October 12, 2026, 21:36:06 pm
cooling tin with jp motorsport cylinder heads
Topic: cooling tin with jp motorsport cylinder heads (Read 5021 times)
bang
June 24, 2008, 16:11:36 pm »
have anyone tryed to fit cooling tin with jp heads? do you use s/f tin or modyfi stock?. my engine is a oxy boxer with 30 hk fan house. and i use 5,7" rods so it is a bit wider than stock..
if anyone have pictures i would like to see pictures..
thanks.
Peter Bang
Denmark
"Big Bang Racing"
Roman
Re: cooling tin with jp motorsport cylinder heads
June 24, 2008, 19:23:00 pm »
I have done it but I had very low pin height, so it was narrower than stock, but on the other hand: A wider engine does only affect the case side of the cooling tin and and almost every stroker has the same problem.
The JPM heads are like any Superflo/Competition eliminator: They are very big around the intake manifold. Cut/hammer and take your time, it is easier to cut twice than weld back material again.
