September 22, 2026, 07:09:17 am
| | |-+  IRS spring plate retainers
Author Topic: IRS spring plate retainers  (Read 15691 times)
SteveW
« on: June 17, 2008, 18:41:34 pm »
Does anyone know where I can get Ally spring plate retainers like the JCL ones etc but for IRS? I think I read somewhere that GWD may do them but as I don't read German very well I can't find them on the website!
Steve
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
« Reply #1 on: June 17, 2008, 20:53:19 pm »
steve,what spring plates are you using? I have sway a way h/d non adjustable and just use regular swing axle retainers.I am fairly sure that if you are using adjustable ones they make retainers for those,they just have a small spacer behind the cover where each bolt goes through
cheers richie
SteveW
« Reply #2 on: June 17, 2008, 22:54:31 pm »
Well at the moment just for mock up etc I've just got stock IRS single springplates, would you recommend sway away ones? I can't go adjustable because of the backspace of the Erco's..
Steve
1970 Stock Beetle.
« Reply #3 on: June 17, 2008, 22:57:25 pm »
PMed yah
cheers richie
« Reply #4 on: June 18, 2008, 09:47:07 am »
Are you talking about the bras bearing ones? Those would bind if used on a IRS, so I don't think they exist.
« Reply #5 on: June 18, 2008, 11:11:00 am »
Why?
cheers richie
« Reply #6 on: June 18, 2008, 12:04:39 pm »
Because....    or are they sloppy enough to take it?  Shocked
« Reply #7 on: June 18, 2008, 12:21:50 pm »
Interesting view,I always thought it was the inner bush that was pivoted in both arcs and the outer stayed straight,if not wouldnt the spring plate rub against the housing or cover?
Steve see what you have started now Shocked Cheesy
cheers richie
« Reply #8 on: June 18, 2008, 12:56:30 pm »
I'm not sure Richie, but I wouldn't go with solids on a IRS, due to this design... something has to "give" somewhere?
If they exist they must work... right?  Smiley
« Reply #9 on: June 18, 2008, 14:02:42 pm »
What American engineering? of course it will work Wink Cheesy  What if we chrome them,will that help?? Shocked
cheers richie
Martin
Cash Converter....
« Reply #10 on: June 18, 2008, 15:33:36 pm »
have you seen these?
http://www.elephantracing.com/suspension/bushings/911bushings.htm
I know there for a 911, but its looks easy to make, hey they might even fit!........ duno if they do them in chrome though lol
Martin
www.taylormachine.co.uk
OFF/500
SteveW
« Reply #11 on: June 18, 2008, 16:51:18 pm »
 Grin Grin
When I spoke with Wayne yesterday he said they sound similar to stock Porsche 944 items??
Maybe they resemble something like what Martin has posted?!
Steve
1970 Stock Beetle.
Bernard Newbury
9.50 @ 141 MPH
« Reply #12 on: June 18, 2008, 17:52:06 pm »
I have run the ally plate with bronze bushing for a few years with SAW non adjustable spring plates. Swingaxle and IRS. I used the same part on both. Bernie
« Last Edit: June 18, 2008, 17:56:15 pm by Bernard Newbury » Logged
SteveW
« Reply #13 on: June 18, 2008, 19:52:18 pm »
These are the GWD versions, they feature a ball bearing rather than a bronze bush
I found the pic searching on the cal-look.com forum..
Bernie what spring plates did you use?
Steve
1970 Stock Beetle.
Bernard Newbury
9.50 @ 141 MPH
« Reply #14 on: June 18, 2008, 21:07:10 pm »
Sway-a way
« Reply #15 on: June 18, 2008, 23:39:37 pm »
Grin Grin Grin
tikimadness
« Reply #16 on: June 19, 2008, 20:20:51 pm »
I modified a pair of swingaxle plates to Irs plates then I used the JCL retainers it works great.
michael
NIDGAFWYT
dangerous
« Reply #17 on: June 19, 2008, 21:04:42 pm »
I think you will find the swing axle has the same geometry problem, only worse, when you project lines from pivot points.
I run stock stuff with eurethane , and have never under stood the need for these shiny items however.
Hell I ran well into the nines(147) with stock rubber and the car drove super nice.
Perhaps there is some ET to gain from the reduced toe change?
« Reply #18 on: June 20, 2008, 03:28:09 am »
You are forgetting the spring plate can and does twist.  There's no conflict.
« Reply #19 on: June 20, 2008, 07:32:14 am »
There is no doubt in my mind that it works fine in stock form... with rubber. But just common sense tells me that when you twist the plates as VW intended, the rubber will let the plate pivot pretty easy compared to twisting the plate when its in a non forgiving bushing. With rubber you will deform the rubber all the way before the plate twist, with bushing the plate will HAVE to twist from the first second... unnecessary the less you have to jamb or twist stuff, the better in my book...  there is a conflict, but a very small one  Smiley
Svwerker
« Reply #20 on: June 21, 2008, 15:26:19 pm »
The VW IRS (Typ1 ond Typ3) and the Porsche 944 are geometrical the same. If it work on Porsche it will work on VW.
