September 28, 2026, 14:38:32 pm
| | |-+  4-cam 16V heads for Type 1 (air cooled)
Author Topic: 4-cam 16V heads for Type 1 (air cooled)  (Read 17009 times)
« on: June 23, 2008, 16:31:30 pm »
Thanks Derek for the picture. I am anxious to see these on a motor, with cooling shrouds and intake, exhaust.
« Reply #1 on: June 23, 2008, 16:56:15 pm »
 Shocked
looks pretty revolutionary  Cool
kafercup
« Reply #2 on: June 23, 2008, 19:01:51 pm »
No problem Jim Smiley
These are being done by Martin Bott at http://www.bugat5speed.de/  . This guy makes some beautiful pieces for fitting various porsche transmissions to the aircooled VW chassis.
I'd be happy to test out a set of these  Smiley
Prowagen
« Reply #3 on: June 23, 2008, 21:02:04 pm »
Wow they look good, have always loved the idea of twin cam heads and/or 16v heads.
I have seen a bug featured in the mags with the Arao versions but never heard any feedback, also upon internet searches seems arao haven't the best reputation.
http://www.araoengineering.com/VWheads.htm
Also I would worry about the rocker stress with these.
How will the Bugat5speed ones work? I presume stock cam location is done away with and then the over head cams are driven off the crank pulley via belts?
Cheers,
Rob
ian c
« Reply #4 on: June 23, 2008, 22:09:27 pm »
i have some info on twin-camds somewhere , will dig it out .
i also have contact details for a company that havce designed twin spark heads .......  very very good idea Wink
(o\ ! /o)
Prowagen
« Reply #5 on: June 23, 2008, 22:35:47 pm »
I believe Revmaster make twin spark heads too.
« Reply #6 on: June 23, 2008, 23:10:50 pm »
There have been several makers of twin spark heads for the type 1, for use in air planes.
ian c
« Reply #7 on: June 23, 2008, 23:14:00 pm »
interesting !!
would they be viable in a motorcar or is it an aviation specific design ?
any info you can send me will be most appreciated Smiley
« Last Edit: June 23, 2008, 23:18:55 pm by ian c » Logged
(o\ ! /o)
ian c
« Reply #8 on: June 23, 2008, 23:27:35 pm »
i managed to get some info
http://www2.cal-look.com/members/Fetherolf/Fetherolf.html
(o\ ! /o)
« Reply #9 on: June 24, 2008, 00:02:09 am »
Some of these engines have the dual spark setup http://www.limflug.de/index.php?page=products_motors_40-75kw&lang=de
Bewitched666
Bewitched
« Reply #10 on: June 24, 2008, 08:41:05 am »
Only saw that grey oval with the arao system but looked ugly from the backside with everything sticking out. Cool
Fast vw beetle's rule
« Reply #11 on: June 24, 2008, 09:37:00 am »
i think there was a feature in Ultra about this little puppy  Smiley
ESH
« Reply #12 on: June 24, 2008, 10:04:35 am »
... i also have contact details for a company that havce designed twin spark heads .......  very very good idea ...
On aero applications the twin spark per cylinder set up is for redundancy. An engine I saw a few years back had the set up (along with a roller crank and a Speedwell oil system amongst other things) but when that went into a car I think it only ran 4 sparks.
« Reply #13 on: June 24, 2008, 15:41:29 pm »
I think when Russ Fellows used the Porsche 911 heads on his Type 4 motor he went twin spark, and the red supercharged buggy in Volksworld's letters page a month or two ago from an Australian show looked to have an extra set of plug leads.
Felix/DFL
« Reply #14 on: June 24, 2008, 18:37:30 pm »
There is even a very nice solution for an 12V aircooled engine based on a typ-4 case.
Some Netherlands guys are/were? doing this project along the roots of Ludwig Apfelbeck.
Nice thing about a 3V head is the extra room for the two sparks, and the good flow at the inlet like a 4V head.
http://members.home.nl/r.vd.meulen/demo.htm
http://www.apfelbeck.nl/
« Reply #15 on: June 24, 2008, 22:36:31 pm »
If you want 2 spark plugs in an original head ask at CSP . They do this for some comanys
Airspeed
« Reply #16 on: June 28, 2008, 08:47:55 am »
Those are not for a type 1 engine. Neither type 4. According to Martin Bott they will only work on his also to be designed new engine casing.
« Reply #17 on: June 29, 2008, 05:13:36 am »
Oh... ok, thanks for clarification. I would enjoy seeing some more info on this new motor, is he a member here @ Lounge?
Jim
