September 22, 2026, 10:41:58 am
Mocal thermostatic oil filter mount ????
Topic: Mocal thermostatic oil filter mount ???? (Read 5777 times)
Black Sheep
less is more
June 27, 2008, 17:55:00 pm »
Help please got given this by a mate , doe's anyone run one of these ? I need to know which way the lines go
The top right one is marked in but thats all .
cheers fellas
13.03 @ 98mph
black_bullitt
Re: Mocal thermostatic oil filter mount ????
June 28, 2008, 12:12:35 pm »
try
www.thinkauto.com
this is where I got my mocal stuff from.
If its not listed try emailing them.
Black Sheep
less is more
June 28, 2008, 18:27:01 pm »
Cheers buddy
13.03 @ 98mph
June 29, 2008, 11:32:12 am »
Maybe can you try to heat it with an hair-dryer to see which line is the by pass and which is the line that goes to the radiator?
June 30, 2008, 11:43:31 am »
The way these thermostats works is like VW's own in the engine case. Cold oil is thick and will easily force its way over a spring loaded piston. I bet the piston/spring is hiding behind the little screw you see in the picture. So cold oil would go straight threw the section with the name on. And when hot the oil would come down the oil channel pointing towards us and go back in the other channel pointing towards us and exit to the right. To determine where the oil line should go in, you will have to look at the piston that does the blocking, it will have a design to make it easier for the oil to push it down on the side of incoming oil. It's probably tapered or something.
Good luck!
Black Sheep
less is more
June 30, 2008, 18:08:30 pm »
Thanks for the info Johnny , will go and have a closer look at it now with this new knowledge
13.03 @ 98mph
