July 23, 2026, 03:46:18 am
| | |-+  some parts choosing questions...
Author Topic: some parts choosing questions...  (Read 7067 times)
rebel
« on: June 27, 2008, 17:43:48 pm »
hey guys!
Don't know if I should put theese questions in here, but...
I need some kind of traction bar and/or HD trans mount for my 1914cc.  I ain't too hard-core, but I have problems with launching
I was considering a classic traction bar and/or Bugpack Trans Mount. Woat would you choose for not so strong engine?
It sould work okay in the first place, style is second priority Smiley
« Reply #1 on: June 27, 2008, 17:44:55 pm »
Berg traction bar and OEM VW trans mounts if it is primarily a street car
make sure your clutch cable sleeve has a "bow" to it too
Bewitched666
Bewitched
« Reply #2 on: June 27, 2008, 17:51:13 pm »
Well said George Jefferson Grin Grin
Fast vw beetle's rule
« Reply #3 on: June 27, 2008, 18:05:22 pm »
thanks "weezie"
« Reply #4 on: June 27, 2008, 18:12:16 pm »
Make your own traction bar!!! It is VERY easy, and costs almost nothing!
rebel
« Reply #5 on: June 27, 2008, 18:49:53 pm »
Thanx for anwer Smiley Do you have plans for it? The steel rectangular tube is the easiest part. I haven't yet figured out how to fix it to the bumper mounts... The pics on the online stores are that small for a reason Smiley
Does it have to be bolted ti the engine in any way, or just let the tube support the engine during launches? Do you know wher to find specific tech info?
« Reply #6 on: June 27, 2008, 20:04:55 pm »
Just make a V-bracket that bolts to the bumper mounts. Be sure to use proper thickness material.
« Reply #7 on: July 01, 2008, 00:54:45 am »
A friend of mine made his own traction bar and went as far as to make flanges off bar that bolted to Type 2/3 mounting bosses on the case (and ran under case too). Not sure if it ever gave up the ghost, being rigidly "bolted" to the case (I thought of case bosses snapping off!) though...
Sam K
« Reply #8 on: July 01, 2008, 01:36:35 am »
A friend of mine made a traction bar that bolted to the case as well, but he made a "U" shaped bracket that fit over the 8MM case bolt below the oil pump. It seemed to work fine.
« Reply #9 on: July 01, 2008, 05:38:19 am »
Post up some images... otherwise:
