September 22, 2026, 10:18:01 am
Fuel pressure??
Topic: Fuel pressure?? (Read 8460 times)
Buttons
I got 56 reasons to kick your ass!!
Fuel pressure??
June 19, 2008, 17:19:13 pm »
What kind of fuel pressure should i be getting?
The guage on my regulator reads 3psi when ignition is on and pump is running, BUT when the engine is running it drops to 0psi!!
The motor is popping and banging when revved, hence the reason i looked at fuel pressue.
Any ideas?
(2276 IDA'd with Holley fuel pump if that helps!)
SteveW
Re: Fuel pressure??
June 19, 2008, 17:52:47 pm »
Well with my limited knowledge I'd say you have a problem with the holley fuel pump or its a problem somewhere else causing the pressure to drop (short circuit maybe?) IDA's need a constant 3 to 3.5 PSI fuel pressure..
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
Re: Fuel pressure??
June 19, 2008, 21:02:55 pm »
Try a different gauge. If your car continues to run with 0psi, the gauge isn't right.
Re: Fuel pressure??
June 19, 2008, 22:30:09 pm »
again, if it is liquid filled when engine compartment gets hot, it will show inaccurate reading. I had a liquid filled gauge make me chase my tail for a few months back in mid 90's.... drive car, gauge showed under 1psi, cranked reg up to show 3psi, carbs flooded, burbled, ran like shit.
Re: Fuel pressure??
June 20, 2008, 03:19:56 am »
Quote from: Jim Ratto on June 19, 2008, 22:30:09 pm
..., carbs flooded, burbled, ran like shit.
I had that problem recently and the gauge said the pressure was good. So I tried another gauge. It agreed with the first. But it still flooded. A
third
gauge confirmed the first two were duds.
Those small gauges everyone uses are junk, and they get shook to death.
Re: Fuel pressure??
June 20, 2008, 16:31:03 pm »
Quote from: Bruce on June 20, 2008, 03:19:56 am
third
I agree. I am going to eventually need another...
What i want to do is just buy a real diagnosis type pressure checking gauge, then plug hole in tee.
Re: Fuel pressure??
June 20, 2008, 16:37:23 pm »
Quote from: Jim Ratto on June 20, 2008, 16:31:03 pm
third
69Stu
Re: Fuel pressure??
June 20, 2008, 21:19:32 pm »
Have you tried adjusting the fuel with the engine running?
Buttons
Re: Fuel pressure??
June 20, 2008, 22:03:02 pm »
No... you mean adjust the regulator whilst it's ticking over??? that sounds pretty logical......... thanx
John Rayburn
Re: Fuel pressure??
July 01, 2008, 01:30:22 am »
Sounds like your pump has something stuck in the bypass. Run the engine, and smack the pump around with a wrench or something, it'll probably dislodge. Good luck.
I also park at Nick's.
