October 12, 2026, 17:18:45 pm
Off Topic
How about post reserved just for hardware,part's material's etc...
Topic: How about post reserved just for hardware,part's material's etc... (Read 9980 times)
July 03, 2008, 04:57:47 am »
were to get, what area's,new idea's, new tec.. etc.....
? well
Re: How about post reserved just for hardware,part's material's etc...
July 03, 2008, 05:16:58 am »
yeah good idea... like using Porsche 911 heater box nuts in close quartered areas.....doing that on some new projects
July 03, 2008, 05:24:07 am »
Ya that's what I'm getting at,helping somebody out so they don't have to go throught all the bullshit. I love seeing new thing's trick ! little idea's, place's to get stuff like surplus aircraft hardware. tools, I just bought a peice of equipment off a sight called government liquidation . com lot's of cool stuff if your looken. this is just an Idea.
July 03, 2008, 05:28:22 am »
Quote from: danny gabbard on July 03, 2008, 05:24:07 am
yes, that beats going to Home Depot to buy 5/16" nylocks
Good idea. O-rings, and such would be cool too.
Danny there are numerous pieces and parts from other German cars that can be utilized on VW applications either for improvement or just for something different.
I love going through parts bins
July 03, 2008, 05:42:41 am »
even plater's like crome, cad, polishing, everyboby post where they even had work by somebody or someplace, a library for good and bad,well good or better work not to bag on somebody, but to go somewhere and get good results. building cars you can run into dead end's with project's.
July 03, 2008, 11:03:28 am »
Good idea. I've had Bug doors chemically stripped by a company local to me that specialised in stripping pine furniture! £10 a door - bargain! Can't remember the name but they were on Upper Villiers street in Wolverhampton, for those in the West Midlands!
ian c
July 05, 2008, 12:59:11 pm »
FROST RESTORATION SELL SOME GOOD PRODUCTS .
WWW.FROST.CO.UK
MACHINE MART ALSO SELL GOOD THINGS .
WWW.MACHINEMART.CO.UK
BEST THINGS I'VE HAD WAS A CAD/ZINC PLATING KIT FROM FROST , HANDY FOR SMALL ONE-OFFS
AND THE JOGGLER/PUNCH FROM MACHINEMART MAKES WELDING SOME REPAIRS EASIER . I HAD THE COMPRESSED AIR VERSION .
WELDING MAGNETS AND VICE CLAMPS ARE CHEAP ENOUGH THERE TOO .
MY PLASMA CUTTER AND MIG WELDER WERE SNAP-ON . WHICH ARE REALLY MODELS BY (IIRC) ESAB , SO MY LOCAL WELDING SUPPLIERS COULD SUPPLY CHEAP CONSUMERBLES .
A LOCAL PAINT SPECIALIST GOT ME THE PAINT THAT THEY USE ON OIL-RIG LEGS ETC. MY SISTERS CAMPER HAS THE BOTTOM COVERED IN IT ..... SHOULDNT RUST AGAIN FOR A FEW MORE YEARS
IF YOU KNOW ANYBODY THAT WORKS IN A FOUNDRY , GET A LUMP OF BRASS . I GOT MINE FROM A PLACE THAT MAKES VALVES FOR PIPELINES . USE IT TO ABSORB HEAT WHEN WELDING . I USED TO USE IT FOR FILLING HOLES LEFT FROM REMOVING TRIM .
PLACE BEHING HOLE , MOST OF THE TIME IT WILL HOLD IN THE SLUG OR NAIL IF YOURE USING THAT TO FILL THE HOLE . WELD , THEN COOL WITH COMPRESSED AIR , THEN GIVE A TAP WITH AN HAMMER TO RELIEVE STREES , THEN REMOVE BRASS BLOCK AND ONTO THE NEXT HOLE .
MOST STAINLESS STEEL FABRICATORS USE 1MM THICK CUTTING DISCS .. THESE ARE THE BEST FOR CAR WORK , AS THE CUT QUICKLY HENCE LESS HEAT DISTORTION .
WILL POST MORE WHEN I THINK OF THEM !!!
(o\ ! /o)
ian c
July 05, 2008, 13:02:38 pm »
IF YOU HAVE AN OLD ARC WELDER , YOU CAN GET A CHEAP TIG TORCH , AND CONNECT TO ARGON AND POSITIVE EARTH AND YOU CAN HAVE A GO AT SCRATCH-START TIG !!!
IF YOU KNOW ANYONE THAT OWNS A BAR , THE CO2 THEY USE ON THE BEER PUMPS WILL WORK INSTEAD OF ARGON AT A LOT LESS COST
(o\ ! /o)
ian c
July 05, 2008, 13:03:58 pm »
and if you press caps lock until the blue light goes out , you can type replies in a much less annoying manner !!!
(o\ ! /o)
ian c
July 05, 2008, 13:11:17 pm »
this is a usefull gadget store , and about 3 times a year they sell these solar powered battery top-ups for half price !!
http://www.maplin.co.uk/Module.aspx?ModuleNo=98358&criteria=charger&doy=5m7
keeps my car going when its in storage .
(o\ ! /o)
July 05, 2008, 18:42:33 pm »
Quote from: ian c on July 05, 2008, 13:03:58 pm
ROFL!!!
