Hopefully, we'll get some insightful input/posts regarding this. For extra credit, use Solex 40P11 carbs.
June 17, 2008, 17:04:03 pm »
Thanks Mark... kind of a Formula Vee way of thinking, but 1600cc instead of 1200cc, able to use stock valved dual port heads (but go ahead and reshape ports, plunge-cut...etc...), actually what about those Brazilian 88mm p/c (Puma?) and the OE VW 1.25 ratio rocker arms....
if it came stock on a VW product, it's fair game.
Jordy/DVK
June 17, 2008, 17:07:22 pm »
Oxyboxer 2.1L with aircooled parts... Heavily modified VW heads... 181 Fan shroud... Solex 40PII carbs...
Quote from: Jim Ratto on June 17, 2008, 17:04:03 pm
Soo Bugatti engines are allowed too...
DVK ~
"The Full-Throttle Cruisers"
1951
medium brown splitwindow beetle
(resto in progress)
1968
Cal-look(-a-like)
(my daily driver)
June 17, 2008, 17:08:26 pm »
Quote from: Jordy/DVK on June 17, 2008, 17:07:22 pm
June 17, 2008, 18:52:15 pm »
Type IV
alex d
June 18, 2008, 09:05:18 am »
for a start, wasserboxer crankshaft in a type 1 case
June 18, 2008, 09:09:13 am »
Quote from: alex d on June 18, 2008, 09:05:18 am
I was going to say that! 76mm crank?
rebel
June 18, 2008, 18:06:57 pm »
Is it counterweighted?
Hot VWs RULE!
my site:
http://cal-look.pl
my club:
http://cal-look.pl/ssvwf.htm
my blog:
http://www.california-look.blog.pl
my car:
http://cal-look.no/lounge/index.php/topic,6104.0.html
June 18, 2008, 18:10:25 pm »
that's a neat idea, but let's say you have to keep it 1584cc....
69mm stroke by Sp2 88mm bore
stock valved d/p or 041 VW heads
stock VW cam (but can use 36hp gear for less drag)
VW 1.25 ratio rockers
you can grind, port, lighten, flycut....
June 19, 2008, 02:51:23 am »
Swiss cheese the rods
Still aren't going to get much out of it though
June 19, 2008, 03:04:16 am »
This little manx is running a STOCK uncounterweighted crank(4 dowel), STOCK rods, STOCK Cam, Ali push rods, STOCK sized valves - ok its 1776cc but apart from that its a STOCK bottom end
Last Edit: June 19, 2008, 03:23:38 am by monkiboy
June 19, 2008, 06:31:04 am »
Now THATS a wheelie!
June 19, 2008, 11:04:14 am »
Quote from: monkiboy on June 19, 2008, 03:04:16 am
And my race car (which those front wheels came from!) ran a 1584cc motor with stock crank (just added 4 extra dowels!), rods, pistons, barrels, valves and springs, oil system and I think stock cam as well. Added carbs and a header and ran 15.75 best! As far as i know, the case halves had nevre been split and it was as built in the factory!
June 19, 2008, 11:20:04 am »
i think the key in building this kind off engine is getting all the specs and tolerances just right. attention to detail and finish will be important. i know when i rebuild the 1641 engine it was way better then before, by just taking care off the cooling (improving it and close it all like it should be) and have a less restricted oilcircuit with less bents in the fittings and lines. it ran at 70°C - 80°C and that improved power a lot over the hotter running engine before that.
karl h
June 25, 2008, 11:45:11 am »
76mm wasser crank with P/Cs from a 1700 type 4 (90mm bore - can be modified for type 1 stud pattern) equals 1933cc
wasserboxer cam and 1.25s, stock dualports ported/polished, 36/40 solexes from a type 4 or porsche 914 on type 3 manifolds
stock exhaust opened and the tubes modified to let them flow more (like porsche salzburg rallye bugs)
228mm clutch from a wasserboxer, TSZH ignition....
wait... i got most of these parts in the garage
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
June 25, 2008, 13:43:10 pm »
Quote from: karl h on June 25, 2008, 11:45:11 am
NICE! Sounds like what Jim's after. We're going to need detailed pictures, showing you building this wonderful engine.
karl h
June 25, 2008, 14:33:51 pm »
well at the moment there is a 82x101.6 engine on the bench
i wanted to build this engine for my 61 panel. what i still need is a 1mm linebored case, so i can fit the waterboxer crank
the panel needs a ground up resto first
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
67worshipper
June 25, 2008, 17:00:24 pm »
Quote from: Neil Davies on June 19, 2008, 11:04:14 am
how light was your car neil? when i saw your old racecar in total vw (i think) i loved it.one of my most thumbed issues at the time! i also had a club magazine with your car featured in it.i think it was called aircoolzine
vw hot rod heaven
June 26, 2008, 17:37:52 pm »
Quote from: 67worshipper on June 25, 2008, 17:00:24 pm
Had it weighed once with the old cage, before the chro-moly one went in. It was 1639lbs (743kg) with me in it, and at the time i would have been about 17stone, so roughly 1400lbs (635kg) without me! I loved it too - pity the new owner didn't. It was scrapped 8 weeks after I sold it.
Aircooler 'Zine was the brainchild of Ben Bosworth, our late club president. He did one full size issue and several smaller ones, always a superb read!
June 26, 2008, 19:09:01 pm »
An old engine as it looked in 1949.
June 26, 2008, 19:14:46 pm »
Quote from: DKK_Fred on June 26, 2008, 19:09:01 pm
explain..... PLEASE
I see OHC's
what are exit ducts coming out from under "cylinders" (?)
June 26, 2008, 19:33:40 pm »
it looks like a early porsche engine
, maybe it's to evacuate blowing air by the fan after being last on the cylinders
Last Edit: June 26, 2008, 19:35:45 pm by speedwell
67worshipper
June 26, 2008, 21:38:17 pm »
Quote from: Neil Davies on June 26, 2008, 17:37:52 pm
it was one of the smaller issues i had.ben bosworth i didnt know him but a great loss to the vw scene.who had your old car then? or is it to painful to talk about
vw hot rod heaven
June 27, 2008, 10:00:37 am »
Quote from: 67worshipper on June 26, 2008, 21:38:17 pm
Long story, and completely off topic, I've just spent 15 minutes writing it out but it's not worth going into too much detail.
End of the day, I sold the car to someone who was going to race it, they chopped it up. I expected it - his previous car was a german looker based on a late '90s Mexican, that got chopped up. Before that he had a '62, as a stocker restored by Julian Hammond (now works at BFY Obsolete I think) it was shown at Stanford Hall and I believe it even won a few shows. That car is now a beach buggy because he cut the shell up as he was driving it! Last I heard he'd got a new Beetle with an Audi TT motor that had mysteriously gone missing. He's a f*cking moron and I hope he drops out of the VW scene before he chops up anything else.
67worshipper
June 27, 2008, 17:26:07 pm »
why do people do that! why cant they chop something up thats f@ckin scrap instead
vw hot rod heaven
John Rayburn
June 30, 2008, 23:29:12 pm »
Type 4 valves and make the type 4 1.3 rockers work on the type one head?
I also park at Nick's.
karl h
July 01, 2008, 06:39:23 am »
the type 4 or wasserboxer valves are longer than stock type 1, so i think you will have problems with the pushrods (remember, only vw parts
there must be some way to use the type4 rockers, but i think they are longer than a type1 rocker (i mean the spacing of the axis of the valve to the pushrodtube is greater), maybe the pushrods will rub the tubes
biggest problem i see is the exhaust, because the modified stock muffler is loud as hell
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
July 07, 2008, 19:40:30 pm »
now this is really getting interesting
Reply #29 on:
July 08, 2008, 12:21:58 pm »
Quote from: monkiboy on July 07, 2008, 19:40:30 pm
What, the new title? I think Jim is suffering from sleep deprivation thanks to Junior...
